oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
101 registered members (4WD, anndel, 28oz, 240_Ed, aquariuscsm, 12 invisible), 1,728 guests, and 38 spiders.
Topics295,018
Posts4,926,041
Members66,664
Most Online2,553
Oct 27th, 2018
2017 Ford F53 6.8V10-Kendall GT-1 5W-30 4883 miles #4499662
08/27/17 05:12 PM
08/27/17 05:12 PM
USA
AITG Offline OP
AITG  Offline OP
USA
This is the second oil change on my Motor Home. I am pleased to see that the wear metals have dropped off quickly but I find the fuel dilution surprising. If ever there was an "on-highway use", this is it. Virtually no idling and lots of highway running.
Code:
Miles on lube  1113   4883
Miles on Unit  1113   5996
Fe               34     21
Ch                0      0
Ni                1      0
Al                7      4
Cu               22      7
Pb                0      0
Sn                0      0
Cd                0      0
Ag                0      0
V                 0      0
Si               88     46
Na               10      5
K                 8      3
Ti                0     85
Mo               85     24
Sb                0      0
Mn                4      1
Li                0      0
B               211     79
Mg               15     12
Ca             2068   2161
Ba                3      0
P               757    679
Zn              760    797
Fuel dilution   2.3    2.8
Soot            <.1    <.1
Water           <.1    <.1
Vis, 100C cSt   7.4    8.6
I may try to stretch the next OCI but the fuel dilution concerns me. dnewton3, do you have any comments?
The answer to 80% of BITOG questions: Read the book, follow directions.
Changing oil is not maintenance. Maintenance is the science of inspecting equipment to find and fix things before they break.
Re: 2017 Ford F53 6.8V10-Kendall GT-1 5W-30 4883 miles [Re: AITG] #4499829
08/27/17 08:15 PM
08/27/17 08:15 PM
il usa
merconvvv Offline
merconvvv  Offline
il usa
Whats the recommended oil for your ford?
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
Re: 2017 Ford F53 6.8V10-Kendall GT-1 5W-30 4883 miles [Re: AITG] #4499844
08/27/17 08:34 PM
08/27/17 08:34 PM
USA
AITG Offline OP
AITG  Offline OP
USA
5W-20 or 5W30.
Re: 2017 Ford F53 6.8V10-Kendall GT-1 5W-30 4883 miles [Re: AITG] #4499855
08/27/17 08:44 PM
08/27/17 08:44 PM
il usa
merconvvv Offline
merconvvv  Offline
il usa
Did u have to add makeup oil?
Re: 2017 Ford F53 6.8V10-Kendall GT-1 5W-30 4883 miles [Re: AITG] #4499869
08/27/17 08:56 PM
08/27/17 08:56 PM
Washington, USA
Onug Offline
Onug  Offline
Washington, USA
You're wear metals should continue to drop, but I'm thinking they're already within normal averages.
I've never heard of the V10 having fuel dilution issues...that's very strange. Other than being a very thirsty motor, they're solid monsters. I'd watch it closely...
2016 F-150 3.5L Ecoboost
Current Oil: Castrol Magnatec 5W-30 and Fram Ultra filter
Re: 2017 Ford F53 6.8V10-Kendall GT-1 5W-30 4883 miles [Re: AITG] #4500129
08/28/17 07:48 AM
08/28/17 07:48 AM
il usa
merconvvv Offline
merconvvv  Offline
il usa
Since its under warranty why dont you take it to the dealer and show them the uoa.
Re: 2017 Ford F53 6.8V10-Kendall GT-1 5W-30 4883 miles [Re: AITG] #4500238
08/28/17 09:28 AM
08/28/17 09:28 AM
Planet Earth
2015_PSD Offline
2015_PSD  Offline
Planet Earth
I would definitively take it to the dealer. My 2014 Explorer had a failed secondary throttle body which caused high fuel dilution (something these engines are not known for) in back to back UOAs. The check engine light came on during the next run of oil and I took it in. My point is there could be something happening that is not bad enough to cause a code to the thrown, but should be fixed.
