Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
78 registered members (Alfred_B, 2010Civic, Ama0787, ABCarr, 69GTX, 2015_PSD, 8 invisible), 1,503 guests, and 61 spiders.
Topics286,215
Posts4,904,411
Members67,579
Most Online2,967
Mar 10th, 2019
Adjusting push mower RPM #4499048
08/26/17 11:27 PM
08/26/17 11:27 PM
FL
CharlieJ Offline OP
CharlieJ  Offline OP
FL
Has anyone increased their push/self propelled mower's engine RPM? From reading online, it seems like 21 inch blade mowers are limited to around 3000 RPM for "safety" reasons. Some say that raising the RPM to 3600 is a more ideal running speed for mowers to properly mulch grass clippings.
Has anyone adjusted the RPM of their small engine mowers? I am considering trying it myself.
'07 Mazda3 2.3 Mobil 1 HM 5w-30
'84 Mazda Rx-7 Valvoline Maxlife 10w-30
Re: Adjusting push mower RPM [Re: CharlieJ] #4499052
08/26/17 11:42 PM
08/26/17 11:42 PM
NorCal
Seventh Offline
Seventh  Offline
NorCal
I've done it on mine. It's a briggs 158cc I believe. It has the plastic primer bulb type carb with no adjustments whatsoever.
The throttle butterfly is attached to a little lever/arm thing on top of the carb. The lever has a spring that goes to the tank mounting bracket.
I pulled the end of the spring through the bracket, one additional "loop" around. Essentially making it pull more on the butterfly.
Picked the revs up nicely, although I have no idea what the actual rpm is... runs way smoother
Re: Adjusting push mower RPM [Re: CharlieJ] #4499055
08/26/17 11:50 PM
08/26/17 11:50 PM
Grande Prairie, Alberta,Canada
gpguy Offline
gpguy  Offline
Ive done it too on my Husqvarna with a Honda GC160 motor.
I thought the mower seemed to lack umphh. Handheld tach showed only 2800 rpm. Max for motor is 3600 but I only adjusted it up to 3200. It made a huge difference in mulching and ability to cut taller grass.
1999 F250LD 4X4 XLT SCab 5.4L (Mobil Delvac Elite 222 0w30)
2011 F150 4X2 XL RC 3.7L (Castrol Syntec 5w20 ).
Re: Adjusting push mower RPM [Re: CharlieJ] #4499058
08/26/17 11:51 PM
08/26/17 11:51 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I do it all the time. I don't have a tachometer, so I adjust the RPM to what I think sounds good.
Re: Adjusting push mower RPM [Re: CharlieJ] #4499115
08/27/17 02:42 AM
08/27/17 02:42 AM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
I have the RPMs on my Toro Recycler w/ Tecumseh engine maxed out. Since the wheels are belt driven, this also speeds up how quickly the mower moves.
But now I am left wondering if there is an ideal speed that maximizes mulching capability along with propel speed.
Re: Adjusting push mower RPM [Re: CharlieJ] #4499200
08/27/17 07:49 AM
08/27/17 07:49 AM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
most ope engines are optimized for 3600 rpm.
but a blade rpm limit is something i would not exceed.
a failure would not be pretty.
Re: Adjusting push mower RPM [Re: CharlieJ] #4499233
08/27/17 08:40 AM
08/27/17 08:40 AM
northwest pa
justintendo Offline
justintendo  Offline
northwest pa
my husky has a honda gcv 190..cant remember for sure what the stock rpm was but it was well under 3k. it lives at 3250 now and handles the grass much better. there is a small uptick in fuel consumption..
2013 escape 2.0 awd mobil 1 10w30ep
2008 fusion 2.3 mtx redline 0w20
1996 f150 4.9 2wd mtx mobil 1 10w30hm
1999 kaw zrx 1100 redline 10w40
many husqvarnas
Re: Adjusting push mower RPM [Re: CharlieJ] #4499258
08/27/17 09:11 AM
08/27/17 09:11 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
I like adjusting for 3600RPM. I don't always use that much RPM, but at times it's helpful.
However, my current Honda 190 will not adjust up that high. It's limited to around 3000 at max adjustment.
