Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
In praise of kludges...
by wings&wheels. 01/17/19 02:11 PM
Has Mobil 1 0w40 been discontinued?
by Doublehaul. 01/17/19 01:17 PM
Some questions for the home theater gurus
by grampi. 01/17/19 12:55 PM
Weird side problems after doing repairs
by mclasser. 01/17/19 12:31 PM
Shell Rotella Gasoline Truck.
by JHogan. 01/17/19 12:14 PM
Sears to stay open, for now
by addyguy. 01/17/19 11:35 AM
What Have I Gotten Myself Into?
by Gebo. 01/17/19 11:17 AM
Car stereo FM/ AM Reception Problems
by LazyDog. 01/17/19 11:13 AM
PPHM uoa requests
by aquariuscsm. 01/17/19 11:00 AM
Odd issue in Tacoma 3.5L V6 (2GR-FKS)
by 2019StingrayZ51. 01/17/19 10:58 AM
Alternative to Gillette Fusion razor
by gman2304. 01/17/19 10:55 AM
CAFE standards
by otis24. 01/17/19 10:01 AM
5w30 vs 5w40 Mercedes E220 BLUETEC
by Costas00. 01/17/19 09:56 AM
Moving mobility scooters
by supton. 01/17/19 08:59 AM
Car stumbling in idle
by dan765. 01/17/19 08:58 AM
Fiat 9.55535-GS1 Certification - Ravenol
by RamFan. 01/17/19 08:35 AM
Bigyetti83, Drava, supertrucker, neiltt, Drspel
66960 Registered Users
119 registered members (anndel, Andy636, addyguy, aquariuscsm, 28oz, AandPDan, 13 invisible), 2,179 guests, and 49 spiders.
Topics296,731
Posts4,957,830
Members66,960
Most Online2,577
Jan 14th, 2019
Page 1 of 19 1 2 19
Molybdenum, Cam wear and Hemi tick #4499405
08/27/17 11:03 AM
08/27/17 11:03 AM
sonoma
burla Offline OP
burla  Offline OP
sonoma
So I would like to share to those who might be helped by these facts. Using moly lessons cam wear, using high moly lessons cam wear even more and faster. Here is the science behind that statement page 11 PDF
On another board we tested high moly Redline against other oils, and at about an 80% success rate hemi tick has been eliminated just by switching to Redline 5w30 and 5w20. I'm sure the chart is trinuclear moly, but there also is another graph showing different moly and lowering the coefficient of friction.
So this is my suggestion, discount what about twenty guys have done with their hemi ticks. Start a new test here at bobs with anyone having a ticking condition, and by tick those who have it more sounds like a knock. The science is there, as the temps go up, the friction goes down, perfect for a ticking condition. And as it haves it, this is silencing ticking conditions with a success rate that is stunning. I just hope I can help anyone who bought a 50k dollar vehicle and has to live with this tick, as it turns out, it might be as simple as changing the oil.
My main hope is to have other options as well. Unfortunately even using 0w40 PUP which has over 200ppm moly and may even be TN moly? didn't work as redline has. Read the science, if you want more info pm me, and maybe take a chance and report if it helped your tick. Now, it has taken most guys 500 miles for the ticks to go quiet, nd I am open to suggestions why that has been the fact.
Both Ram forums have cams being wiped out on a weekly basis. The last 6 cam fails the users were using non moly oils. Most guys don't put a lot of thought into oil choice until there is a problem. Match that "coincidence" with the link on moly and cam wear above and decide for yourself. non moly oil creates 10 times the cam wear of over 200ppm moly, 5 times more cam wear then the average 50ppm moly. Take this to the next level guys and gals here at bob's. Test those hemi ticks, you have to change your oil anyway? All findings good or bad should be posted.
Re: Molybdenum, Cam wear and Hemi tick [Re: burla] #4499411
08/27/17 11:14 AM
08/27/17 11:14 AM
sonoma
burla Offline OP
burla  Offline OP
sonoma
This is the kind of thing happening over and over with hemi tick. One lob gets wiped out, thus turning into a 7 thousand dollar dealer fix. Hemi tick leads to wear here, downstream at the cam!! The other forum has been testing now nearly 5 years.
Re: Molybdenum, Cam wear and Hemi tick [Re: burla] #4499413
08/27/17 11:20 AM
08/27/17 11:20 AM
burlington ,ontario, canada
ndfergy Offline
ndfergy  Offline
I believe moly et al FM/AW's are a necessary compensation in the valvetrain for a lack of base oil viscosity. Add a 10W conventional with better EHD lubrication to the list to try.
2015 Toyota Yaris 5spd Manual
Summer: Mobil Super 1000 10w30
Winter: Mobil Super 1000 5w30
OEM Filter
Re: Molybdenum, Cam wear and Hemi tick [Re: burla] #4499423
08/27/17 11:25 AM
08/27/17 11:25 AM
sonoma
burla Offline OP
burla  Offline OP
sonoma
I can agree with that. We have tested many viscosities 20 to 40 weights, but every winter rating was 0 to 5, so it wouldn't hurt to try a 10 wr with a 30 weight. But did you read the cam wear pdf in relation to moly levels versus base oil?
