Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
540 RAT
by elpcmaster. 03/21/19 09:18 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
2001 CRV no restart when hot
by Kurtatron. 03/21/19 07:27 AM
Amazing human feats - free-diving...
by Shannow. 03/21/19 04:59 AM
How long to warm-up an engine?
by OilUzer. 03/21/19 04:58 AM
Disappearance and appearance
by bbhero. 03/21/19 04:38 AM
Big Changes for WIX 51334 - Pics
by tony1679. 03/21/19 04:26 AM
Supertech Synthetic Data Sheets
by The Critic. 03/21/19 04:25 AM
Forester XT filter recommandation
by jbutch. 03/21/19 04:23 AM
Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
AlanGonzales, Jrealstreeter, DarkFrontier, Zuraxus, Burks21
67574 Registered Users
83 registered members (Astro_Guy, arowbat, addyguy, 928, a2gtinut, 3311, 9 invisible), 1,896 guests, and 63 spiders.
Topics286,183
Posts4,903,727
Members67,574
Most Online2,967
Mar 10th, 2019
Running 0w40 or 5w40 #4499197
08/27/17 07:48 AM
08/27/17 07:48 AM
MA.
Camprunner Offline OP
MA.
Just wondering who here is running either 0w40 or 5w40 when there car or truck recommends either a 20 weight or 30 weight oil?
I have used M1 0w40 in my 2012 Nissan Pathfinder V6 and noticed no difference in fuel millage and my idle seemed to improve for the full OCI.
Re: Running 0w40 or 5w40 [Re: Camprunner] #4499201
08/27/17 07:59 AM
08/27/17 07:59 AM
USA
ArcticDriver Offline
USA
Why would viscosity effect idle?
Multiple Diesel and Gasoline vehicles
Re: Running 0w40 or 5w40 [Re: ArcticDriver] #4499207
08/27/17 08:08 AM
08/27/17 08:08 AM
MA.
MA.
I am as confused about that as you are?? I just can't explain it.
Re: Running 0w40 or 5w40 [Re: Camprunner] #4499243
08/27/17 08:48 AM
08/27/17 08:48 AM
USA
USA
What do you mean with "Improved Idle"?
Is this a difference in idle RPM at the tach? Or do you mean it just "feels" smoother, quieter, etc..?
I have found that a different motor oil can result in different engine "feel" just like a fresh oil change using the same brand oil.
Re: Running 0w40 or 5w40 [Re: Camprunner] #4499291
08/27/17 09:46 AM
08/27/17 09:46 AM
MA.
MA.
Since day one my 4.0 in my Nissan has always had a significant amount of vibration that you can feel threw the drivers seat and through the steering wheel. The vibration seems to go away with adding more rpm at idle and it is not felt when driving. When I run a 0w40 the idle seems to increase just enough so the vibration can't be felt and I also get less engine noise so it seems.
Re: Running 0w40 or 5w40 [Re: Camprunner] #4499325
08/27/17 10:20 AM
08/27/17 10:20 AM
North Central Illinois
EyesofThunder Offline
Is it a variable valve timing engine? The change in viscosity could change the cam positioning some. Lower overlap at idle smooths idle.
Re: Running 0w40 or 5w40 [Re: Camprunner] #4499346
08/27/17 10:31 AM
08/27/17 10:31 AM
Flaherty, KY
92saturnsl2 Offline
92saturnsl2  Offline
Flaherty, KY
I'm currently using Pennzoil Ultra Platinum 5w-40 in a '04 Odyssey with J35A4 engine that specs 5w-20. I did it this summer in an effort to combat oil consumption (with 5w-20, it'd use about 2.5 quarts in a 6-7k OCI); it's too early to tell yet if it's helped in that regard.
Since purchasing it at 130k miles (has about 175k now), I'd only used 0w/5w-20 and once or twice used Mobil1 0w-30 AFE. I really can't tell the difference between any of them, the engine runs the same and had always used about the same amount of oil regardless of what was used. The 5w-40 this time is a curiousity thing, to see if it might help. I feel like it may not rev as fast, perhaps not as responsive using the thicker oil, but the difference is minimal. This engine has VTEC and the thicker oil has made no difference with the VTEC solenoid that activates the second cam profile.
1985 F-250HD 7.5L 4x4 135k- Castrol GTX 15w-40 HDEO
04 Odyssey EX 184k Valv. Durablend 5w-30
96 Maxima GLE 255k Castrol Edge EP 5w-20
07 Chrysler Pacifica Limited 4.0L 134k Chevron Supreme 5w-20
Re: Running 0w40 or 5w40 [Re: Camprunner] #4499406
08/27/17 12:06 PM
08/27/17 12:06 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Ive run 0w40 on my car that specs 5w30. No issues or change in consumption. Ive also run 0w20 and 5w20 with no noticeable difference. Once back in day someone put 5w50 in and I did notice a significant decrease in gas mileage.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Running 0w40 or 5w40 [Re: Camprunner] #4499445
08/27/17 01:05 PM
08/27/17 01:05 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
I've used M1 0w40 (old formulation) in my Infiniti that calls 5w30. No scientific data but the engine sounded very smooth.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Running 0w40 or 5w40 [Re: Camprunner] #4499585
08/27/17 04:22 PM
08/27/17 04:22 PM
I've often wondered are the variable valve timing, VVTi, VTEC, etc THAT sensitive to oil viscosity?
Some say that xW20 oils are only spec'd in the US/North America and not overseas, IF that is true (I can't figure out how to find out), do the OEM's change the variable valve timing orifices?
Re: Running 0w40 or 5w40 [Re: Camprunner] #4499652
08/27/17 05:54 PM
08/27/17 05:54 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
0W-40 is typically a thinner base oil with more viscosity index improvers to achieve KV100, hence why they usually have higher NOACK figures versus the same oil in 5W-40. Typically a better quality base-stock, though, to achieve 0W pour point and cold crank.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: Castrol 0W-40
Re: Running 0w40 or 5w40 [Re: Camprunner] #4499745
08/27/17 07:47 PM
08/27/17 07:47 PM
WI.
dblshock Offline
dblshock  Offline
WI.
Civic at 25k now.. 12k on 0/40, better upgrade early to avoid excessive wear...upgraded that the fuel and UHP tires, real nice.
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: Running 0w40 or 5w40 [Re: Camprunner] #4499823
08/27/17 09:10 PM
08/27/17 09:10 PM
NC
Vladiator Offline
Vladiator  Offline
NC
I am using Pennzoil 0w40 in 2009 Scion xB that specs 0w20. Engine is nice and smooth, definitely smoother than 0w20. Fuel economy is the same on both viscosities.
Re: Running 0w40 or 5w40 [Re: Camprunner] #4499835
08/27/17 09:23 PM
08/27/17 09:23 PM
Texas
4WD Offline
4WD  Offline
Texas
Mobil 1-FM 5w40 in ecoboost & Delvac 15w40 in 5.3L ... both tested quieter than 5w30 ... don't notice any other difference
Re: Running 0w40 or 5w40 [Re: 4WD] #4499843
08/27/17 09:33 PM
08/27/17 09:33 PM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
"FM"?