Re: Adjusting push mower RPM [Re: CharlieJ] #4499319
08/27/17 10:12 AM
08/27/17 10:12 AM
Flaherty, KY
92saturnsl2 Offline
92saturnsl2  Offline
Flaherty, KY
I have a 2010-ish Troy-Bilt non-self propelled push mower w/ a Honda GCV160 engine. My governor works off a spring attached to a metal arm- if you raise the spring pressure it raises RPM and vice versa. I took a dremel and made indents in the metal arm, so I could connect the spring to different points on it, ultimately changing the spring pressure that whatever it's connected to sees. Works great, I have about 5 positions all the way from near idle, to full-out screaming (probably dangerous) for when I'm cutting through knee high grass / brush. I've run it at the highest setting a few times when I'm in a real hurry, and it's a beast. Engine doesn't seem to mind what settings it's at. I had some governor surging when I lived in Colorado (high elevation), but that cleared up once I brought it back down to sea level, which is where I bought it. Not sure if that had to do with me monkeying with it, but it's fine now.
1985 F-250HD 7.5L 4x4 135k- Castrol GTX 15w-40 HDEO
04 Odyssey EX 184k Valv. Durablend 5w-30
96 Maxima GLE 255k Castrol Edge EP 5w-20
07 Chrysler Pacifica Limited 4.0L 134k Chevron Supreme 5w-20
Re: Adjusting push mower RPM [Re: CharlieJ] #4499357
08/27/17 10:53 AM
08/27/17 10:53 AM
North Carolina
SirWired Offline
SirWired  Offline
North Carolina
As far as safety goes, at the factory-set RPM, the mower is tested to see if the blade will break through or ricochet out of the deck if it were to fracture, in case anybody was wondering. While the engine has a specific top speed available, it's not for no reason that the manufacturer set the governor at a particular speed in the factory.
Re: Adjusting push mower RPM [Re: CharlieJ] #4500224
08/28/17 10:13 AM
08/28/17 10:13 AM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
By regulation the max safe RPM is 3200. IIRC
Thick oil is better grin2
Re: Adjusting push mower RPM [Re: CharlieJ] #4500436
08/28/17 02:05 PM
08/28/17 02:05 PM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
I usually set them at 3000-3200 RPM. That seems to be the best range for power while still maintaining fuel efficiency. I've seen some Briggs set at 2000-2100 RPM from the factory, basically idling.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (38k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Adjusting push mower RPM [Re: SirWired] #4502114
08/30/17 09:07 AM
08/30/17 09:07 AM
Kennett Square, PA
artbuc Offline
artbuc  Offline
Kennett Square, PA
On my Honda HRS 216 with GVC 160 engine, manual warns that "blade could fracture and come apart" if operated at higher than maximum governed speed of 3000 + 0 / - 150. Mine came from factory dead on 3000. There is a second hole in governor arm which operates at 3350. I wonder how much safety factor Honda builds in? I am guessing the chances of my blade self-destructing at 3350 are pretty minimal.
Re: Adjusting push mower RPM [Re: CharlieJ] #4502991
08/31/17 06:06 AM
08/31/17 06:06 AM
FL
CharlieJ Offline OP
CharlieJ  Offline OP
FL
I bought one of those small engine tachometers off of ebay for about $10. I have a B&S 550E engine which I bent the metal governing tab to increase the RPM of the mower to 3600 RPM. I have not had a chance to cut grass with it yet, I hope it does a better job.
Anyone know how high these engines will rev? I don't want to take the chance of over revving the engine, but I know it will go 4200 RPM.
Re: Adjusting push mower RPM [Re: CharlieJ] #4503265
08/31/17 11:38 AM
08/31/17 11:38 AM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
Small engines like B&S aren't designed for high rpm, so I'd be surprised
if they will rev past 5000. If they do, it won't be for long.
Some of these small engines have plastic camshafts and/or gears, and they can't
take the higher revs.
Stick with the 3600 rpm, which is what they are rated at and designed to
hopefully last.
As it is, since most are limited to even less than the 3600, it explains why
they last nearly forever.
My 2
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
