New TV Audio Question
by Toros - 12/16/19 01:25 AM
is on car rotor cutting the best method?
by WhyMe - 12/16/19 12:37 AM
Found a Good deal!!!
by GuinnessGuy - 12/15/19 11:28 PM
Serpentine Belt Change
by Propflux01 - 12/15/19 08:59 PM
QS HM 10W-40
by kstanf150 - 12/15/19 08:29 PM
4.5" Angle Grinder
by TheLawnRanger - 12/15/19 07:51 PM
Cooper CS5 Ultra Touring
by Warstud - 12/15/19 07:39 PM
Highway power loss
by HyundaiAbuser - 12/15/19 07:21 PM
General truck tires
by spasm3 - 12/15/19 07:18 PM
Alternative uses for CVT fluid?
by stroo - 12/15/19 05:57 PM
CANbus mileage editor
by cwilliamsws6 - 12/15/19 05:56 PM
Fed ex
by Chris142 - 12/15/19 05:53 PM
New oil treatment from Colgin
by qball16 - 12/15/19 05:36 PM
Discount Tire Direct $80 Flash Sale
by BePrepared - 12/15/19 05:16 PM
Bleed and refill?
by cwilliamsws6 - 12/15/19 04:19 PM
Pies: which ones do you love?
by 53' Stude - 12/15/19 02:32 PM
Honda Ridgeline ZF 9 Speed
by dakota99 - 12/15/19 12:02 PM
bjonga, theman5142, 750IX, Tzam, tjl5709
70138 Registered Users
30 registered members (CB900F2, Astro14, ccs368, AurionX2, 750IX, BlakeB, 3 invisible), 722 guests, and 23 spiders.
Topics298,856
Posts5,142,679
Members70,138
Most Online3,589
Nov 2nd, 2019
Piston Engine Management #4499350 08/27/17 09:35 AM
DeepFriar Offline OP
Superior Air Parts' Bill Ross has written a great booklet on taking care of aircraft recips. It apparently went like hotcakes at Oshkosh and they've decided to make it available to the general public in .pdf form. Great data from a great builder.
http://superiorairparts.com/files/1715/0273/3473/EM101.pdf
Re: Piston Engine Management [Re: DeepFriar] #4499441 08/27/17 11:58 AM
T
Taildragger Offline
T
LIKE!
04 F-150 5.4
73 Big Block, 4sp Corvette
15 Mazda 3
Couple of airplanes
Re: Piston Engine Management [Re: DeepFriar] #4499531 08/27/17 01:58 PM
69GTX Offline
Interesting article. Noticed this quote in there: wink
Oil analysis should never be used as a snapshot in
determining the internal engine health.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Piston Engine Management [Re: DeepFriar] #4499560 08/27/17 02:35 PM
Yah-Tah-Hey Offline
Pay a Spartan grad to do it. banana
Re: Piston Engine Management [Re: DeepFriar] #4499625 08/27/17 04:16 PM
L
LoneRanger Offline
L
I was just reading online the other day about the careful and precise operating techniques required on the early Mooney M20K 231 Continental turbo's with the fixed wastegate or whatever. Sheesh !! Lot to stay on top of and that's just for a single. Apparently Mooney improved it all in 1986 and beyond with the 252's LB engine and an automatic wastegate setup, as well as numerous other improvements both engine and airframe.
'19 Ford F150 2.7 twin turbo GDI V6 .....(Motorcraft 5W30 SN+)
'19 GMC Terrain 1.5 turbo GDI I4...........(GM 0W20 dexos)
'16 Moto Guzzi 1151cc air cooled v-twin (Eni 10W60)
Re: Piston Engine Management [Re: DeepFriar] #4499632 08/27/17 04:25 PM
L
LoneRanger Offline
L
And then there's this, gleaned from the interwebs ...
DEDICATED TO ALL THOSE WHO WORKED ON OR FLEW BEHIND ROUND ENGINES
We gotta get rid of those turbines, they're ruining aviation and our
hearing.
A turbine is too simple minded, it has no mystery. The air travels
through it in a straight line and doesn't pick up any of the pungent
fragrance of engine oil or pilot sweat.
Anybody can start a turbine. You just need to move a switch from "OFF"
to "START" and then remember to move it back to "ON" after a while. My
PC is harder to start.
Cranking a round engine requires skill, finesse and style. You have to
seduce it into starting. It's like waking up a mistress. On
some planes, the pilots aren't even allowed to do it.
Turbines start by whining for a while, then give a ladylike poof and
start whining a little louder.
Round engines give a satisfying rattle-rattle, click-click, BANG, more
rattles, another BANG, a big macho [censored] or two, more clicks, a lot more
smoke and finally a serious low pitched roar. We like that. Remember
Jimmy Stewart nursing that engine to life in "Flight Of The Phoenix "?
It's a GUY thing.
