Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
9 minutes 32 seconds ago
revive Nicd battery
by Donald
22 minutes 31 seconds ago
Need help finding an apartment for friend
by RazorsEdge
43 minutes 4 seconds ago
ceratec with redline 5w30?
by 08z06
56 minutes 21 seconds ago
does your COMCAST modem have weak wifi??
by edwardh1
Today at 09:50 PM
I hate stuck thermostats
by jakewells
Today at 09:49 PM
Mag1 75w90
by SavagePatch
Today at 09:32 PM
Old batteries at HD
by bbhero
Today at 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
Today at 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
Today at 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
Today at 08:13 PM
Shure stylus replacement
by aquariuscsm
Today at 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
Today at 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
Today at 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
Today at 06:27 PM
Why buy low mileage tires?
by HowAboutThis
Today at 05:49 PM
Mercury 35-8M0065104 cut open w/ oil change pics
by dlundblad
Today at 05:37 PM
2019 Honda’s miniMOTOs (125cc)
by DuckRyder
Today at 05:18 PM
Car Sales Scammers on Letgo
by ZZman
Today at 04:18 PM
Air shocks or Timbren for trailer towing ?
by Oldtom
Today at 04:10 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
70 registered (AnonOIl, bbhero, AVB, alphadog, 10 invisible), 1289 Guests and 35 Spiders online.
65258 Members
67 Forums
285500 Topics
Page 1 of 3 1 2 3 >
#4499468 - 08/27/17 01:32 PM 2AZ-FE motor oil burn off or oil consumption???
crazy_raccoon Offline
Loc: USA
I have a 2007 Scion tC bought and owned since new of December '06 and I started to notice oil consumption of some kind back in Jan '12. I pretty much stick to 4,500 - 5,000 mile OCI's regardless of which oil I put in it. 9/10 years I've only used full synthetic Mobil 1 and Pennzoil (1st year during break in was the free dealer change). Every time I change out the oil I usually drop out 1.5 - 2.0 qts. when I put 4 qts. of new oil. I have roughly 95K miles on the car right now after owning it for 10 years. I know motors can consume oil as they age and I have already taken it to the dealer twice for TSB oil consumption tests (passed both times).
Just a little run down of my driving habbits, oils used, conditions of the vehicle, etc.;
Vehicle: 2007 Scion tC
Current Mileage: Roughly 95,000 miles
Misc Engine Conditions:
- No leaks
- No issues
- Runs fine
- PCV valve was not clogged (replaced with new OEM PCV two week ago around 94,500 miles)
Oils Used at 4,500 - 5,000 mile OCI:
- Mobil 1 Full Synthetic 5W-20
- Mobil 1 Extended Performance 5W-20
- Mobil 1 High Mileage Full Synthetic 5W-20 (used once back in summer of 2015)
- Pennzoil Platinum 5W-20
- Pennzoil Platinum 0W-20 (only used once for 4,500 miles)
Oil Filters Used:
- FRAM Ultra Synthetic (used only once with Pennzoil Platinum 0W-20)
Driving Habbits:
- Lots of short distance driving in the city with about a 5 minute drive on the high way usually totaling around 20 - 30 miles a day on average.
- Rarely go on road trips that are around 1,500 miles one way. (Only done that about 7 times)
- I do not have a lead foot and the only time I punch it is when I'm at a yield/stop sign intersection trying to get on the main road when cars are flying passed you at 45 - 50 mph.
I know Toyota changed to 5W-20 for CAFE reasons during the time period my car was sold because the previous years the manual stated to use 5W-30 instead. Then again they say the '07+ has minor engine tweaks that I cannot confirm (just word of mouth). Anyways, my issue is I seem to burn roughly 2 - 2.5 qts, of oil when I mainly do city driving. I figure it might have to do with the type of oil I'm using or worried that I actually have some kind of oil consumption the dealer might of missed during the tests. From their results they said I barely burned a 1/4 of a qt. of oil within the 1,200 mile tests which seemed odd.
I was thinking of switching to Amsoil as they are actual synthetic oil compared to the group III Mobil 1 and Pennzoil full synthetics are mostly comprised of. Also, even though my car has used full synthetic oils practically it's whole life, should I change to high mileage oils even though I don't see any types of leaks on the outside of my engine or driveway and is it safe to go back and forth between high mileage oils and regular full synthetic with car being 10 years old?