Re: Molybdenum, Cam wear and Hemi tick [Re: burla] #4499425
08/27/17 11:27 AM
08/27/17 11:27 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Are we looking at an additive in oil to fix a design/mfr flaw? If this issue is only on hemis than I think its poor design not oil choice, although it is possible that oil selection can prevent this problem. Id blame the mfr though.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Molybdenum, Cam wear and Hemi tick [Re: burla] #4499429
08/27/17 11:34 AM
08/27/17 11:34 AM
sonoma
burla Offline OP
burla  Offline OP
sonoma
I totally agree bud, it is a weakness in hemi's and is a design flaw. But once a owner has the tick, he/she needs a path forward? Most dealers call this normal, and every hemi owner just about bursts when they hear that!
Re: Molybdenum, Cam wear and Hemi tick [Re: burla] #4499432
08/27/17 11:37 AM
08/27/17 11:37 AM
Fort Lauderdale, FL
DoubleWasp Online content
DoubleWasp  Online Content
Fort Lauderdale, FL
Study seems to indicate that it's moly you want when breaking in a cam and to keep it alive.
Re: Molybdenum, Cam wear and Hemi tick [Re: burla] #4499442
08/27/17 12:00 PM
08/27/17 12:00 PM
Storrs, Connecticut
jeepman3071 Online content
jeepman3071  Online Content
Storrs, Connecticut
Is there any particular year range that is impacted by this?
My dad has a 2013 Grand Cherokee with the 5.7L V8. It is approaching 100k miles with no knocks, ticks, oil burning, etc. I run Pennzoil Platinum 5w30.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (36k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Molybdenum, Cam wear and Hemi tick [Re: burla] #4499443
08/27/17 12:01 PM
08/27/17 12:01 PM
ndfergy Offline
ndfergy  Offline
All that proves, in their findings at least, is that Tri-nuclear is the best. Better than a formulation without any FM/AW, notwithstanding ZDDP, is to be expected, especially if the base oil is < 5w. How does TN moly compare to other FM/AW additives?
OEM Filter
Re: Molybdenum, Cam wear and Hemi tick [Re: burla] #4499450
08/27/17 12:09 PM
08/27/17 12:09 PM
sonoma
burla Offline OP
burla  Offline OP
sonoma
That is a piece of the puzzle, and part of that puzzle happens to include 6 cam fails in a row running non moly oils and 16 outta 20 guys ending their ticks with high moly oil. Really need testers as opposed to opinions, there is nothing to loose and everything to gain. Test additives or oils, whatever. it should be encouraging that most guys who try and solve this with lubrication actually get results, and as it haves it, the science backs it up.
Re: Molybdenum, Cam wear and Hemi tick [Re: burla] #4499462
08/27/17 12:22 PM
08/27/17 12:22 PM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
The only tick I had was a manifold gasket leak which was under warranty.
I have been mostly on a 10w30 diet though with a couple of 5w30 oil changes. I have never run the 5w20 that was on the oil cap or manual that it calls for. So maybe thicker oil rather than moly has something to do with it because the early Hemis when it was thicker oil the tick wasn't as big a issue as it was later with the 5w20 switch.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Molybdenum, Cam wear and Hemi tick [Re: burla] #4499463
08/27/17 12:22 PM
08/27/17 12:22 PM
ndfergy Offline
ndfergy  Offline
Not disagreeing with you and hope you all the best. As you stated, "My main hope is to have other options as well". I gave you one.
OEM Filter
Re: Molybdenum, Cam wear and Hemi tick [Re: burla] #4499481
08/27/17 12:42 PM
08/27/17 12:42 PM
Port Aransas, TX
Stevie Offline
Stevie  Offline
Port Aransas, TX
Those cams aren't hardened properly. Should be a recall. In the 1980s Honda 750 v4 motors had some cams that weren't hardened properly and wore out like that. Honda issued recalled and fixed all of them.
Re: Molybdenum, Cam wear and Hemi tick [Re: burla] #4499499
08/27/17 01:09 PM
08/27/17 01:09 PM
sonoma
burla Offline OP
burla  Offline OP
sonoma
Yes one issue is ticks can be exhaust bolts, our rough number is about 50% of them, and yes they can sound identical. I would look there first as that if that is the nature of the tick fix it or not, wont wipe out your cam.
If the cam wasn't hardened properly it would be multiple lobs, this is a problem with the lifters unique to hemi's. More and more guys are paying attention and taking pics of their cams. In most cases there is horrible pitting on one or two lobs from hemi tick. You don't have to look hard to see the problem, other forums have sticky's with 1000's of posts and examples.
Again, everyone needs to change their oil, it should be encouraging and interesting the results that have been coming in.
Re: Molybdenum, Cam wear and Hemi tick [Re: burla] #4499535
08/27/17 02:05 PM
08/27/17 02:05 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Will a UOA indicate if there is a problem in this engine like high FE content?
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Page 1 of 19 1 2 19
