1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
30 registered members (billt460, citationxeleven, anndel, c502cid, Ag76, 3 invisible), 952 guests, and 31 spiders.
Topics296,903
Posts4,961,304
Members66,997
Most Online2,688
Jan 19th, 2019
LM Mos2, perhaps, lowered my Idle speed. #4498856
08/26/17 04:39 PM
08/26/17 04:39 PM
california
wrcsixeight Offline OP
california
I had driven ~1000 miles to the eclipse's path of totality in two days. I checked my oil level when cold out in the middle of nowhere and found it right in the middle, having started at about 3/4. It should have been reading a little higher than actual, as The Vehicle was slightly nose down at the time, so it had burned some on the drive.
I thought I had a spare quart of M1 0w-40 but all I had was a can of LM MOS2 that was half MOS2 and half TDT 5w-40 left over from a previous oil change.
While I knew I was in no danger of it running too low, Warm and fuzzies required I add it. Next day when hot, I noticed the engine was not idling quite as smoothly as normal, as normally I can't notice it.
Then I looked at my tach, and while the factory service manual says it should Idle at 750 rpm, for the last 7 years since I added the tach it has idled when hot in gear foot on the brake unmoving, at 525 to 550 rpm.
It now Idles at 500 rpm hot in gear foot on the brake unmoving. As hot as it gets, I have 22 to 24 PSI oil pressure at this 500 rpm with M1-0w-40. 65mph at 1900 rpm is 50 to 54PSI. Max cold is 68PSI, max PSI hot is 62 at 2400+ rpm.
It is a 1989 throttle body injected 318 controlled by the engine computer.
I am not saying the MOS2 lowered my Idle speed rpms nor claiming any magical properties of the product, just that the hot idle speed rpms in gear have lowered by 25 rpm after adding it. I am aware there could be other affecting variables, it just seems to have some rather direct correlation.
I expected the engine computer hold whatever Idle speed it decided to, and remain constant.
I know M1 0w-40 requires no additives and in general I am not an Additive type of person. I Noticed nothing when I bought and added half a can of the Mos2 3 years ago and added it to M1 0w-30 AFE, and forgot I had half of it left.
Average Fuel economy over the 2500 miles was pretty good for my Vehicle considering all the considerable elevation changes, before adding the Mos2 and Afterwards as well, Exceeding my expectations by ~0.5 MPGs for the ~2300 miles I acquired before the last fill up.
LA 318 Roller Cam
Pennzoil Platinum 10w-30 SN Plus
Fram ultra XG8A
Fram Ultra XG16 on remote transmission filter mount
Re: LM Mos2, perhaps, lowered my Idle speed. [Re: wrcsixeight] #4499007
08/26/17 09:00 PM
08/26/17 09:00 PM
SD
zrxkawboy Offline
zrxkawboy  Offline
SD
I don't see how it could have affected the idle speed. I believe it was caused by something else.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: LM Mos2, perhaps, lowered my Idle speed. [Re: wrcsixeight] #4499914
08/27/17 10:08 PM
08/27/17 10:08 PM
Michigan
Oil_Flunky Offline
Oil_Flunky  Offline
Michigan
From my experience; older, maybe worn engines like mos2.
Oil, you need it. Oil snobbery, you don't need it.
Re: LM Mos2, perhaps, lowered my Idle speed. [Re: wrcsixeight] #4500140
08/28/17 07:58 AM
08/28/17 07:58 AM
Texas
wag123 Offline
wag123  Offline
Texas
When was the last time you cleaned your throttle body/blade? The idle speed is not electronically regulated on your engine and a carboned/gunked-up throttle body/blade will cause an idle speed reduction.
Re: LM Mos2, perhaps, lowered my Idle speed. [Re: wrcsixeight] #4500270
08/28/17 10:10 AM
08/28/17 10:10 AM
california
california
I looked down the TB's throat about 10 days ago before road trip. No obvious varnish.
Perhaps My Idle speed actuator motor is retracting a bit further. The thing has always been noisy.
LA 318 Roller Cam
Fram ultra XG8A
Re: LM Mos2, perhaps, lowered my Idle speed. [Re: zrxkawboy] #4500954
08/29/17 03:54 AM
08/29/17 03:54 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Me either. I'd call it a coincidence, and there's some other issue, either with an electrical part, something mechanical, or a vacuum leak.
God Bless Our Troops
Re: LM Mos2, perhaps, lowered my Idle speed. [Re: wrcsixeight] #4500960
08/29/17 04:30 AM
08/29/17 04:30 AM
NC
Vladiator Offline
Vladiator  Offline
NC
Did you just glance at it or open the blade to look behind it? Usually the varnish hides behind that blade. At least that is how it's been in my vehicles. Spakling clean on the intake side, varnish and oil on the manifold side of the blade.