If anyone has any kind of tips or insights to which might be causing this then by all means post up. I'm still learning about oils so bare with me.
Edited by crazy_raccoon (08/27/17 01:36 PM)
'07 Scion tc
- 98K miles
- Valvoline FS w/ML 0W-20 D1G2
- FRAM Ultra
'07 Honda Accord coupe 4cyl
- 120K miles
- FRAM Ultra
#4499471 - 08/27/17 01:35 PM Re: 2AZ-FE motor oil burn off or oil consumption??? [Re: crazy_raccoon]
slacktide_bitog Online   content
Loc: USA
Try using 5w30 smile
#4499476 - 08/27/17 01:37 PM Re: 2AZ-FE motor oil burn off or oil consumption??? [Re: crazy_raccoon]
Rolla07 Offline
Loc: MTL, CANADA
Is it same 2.4l as was in the camry that year? I know someone who had excessive consumption and the dealer did a test to measure how much loss and had part of engine fixed under warranty. Im unsure of the specifics but id check TSB's and recalls.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
#4499477 - 08/27/17 01:38 PM Re: 2AZ-FE motor oil burn off or oil consumption??? [Re: crazy_raccoon]
Rolla07 Offline
Loc: MTL, CANADA
PP 0w20 & ST 4967
#4499479 - 08/27/17 01:40 PM Re: 2AZ-FE motor oil burn off or oil consumption??? [Re: Rolla07]
Loc: USA
Yes it's the same 2.4L motor the Camry used during that generation and I've already stated that I took my car into the dealership to do a oil consumption test based off the TSB twice and passed both times according to the dealership.
'07 Scion tc
- 98K miles
- FRAM Ultra
- 120K miles
- FRAM Ultra
#4499494 - 08/27/17 01:59 PM Re: 2AZ-FE motor oil burn off or oil consumption??? [Re: crazy_raccoon]
Rolla07 Offline
Loc: MTL, CANADA
No oil will solve this. If it is only using a quart per 4800 miles, you wont get anywhere with them. If your consumption is 2-2.5 quarts per 5k miles, it still doesnt meet their guidelines, however, id bet that if you pushed the subject and pointed them to the data on the web, that you could talk them into doing the proper repair. Have them redo the test and if usage is higher than previous you can tell them its getting worse and you want it dealt with. Go to corporate and push the subject. Thats what id do.
PP 0w20 & ST 4967
#4499497 - 08/27/17 02:06 PM Re: 2AZ-FE motor oil burn off or oil consumption??? [Re: Rolla07]
Loc: USA
As far as I'm aware I'm now out of the extended warranty anyways. It was either less than 150K miles or no more than 10 years old. A lot of people actually pushed this up to the top for a few years now because of this. Some people failed miserably by burning 1 qt. of oil at 600 miles. Those were the ones that had their motor rebuilt or replaced. As per Toyota, burning up to 1 qt. every 1,200 miles is acceptable. Pretty shi**y isn't it?
'07 Scion tc
- 98K miles
- FRAM Ultra
- 120K miles
- FRAM Ultra
#4499498 - 08/27/17 02:09 PM Re: 2AZ-FE motor oil burn off or oil consumption??? [Re: crazy_raccoon]
khittner Offline
Loc: Michigan
If you're only draining out 1-1/2 to 2qts. at an oil change, you need to be checking your level and topping it off way more often. You've done what you can to preserve it by your choice of good oils and filters (I doubt that changing over Amsoil will improve your consumption issue), but your engine is an oil-burner, and you need to keep more oil in it continuously. My '02 Camry has the same engine in it (maybe less problematic than the same 2.4 engine from the '07-? years?) and has gone 263K miles without rings or valve work, but it only gets about 1200 miles out of a quart of oil. Keep a 5-qt. Jug and a funnel in your trunk, use it as needed, and drive it. Otherwise, it's 20 hours of labor to do a ring job on that engine.
Edited by khittner (08/27/17 02:11 PM)
#4499524 - 08/27/17 02:48 PM Re: 2AZ-FE motor oil burn off or oil consumption??? [Re: crazy_raccoon]
bioburner Offline
Loc: Minnesota
You need to keep the oil levels up between changes no matter what. Oil is a primary coolant too.
