No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
Practice CLS material
by RDY4WAR. 12/17/18 01:52 PM
2005 Chevy Silverado 5.3 vortex
by MSpeer. 12/17/18 12:01 PM
Comma X-Tech 5w30 oil, any good?
by BobGoblin. 12/17/18 11:40 AM
Modern Engine's Grenading?
by Nickdfresh. 12/17/18 11:15 AM
Magnetic Smartphone Holders
by willbur. 12/17/18 11:06 AM
1991 Caprice 5.0l hard starting in the AM
by WyrTwister. 12/17/18 10:55 AM
Question about new Peak OEM coolants
by PD001. 12/17/18 10:21 AM
Rev X
by Big_3_Only. 12/17/18 10:04 AM
Modern engines put less contaminants in the oil?
by WyrTwister. 12/17/18 08:12 AM
Gear whine
by odotb. 12/17/18 07:38 AM
Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
harvey_01, Gordon_Walter, MikeSheng, stantaur, Brandon9797
66703 Registered Users
84 registered members (bdcardinal, BeerCan, aquariuscsm, 4WD, Anduril, 16 invisible), 2,200 guests, and 42 spiders.
Topics295,189
Posts4,929,470
Members66,703
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
Repairing dent in hollow core door #4499214
08/27/17 07:12 AM
08/27/17 07:12 AM
Ceciltucky Maryland
Oldtom Offline OP
Oldtom  Offline OP
Ceciltucky Maryland
Good Morning - One of my tenants put a six inch diameter X 3/4 inch deep " dent " in a brand new hollow core door. I want to fix the dent and bill the tenant for it. I am looking for a quick and cheap repair, since the next crew of knuckle dragging neanderthals will probably punch a hole into the same spot. No point in getting fancy in a rental. The dent only shows on one side of the door panel. The door is a plain, flat panel, which simplifies things.
I was thinking of experimenting with fast setting drywall mud. Not sure if it will stick.
What do you folks think? Thanks in advance for any advice.
Re: Repairing dent in hollow core door [Re: Oldtom] #4499218
08/27/17 07:20 AM
08/27/17 07:20 AM
Chicago, IL
Brybo86 Offline
Brybo86  Offline
Chicago, IL
2part wood filler
08 Honda Accord EX-L 2.4L M1 EP 0w20 145k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 193k
95 Yamaha Jog
Re: Repairing dent in hollow core door [Re: Oldtom] #4499219
08/27/17 07:20 AM
08/27/17 07:20 AM
Chicago, IL
Brybo86 Offline
Brybo86  Offline
Chicago, IL
2part wood filler
01 Kymco People 50
95 Yamaha Jog
Re: Repairing dent in hollow core door [Re: Oldtom] #4499221
08/27/17 07:29 AM
08/27/17 07:29 AM
ME
eljefino Offline
eljefino  Offline
ME
I think the mud will fall out... it's a door... it moves (slams).
How much of a hassle is it to get over to this dwelling and futz with it?
Re: Repairing dent in hollow core door [Re: Oldtom] #4499222
08/27/17 07:30 AM
08/27/17 07:30 AM
out there
spasm3 Offline
spasm3  Offline
out there
Assuming this is a painted door, i'd wire brush the area off and use bondo. I'd check and see if there are any salvage stores in your area. Habitat restores usually have lots of doors like this , and they are cheap. If you can get a cheap one, its faster than repair.
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: Repairing dent in hollow core door [Re: Oldtom] #4499224
08/27/17 07:30 AM
08/27/17 07:30 AM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Get a piece of wall panel,cut and cover the whole door. Use panel adhesive to attach to the door and if you want it fancy, cut the panel undersize and get some molding to frame it. Time effective.
Spasm has the right idea with recycle. I know my local box store has a bargin bin full of scratch and dent doors for very cheap too. Most under $20
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Repairing dent in hollow core door [Re: Oldtom] #4499226
08/27/17 07:34 AM
08/27/17 07:34 AM
Texas & Global
4WD Online confused
4WD  Online Confused
Texas & Global
What exactly is the surface to be repaired (the skin) ?
