The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
29 registered members (Agnosto, Bailes1992, carlprop, c502cid, chance, 4 invisible), 634 guests, and 62 spiders.
Topics286,097
Posts4,902,471
Members67,560
Most Online2,967
Mar 10th, 2019
VIRGIN FRAM TG8A CUT OPEN #4499328
08/27/17 10:22 AM
08/27/17 10:22 AM
In the shop
53' Stude Offline OP
In the shop
I nabbed one of the 2 of this # filter at Wal Mart this morning for 50cents smile
Enjoy the pictures folks
Re: VIRGIN FRAM TG8A CUT OPEN [Re: 53' Stude] #4499331
08/27/17 10:23 AM
08/27/17 10:23 AM
In the shop
In the shop
Re: VIRGIN FRAM TG8A CUT OPEN [Re: 53' Stude] #4499343
08/27/17 10:29 AM
08/27/17 10:29 AM
MD
AirgunSavant Offline
MD
Looks a bit crusty. The outside quality on these were brilliant and better than the Ultras I had. But inside i wasn't impressed. Not a bad filter but no bargain either.
Ultras are king. Thanks for the pictures!!
Re: VIRGIN FRAM TG8A CUT OPEN [Re: 53' Stude] #4499347
08/27/17 10:34 AM
08/27/17 10:34 AM
Flaherty, KY
92saturnsl2 Offline
92saturnsl2  Offline
Flaherty, KY
Yep, I fail to see what's so tough about it. Looks like a bargain basement filter-- that alone isn't a bad thing (it certainly doesn't look so bad that I'd worry about it failing), but for the normal price of these, you just don't get your money's worth.
I've used them a handful of times and never had any problems.
1985 F-250HD 7.5L 4x4 135k- Castrol GTX 15w-40 HDEO
04 Odyssey EX 184k Valv. Durablend 5w-30
96 Maxima GLE 255k Castrol Edge EP 5w-20
07 Chrysler Pacifica Limited 4.0L 134k Chevron Supreme 5w-20
Re: VIRGIN FRAM TG8A CUT OPEN [Re: 92saturnsl2] #4499351
08/27/17 10:41 AM
08/27/17 10:41 AM
In the shop
In the shop
For 50cents and the age of the filter I ain't complaining
Re: VIRGIN FRAM TG8A CUT OPEN [Re: 53' Stude] #4499382
08/27/17 11:27 AM
08/27/17 11:27 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
It's not very old per the date code.
Re: VIRGIN FRAM TG8A CUT OPEN [Re: 53' Stude] #4499444
08/27/17 01:04 PM
08/27/17 01:04 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
The 99% @ 20 micron efficiency is tough to find at the regular price of a TG.
Good looks or not, that filter is still kicking the competition.
Re: VIRGIN FRAM TG8A CUT OPEN [Re: 53' Stude] #4499453
08/27/17 01:11 PM
08/27/17 01:11 PM
In the shop
In the shop
smile
Re: VIRGIN FRAM TG8A CUT OPEN [Re: 53' Stude] #4499458
08/27/17 01:15 PM
08/27/17 01:15 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
Thank you for the time and effort to show the filters. I think the filter hits all the marks well except one. The excess glue or whatever stained the filter shows where the baseplate seals to the ADBV. Two or three of the inlet holes, shown in the bottom of the fifth picture down, have hole edges which are at or near the sealing surface edges. Too close IMO, and it's been seen before. I think it could leak. The only real defect seems to me, except the strange deposits on this particular sample.
It looks like the nub centering method has the ADBV off to one side a bit on this one. More sealing space on one side than the other, by a lot.
Re: VIRGIN FRAM TG8A CUT OPEN [Re: goodtimes] #4499478
08/27/17 01:40 PM
08/27/17 01:40 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
^^^ The 3rd and 5th photos show the ADBV seals outside the hole circumference. Even if it's not perfectly centered, looks like still enough area to seal. It looks pretty centered in photo #3.
Re: VIRGIN FRAM TG8A CUT OPEN [Re: 53' Stude] #4499514
08/27/17 02:33 PM
08/27/17 02:33 PM
In the shop
In the shop
Yeah Zee0Six is correct. 3rd pic: what you see is exactly what I saw when I pulled baseplate from filter can. Looks good to me smile
Re: VIRGIN FRAM TG8A CUT OPEN [Re: 53' Stude] #4499526
08/27/17 02:49 PM
08/27/17 02:49 PM
TN
MinamiKotaro Offline
TN
Looks waaaaaaay better than the last PH8A I cut open. The last few Frams I've seen on here finally seem to have addressed the lack of media issue.
1967 VW Beetle: Delo 15w40/ST4386
2004 Saturn Ion: Magnatec 5w30/DW5436
2014 Polaris Ranger 570: Delo 5-40/Wix 51356
Re: VIRGIN FRAM TG8A CUT OPEN [Re: ZeeOSix] #4499635
08/27/17 05:28 PM
08/27/17 05:28 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
I was looking at the inside seal, #5, where the ADBV seals the center tube. It's pretty extreme on this one I would say, the off center. The holes on one side almost go past the seal. That would leak oil from the inlet to the outlet. Probably still enough rubber to seal, but who knows, it isn't centered well is what I am saying. That is something the nub center system, especially with fiber nubs is a little different on than an ADBV that centers perfectly around a collar.
Re: VIRGIN FRAM TG8A CUT OPEN [Re: 53' Stude] #4499680
08/27/17 06:34 PM
08/27/17 06:34 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
Another good looking Fram.
CX5 Touring 2.5L :-)
Re: VIRGIN FRAM TG8A CUT OPEN [Re: 53' Stude] #4499683
08/27/17 06:36 PM
08/27/17 06:36 PM
Washington, USA
Onug Offline
Onug  Offline
Washington, USA
Wow... they start ugly and end ugly. But they seem to last.
2016 F-150 3.5L Ecoboost
Current Oil: Castrol Magnatec 5W-30 and Fram Ultra filter