Wasn't that long ago getting 100k out of a engine was great and oil consumed was ok if quart per 1k. Short tripping doesn't do well with motors as it don't let them expand to help with sealing things up. Keep it full of oil and when it has other issues think about having it rebuilt to go another 100k +
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4499538 - 08/27/17 03:11 PM Re: 2AZ-FE motor oil burn off or oil consumption??? [Re: crazy_raccoon]
blupupher Offline
Loc: Katy, Republic of Texas
The poor engine design (oil hole in piston clogged up, ring issues) is why you have the oil consumption. Tends to start happening around 60,000 miles.
Some have decreased consumption some by going up in weight and/or switching to a high mileage oil.
Just check your oil and add as needed. So long as the oil level is fine, the engine will last 200,000 miles or more.
I hope my xB does not start to consume oil (although I am doing similar to the OP, sticking with a 5000 mile OCI with synthetic), but if it does, I will just add oil as needed.
1994 Honda VT1100C: Peak 15w-40/TG/2500 mile OCI
2002 Ford F150: GTX HM 5w-20/EcoGard Syn/1yr OCI
2012 Scion xB: QSUD 0w-20/CQ Blue/5k OCI
#4499539 - 08/27/17 03:13 PM Re: 2AZ-FE motor oil burn off or oil consumption??? [Re: crazy_raccoon]
car51 Offline
Loc: Southwest PA
My Camry doesn't use a drop and I had a "CAR51 brew" of QSGB SAE 30/DELO XLE 10w30 in for lil' more than 5k and it did just fine.
After this run of leftover VWB/Synpower; I'm sticking with my ole standby: DELO 10w30
2009 Toyota Camry LE
#4499555 - 08/27/17 03:32 PM Re: 2AZ-FE motor oil burn off or oil consumption??? [Re: crazy_raccoon]
danez_yoda Offline
Loc: texas
Yup try any decent cheap 5w30 and check every 1000 miles or so until you get a gauge on consumption.
If you are losing 1.5-2quarts / 4500 miles. check every 2000 miles and add a quart or so.
No need for expensive oils if your burning it like that. Adding fresh oil boost "freshness" of the oil for the second leg of the OCI so the oil doesn't need to be a miricle worker.
At 5K OCI any good oil would do even if you didn't burn a drop.
Edited by danez_yoda (08/27/17 03:41 PM)
#4499566 - 08/27/17 03:45 PM Re: 2AZ-FE motor oil burn off or oil consumption??? [Re: crazy_raccoon]
asiancivicmaniac Offline
Loc: FL
Have a Camry in the family with almost 200,000 miles with the same engine. It uses about 1/2 a quart in a 5000 mile oci. Mostly ran 5w30.
If you know your car is burning oil, why not top it off between oil changes? Letting it get to half of what it normally holds is almost neglect. I would try thicker oil for one change and see if it helps.
2002 Nissan Maxima (beater): Napa Syn 5W-30, Proline 14459
2016 Ford Fiesta ST (fun car): Castrol Edge 0W-40, Bosch D3330
#4499631 - 08/27/17 05:24 PM Re: 2AZ-FE motor oil burn off or oil consumption??? [Re: crazy_raccoon]
philipp10 Offline
Loc: Minnesota
I have the same motor using a quart about every 1200 miles. I could probably push and get Toyota to rebuild the motor. I just add a quart every 1200 and stretch out my OCI's to about 8000. My reasoning is, at 5000 miles, I basically have replaced all the original oil with new oil. No oil is going to fix this.....it's a design issue.
#4499698 - 08/27/17 06:55 PM Re: 2AZ-FE motor oil burn off or oil consumption??? [Re: crazy_raccoon]
Rolla07 Offline
Loc: MTL, CANADA
I agree, completely unacceptable to me in this day and age. I know some will disagree with me on that, but my car doesnt use any oil (not noticeable on the dipstick at least) at 150k miles and will expect the same with a new car too. I think 1/2 quart per mfr OCI is acceptable.
PP 0w20 & ST 4967
Page 1 of 3 1 2 3 >