When you start a round engine, your mind is engaged and you can
concentrate on the flight ahead. Starting a turbine is like flicking
on a ceiling fan. Useful, but hardly exciting.
When you have started his round engine successfully your Crew Chief
looks up at you like he'd let you kiss his girl, too!
Turbines don't break or catch fire often enough, which leads to aircrew
boredom, complacency and inattention. A round engine at speed looks
and sounds like it's going to blow any minute. This helps concentrate
the mind!
Turbines don't have enough control levers or gauges to keep a pilot's
attention. There's nothing to fiddle with during long flights.
Turbines smell like a Boy Scout camp full of Coleman Lamps.
Round engines smell like God intended machines to smell.
Re: Piston Engine Management [Re: DeepFriar] #4499655 08/27/17 05:04 PM
LOL Ya gotta love a poet.
Re: Piston Engine Management [Re: DeepFriar] #4500124 08/28/17 07:38 AM
I thought I would add this link to FAA powerplant manuals (and other manuals). They have updated the maintenance manuals over the past few years and I, at least, think they are well done (ooo, looky at all the colors..). At any rate some of this kind of knowledge might be helpful in assisted annuals so we could save some bux. Some of it is basic but I hope it will be helpful.
https://www.faa.gov/regulations_policies/handbooks_manuals/aircraft/
There are two powerplant volumes. Happy Sunday everyone!
Re: Piston Engine Management [Re: DeepFriar] #4500410 08/28/17 12:32 PM
Malo83 Offline
Love those radials.
Re: Piston Engine Management [Re: DeepFriar] #4516151 09/14/17 12:30 PM
F
FastLane Online Content
Online Content
F
Thanks for sharing!
2010 Silverado 4.8 4x4 Mobil 1 5W30 Fram XG10060
2002 Mustang GT 4.6 Mobil 1 5W30 Fram XG2
1966 Cessna 150 Phillips 20W50
2013 Mercury 30hp Mystic 25W40
Re: Piston Engine Management [Re: DeepFriar] #4516191 09/14/17 01:26 PM
Yah-Tah-Hey Offline
Twenty eight cylinders with a right hand twist arrangement, 56 spark plugs,seven double magnetos, high and low tension ignition wiring, that monster had it all. Seeing a cut away 4360 in motion was better than sliced bread and,you know what else. When I was coming up on my P oral and practical, I dreamed that I was ask to set up the timing on one. In reality and looking back many,many years,the FAA examiners around Tulsa gave very easy practicals because they knew students from Spartan didn't know squat about squat, knew the FAA requirements for aviation schools called for a high percentage of students passing the A&P tests, and knew that nobody cared anyway. I really thought I was in king cotton when I decided to enroll at Spartan. Going to be waist deep in airplanes. Only thing that was waist deep was airplane junk. That "train on live equipment" junk had been dead for twenty five years when I got there.No component worked on was complete. There were ALWAYS parts missing. And no one cared. And, surprise of surprise, airplanes weren't the main focus. $$ reigned supreme. And sometime later, Spartan figured out that if they started calling the school a college, even more $$ would roll in. College my hind side. None of the courses at Spartan College of Aeronautics and Technology are accepted by a degree granting institution. Nothing but a black hole money scam. liar
Re: Piston Engine Management [Re: Yah-Tah-Hey] #4518387 09/17/17 07:14 AM
Cujet Offline
Wow, just the opposite of my Embry Riddle experience.
Re: Piston Engine Management [Re: Cujet] #4518583 09/17/17 12:01 PM
Yah-Tah-Hey Offline
You made a good choice Cujet. Forty some years ago it was harder to sort out the good from the not so good to Spartan. And I visited Tulsa twice. The airlines had been using gas turbine powered aircraft for over a decade and Spartan had one beat up vintage gas turbine laying on the floor. There was no gas turbine training period. The highlight of fourteen months there was leaving the classroom one spring morning to watch AAL land their first 747. No comparison between Spartan and Embry Riddle.
Re: Piston Engine Management [Re: Yah-Tah-Hey] #4519296 09/18/17 09:32 AM
Astro14 Online Content
Online Content
Now I understand that Spartan Grad reference that you have made so often...
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Piston Engine Management [Re: Astro14] #4519585 09/18/17 04:09 PM
Yah-Tah-Hey Offline
I'm more than a little anal when it comes to Spartan. It was more than a bitter disappointment. Spartan wasn't really about airplanes at all.We moved through the various phases of the airframe and powerplant curriculum, but there was no cohesiveness about it. It was just one big joke. My wife worked as a nurse to put me through the school, and when I finished, I was so depressed about the experience that I became very depressed and she divorced me. I didn't really blame her. She is a very intelligent person and went on to great accomplishments. Me not so much. Several good psychotherapist got me up and functioning again, but I never have been able to completely forget about that year and a half in Tulsa. Still have a tendency to get a little screwy when I hear airplane. Spartan wasn't about airplanes. sick
