Offset
by jcartwright99. 04/18/19 04:07 PM
Honda Camera Design...FAIL
by Sayjac. 04/18/19 04:02 PM
rotella t4 vs delo
by 1978elcamino. 04/18/19 03:50 PM
Champion Oil Filters any Good?
by spk2000. 04/18/19 03:46 PM
Opinions on the best hidden dash cam?
by FordBroncoVWJeta. 04/18/19 03:28 PM
Maxlife Synthetic or PPHM 10w30
by 53' Stude. 04/18/19 03:27 PM
PYB 10w30 question
by 1978elcamino. 04/18/19 03:16 PM
Misbehaving Mechanic Caught On Dash Cam
by BlueOvalFitter. 04/18/19 02:38 PM
What oil for my newly acquired Samurai
by ad244. 04/18/19 02:37 PM
Check your Oil (SMA YouTube Video)
by javacontour. 04/18/19 02:37 PM
Wearing Hiking Shoes Full-Time
by oilpsi2high. 04/18/19 01:56 PM
Apply brakes, steering wheel shakes
by grampi. 04/18/19 01:35 PM
F150 Exhaust whistle
by Redright9. 04/18/19 01:20 PM
Boy, what a marketing win!
by SubieRubyRoo. 04/18/19 12:06 PM
auto shipping question for a friend
by earlyre. 04/18/19 11:02 AM
O Reilly motor oil
by porvdub. 04/18/19 10:59 AM
GM & JEEP O/S OIL FILTERS
by adrenalin89. 04/18/19 10:56 AM
Kenzitoz, White12Boss302, terryj, Hadryk, djcavein
67844 Registered Users
119 registered members (2009Edge, 1978elcamino, 28oz, ad244, 53' Stude, 2dogs, 9 invisible), 2,130 guests, and 26 spiders.
Topics287,707
Posts4,932,672
Members67,844
Most Online2,967
Mar 10th, 2019
GM 4T65E magnets #4499666
08/27/17 06:15 PM
08/27/17 06:15 PM
Colorado Springs
Drew99GT Offline OP
Drew99GT  Offline OP
Colorado Springs
I recently did a pan drop and filter change on my moms Impala and obviously cleaned the pan and magnet; at that time, I because aware of the TSB GM has about replacing the stock magnet with an improved one and adding another to the bottom of the filter. I had already buttoned the trans back up before I could get the new magnets.
I'd like to add a rare Earth magnet to the outside of the pan just to see if it helps keep metal off the solenoids, which is the entire point of the TSB.
For anyone experienced with these GM FWD transaxles, where would the safest spot be on the outside of the pan to put a magnet, or even 2??? I don't want to put it close to where the OEM one is and mess it up. I certainly don't want to get a magnet close to any electronics in the trans and fry them.
Thanks! Has anyone done this to a GM or any other type of car???
Re: GM 4T65E magnets [Re: Drew99GT] #4499737
08/27/17 07:36 PM
08/27/17 07:36 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
There are no electronics/solenoids in the bottom/lower pan on a 4T65E, They are in the side pan.
Buy putting them on the outside of the pan, You will lose a lot of magnet surface area for the debris to cling to.
If your worried about this, Pull the pan & do it right! However......You cleaning the original magnet is satisfactory 'til the next service.
The issue is that the Pressure Control Solenoid attracts metal particles & messes with solenoid response to amperage input from the PCM, Whatever metal is stuck to the PCS already is not going to fall off just because the extra magnets.
Around 2002 GM switched from a Holley sourced PCS Solenoids to a Borg Warner sourced solenoid. The Holley part was far better shielded/insulated from attracting debris, But it was more expensive.
2001 Chevy Camaro L92/4L80E
Re: GM 4T65E magnets [Re: Drew99GT] #4499766
08/27/17 08:10 PM
08/27/17 08:10 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Install one of these:
Re: GM 4T65E magnets [Re: Linctex] #4499810
08/27/17 08:56 PM
08/27/17 08:56 PM
il usa
merconvvv Offline
merconvvv  Offline
il usa
Why in heck did gm not put this ?
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
Re: GM 4T65E magnets [Re: merconvvv] #4499816
08/27/17 09:03 PM
08/27/17 09:03 PM
Colorado Springs
Drew99GT Offline OP
Drew99GT  Offline OP
Colorado Springs
Cause the cheap fittings they'd use would leak all over the place!
Re: GM 4T65E magnets [Re: Drew99GT] #4499996
08/28/17 04:35 AM
08/28/17 04:35 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
As those inline filters load up, your flow in/out of the cooler is diminished. You have to change them regularly.The strongest magnets I have tried came from the magnetron of a microwave oven. You have to pry them off the pan with a screwdriver. As posted, you lose a lot thru the pan. I found out you are still far better off even with the stock magnet over anything you can put on the outside of the pan.I did install two of those improved magnets, the improved one is far superior to the square stock one in strength and surface area.
The "thinking" man's friend.
Re: GM 4T65E magnets [Re: Drew99GT] #4500030
08/28/17 06:14 AM
08/28/17 06:14 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Exactly, they probably decided against having the possibility for another leak point in the system, and something else to service. Oh and the added cost.
God Bless Our Troops
Re: GM 4T65E magnets [Re: Drew99GT] #4500109
08/28/17 08:15 AM
08/28/17 08:15 AM
northern NY
Driz Offline
Driz  Offline
northern NY
I remember Avweb did a test on rare earth magnets on the outside of standard champion filters once. They found that the magnets really did grab up metallic debris and lock it to the inside of the pan behind the magnet. The testers were pretty impressed. Those were only tiny 3/4" neobendyum magnets so a bigass microwave magnet should work well outside the pan. Not as well no doubt as inside naturally but still very helpful..
Re: GM 4T65E magnets [Re: Drew99GT] #4500225
08/28/17 10:13 AM
08/28/17 10:13 AM
il usa
merconvvv Offline
merconvvv  Offline
il usa
Well u cud go to an auto store and ask them to see a similarly constructed pan and right at their counter stick the magnet on the outside and see if it will attract a new nail or something mettalic on the inside of pan with force. smile
Re: GM 4T65E magnets [Re: Drew99GT] #4500232
08/28/17 10:21 AM
08/28/17 10:21 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
06 Escalade 6.0L LQ9 AWD 167k M1 0w40
03 Maxima 3.5L POS 170k ST HM 10w30
05 Malibu Classic 109k Unk