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: Repairing dent in hollow core door [Re: Oldtom] #4499289
08/27/17 08:45 AM
08/27/17 08:45 AM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
You didn't tell us if the door is painted or wood faced. Assuming painted, as Brybo86 said, use 2 part wood filler. Two part wood filler is part epoxy, so it's pretty strong. If it's wood faced, just replace the door.
You can do two things to make it stick. One is to increase the surface area, but drilling a bunch of small holes in the dent, and roughing up the surface it adheres to. The second is drive a few screws in, leaving the screw head above the surface of the dent and below the surface of the door. Use a ruler or level straightedge to check this. The screw heads will give the filler something to grab on to.
One more thing. Another landlord strategy is to leave damage until the tenant moves out, and take it out of their deposit. However if it's a good tenant that pays on time and rarely damages things, you might want to fix it soon in order to keep them longer. It's a judgement call.
Various musings: http://hangfire.net
Re: Repairing dent in hollow core door [Re: Oldtom] #4499299
08/27/17 08:50 AM
08/27/17 08:50 AM
MA
Wolf359 Online content
Wolf359  Online Content
MA
It's about the same amount of work to mount a solid door than a hollow core door. Ultimately you didn't save any money. I just put in solid doors instead of bothering with hollow cores. Solid doors are about $100 at Home Depot and the hollow cores are about $35.
Re: Repairing dent in hollow core door [Re: Oldtom] #4499321
08/27/17 09:16 AM
08/27/17 09:16 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
As someone said drill some small holes in it and rough it up then use this an let it dry, finish with an orbital sander and 120 grit. It will last forever.
http://www.homedepot.com/p/Durham-s-Rock-Hard-DU-4-4-lb-Water-Putty-DU-4/202535298
Re: Repairing dent in hollow core door [Re: Oldtom] #4499368
08/27/17 10:04 AM
08/27/17 10:04 AM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
He said it's a 6" dent so I'll assume it's metal. Get a thin piece of sheet metal to cover dent and adhere with whatever you have on hand that will work. And apply bondo and blend....then paint.
Re: Repairing dent in hollow core door [Re: Oldtom] #4499377
08/27/17 10:13 AM
08/27/17 10:13 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
The renter did it. Well that's easy I had rentals for over 20 years. You let them pay for a new door or you take it out of their damage deposit.
2004 Corolla 126884
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Repairing dent in hollow core door [Re: Oldtom] #4499401
08/27/17 11:00 AM
08/27/17 11:00 AM
South Central PA
Delta Online happy
Delta  Online Happy
South Central PA
Quick and cheap repair? Replace the door; a plain hollow-core door is $30... You'll have more than that invested in time to "repair" the old one.
'17 VW GTI 2.0T - 6MT - 11K - Edge 0w40
'15 Camry SE - 2.5 - 22K - PP 0w20
'99 S10 - 2.2 5MT - 157K - PP 10w30
Re: Repairing dent in hollow core door [Re: bioburner] #4499618
08/27/17 04:09 PM
08/27/17 04:09 PM
NC
BigD1 Offline
BigD1  Offline
NC
We use to cover them like that, but we would tack the panel down, and then take a router, and go around it to trim it. Then stain it, or paint it. In a big four bedroom apartment, some times all the doors would be damaged including the closet doors, so it was cheap and fast to fix the doors this way, and they looked good too.
1992 Toyota Pickup--Harvest King Premium 10W-30--Fram PH3614
Re: Repairing dent in hollow core door [Re: Oldtom] #4499643
08/27/17 04:36 PM
08/27/17 04:36 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
Drill a small hole in the middle the spray some expanded ng foam in there to see if it will pop out. You might need to brace the other side so it doesnt bulge.
Page 1 of 3 1 2 3