Re: 2017 Ford F53 6.8V10-Kendall GT-1 5W-30 4883 miles [Re: AITG] #4500483
08/28/17 02:47 PM
08/28/17 02:47 PM
il usa
merconvvv Offline
merconvvv  Offline
il usa
Yup once my ford ran really bad n no codes
The egr ports were blockec.
Re: 2017 Ford F53 6.8V10-Kendall GT-1 5W-30 4883 miles [Re: AITG] #4500598
08/28/17 05:31 PM
08/28/17 05:31 PM
Washington, USA
Onug Offline
Onug  Offline
Washington, USA
That reminds me...I lost an injector once and towed up a steep grade running V9 engine. No codes. Maybe you're down one cylinder and just dumping fuel.
Re: 2017 Ford F53 6.8V10-Kendall GT-1 5W-30 4883 miles [Re: AITG] #4500691
08/28/17 07:00 PM
08/28/17 07:00 PM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
The metals are coming down as expected; no surprise and very encouraging.
The fuel is perplexing. That's not at all normal for a non-DI system. I would continue to track it, but perhaps talk to a dealer service center and keep them in the loop. Could be a leaking injector. 1k miles ran 2.3%. 5k miles ran 2.8%. It's probably leaking in but the type service factor you have (full temps for long periods) is keeping it evaporating as much as possible. If these were short trips, the fuel would probably higher? My point is that the intrusion is fairly consistent, because it's not accumulating with your miles; staying about the same. You didn't mention which UOA service this is; not BlkStn for sure.
I would not stretch out the OCI past what the OEM recommends. Stick with their limits during warranty, especially with the fuel concern.
I love that motor; wish they had it still in the SuperDuty non-commercial trucks.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2017 Ford F53 6.8V10-Kendall GT-1 5W-30 4883 miles [Re: AITG] #4500766
08/28/17 08:08 PM
08/28/17 08:08 PM
il usa
merconvvv Offline
merconvvv  Offline
il usa
Wonder if you can scan for fuel trim ?
I have bafx bluetooth with pro torque which gives fuel trim but dont know if that will be helpful in your case.
Re: 2017 Ford F53 6.8V10-Kendall GT-1 5W-30 4883 miles [Re: AITG] #4501608
08/29/17 06:10 PM
08/29/17 06:10 PM
USA
AITG Offline OP
AITG  Offline OP
USA
The lab is Polaris. The engine needed no add oil over 5k and was on the full mark at change.
Re: 2017 Ford F53 6.8V10-Kendall GT-1 5W-30 4883 miles [Re: AITG] #4502005
08/30/17 06:06 AM
08/30/17 06:06 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
If I understand correctly, Polaris uses a fairly accurate fuel assessment process.
However, mistakes do happen. But, you have two subsequent samples 4k miles apart with higher fuel content, so I don't think this is a fluke. You've got a contributor to higher fuel. If this is all it manifests into (stays below 3.5% for every 5k miles) I don't know that it's worth worry. But it is worth noting and tracking, so that if something happens during (or even slightly after) warranty, you've got proof of your concerns.
Re: 2017 Ford F53 6.8V10-Kendall GT-1 5W-30 4883 miles [Re: AITG] #4502718
08/30/17 07:08 PM
08/30/17 07:08 PM
USA
AITG Offline OP
AITG  Offline OP
USA
Fortunately I live in a rural area that has a Ford dealer who actually has a truck shop, works on Motor Homes and has sold me an F-150 and an Escape. I need to get the Escape in next week. I'll chat with the Service Manager and get the ball rolling.
FWIW, it runs great, gets good mileage and has a ton of power. I'm happy I replaced my Duramax camper with this setup.
Re: 2017 Ford F53 6.8V10-Kendall GT-1 5W-30 4883 miles [Re: AITG] #4503046
08/31/17 06:38 AM
08/31/17 06:38 AM
Planet Earth
2015_PSD Offline
2015_PSD  Offline
Planet Earth
Originally Posted By: AITG
FWIW, it runs great, gets good mileage [...].
Not being a doomsayer, but my Explorer did too, at least there was not a radical drop in MPG and it ran fine, but after the repair, the MPG went up slightly and became more consistent. Good that you are going to have it checked.
