Anyone signing up for the Space Force
by Shannow
06/20/18 03:58 AM
Pennzoil Platinum at Walmart
by TheLawnRanger
06/19/18 11:21 PM
Mopar OEM and Fram Ultra Oil filters, '18 Jeep JL
by IndyFan
06/19/18 10:45 PM
What’s the odds..
by Eric Smith
06/19/18 09:51 PM
Who can relate?
by Reddy45
06/19/18 09:43 PM
No more oil changes
by goodtimes
06/19/18 09:19 PM
Separating toddlers from their parents?
by fdcg27
06/19/18 08:50 PM
gm 8.6 truetrac
by Spitter
06/19/18 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
06/19/18 08:34 PM
Rockauto 5% off
by Spitter
06/19/18 08:32 PM
fumoto oil valve
by Santo
06/19/18 08:19 PM
Grand solar minimum...
by ridgerunner
06/19/18 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
06/19/18 07:49 PM
The things you find cleaning Garage 30+ btls slob
by digger327
06/19/18 07:20 PM
Castrol GTX Magantec 0w20 - 6 pack $21.99 - Amazon
by 04SE
06/19/18 07:07 PM
Havoline Pro DS 5w20 $3.15/quart - Amazon
by 04SE
06/19/18 07:06 PM
Needing New Dipstick
by Geauxtiger
06/19/18 05:11 PM
'98 Mercedes E300TD Rotella T5 10W-30 5k miles
by KenO
06/19/18 04:35 PM
Premium guard oil filters
by Jaha24k
06/19/18 04:09 PM
76 super motor oil- synthetic blend 5w-30
by Jaha24k
06/19/18 04:07 PM
Shassis, Santo, aligoodn, memyself, MichiganKid419
65274 Registered Users
22 registered (iontrap, FordCapriDriver, bbhero, Char Baby, Astro14, 69Torino, 5 invisible), 792 Guests and 26 Spiders online.
65274 Members
67 Forums
285630 Topics
Page 1 of 2 1 2 >
#4498521 - 08/26/17 09:55 AM Vacuum pumps on petrol engines.
shDK Offline
Loc: Denmark
Hi all.
6 month ago we bought a 3 year old Toyota with a 1.6 valvematic engine. The engine runs great and is a really nice engine. But one thing bothered me..a lot. The engine had a faint but really noticeable knocking sound from the cylinderhead/valvetrain. It goes away above 1000 rpm's.
So.. I went to the dealer. They send out a mechanic he listened. And apparently it is perfectly normal. All Toyota valvematic engines do it. And the reason. A cam driven vacuum pump. He explained that due to the function of the valvematic system. The engine had no traditional throttlebody. And therefore no vacuum in the intake to support the brake system. Therefore they mounted a vacuum pump. Just like if it was a diesel. Or turbo engine.
It really does give the engine a bit rough idle sound. And not something I like to listen to.
But how normal is this to newer engine design. Any other engine makers who makes there engines like this? Or is it just Toyota?
#4498541 - 08/26/17 10:21 AM Re: Vacuum pumps on petrol engines. [Re: shDK]
skyactiv Offline
Loc: The Midwest
You need to learn to live with it. Some newer engine designs are simply louder and it's for fuel economy and/or emissions. Mazdas Skyactiv engines are really loud when started on a cold day for the first minute.
Me: 13' VW GTI 3 door 6 speed manual
#4498601 - 08/26/17 11:21 AM Re: Vacuum pumps on petrol engines. [Re: shDK]
Linctex Offline
Loc: Waco, TX
Originally Posted By: shDK
....t due to the function of the valvematic system, The engine had no traditional throttlebody. And therefore no vacuum in the intake to support the brake system.
Only other one I am aware of is BMW
#4498607 - 08/26/17 11:26 AM Re: Vacuum pumps on petrol engines. [Re: shDK]
SHOZ Offline
Loc: Illinois
On the Hyundai Genesis Coupe with the turbo and automatic transmission there is a vacuum pump for when the engine is in boost I guess.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#4498645 - 08/26/17 12:10 PM Re: Vacuum pumps on petrol engines. [Re: shDK]
E150GT Offline
Loc: San Antonio, TX
I am pretty sure the Mazda Skyactiv engines do have a vacuum pump. They have a throttle body but they also have weird valve timing that lowers vacuum. So I have read anyway.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 250k 5w30
2016 Mazda6 Touring 6MT - 56k 10w30
#4498666 - 08/26/17 12:39 PM Re: Vacuum pumps on petrol engines. [Re: shDK]
Colt45ws Offline
Loc: Central Washington
Will probably become more common. The only other way I know of to do a brake booster is to use hydraulics aka hydroboost, but that runs off the power steering pump which is pretty much dead these days now in favor of electric power steering.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
#4498677 - 08/26/17 12:52 PM Re: Vacuum pumps on petrol engines. [Re: shDK]
E365 Offline
Loc: USA
My Ford EcoBoost 1.0 has a mechanical vacuum pump.
As does my 2008 MINI Cooper S. Actually, those have been known to seize. That's how I got a great deal on a used MINI. The exhaust cam mounted vacuum pump seized, which seized the exhaust cam, which sheared off the exhaust cam sprocket bolt and bent a couple exhaust valves.
I plan on replacing them preventatively ever 75,000 miles or so.
Whatever’s on sale...
#4498681 - 08/26/17 12:58 PM Re: Vacuum pumps on petrol engines. [Re: shDK]
HerrStig Offline
Loc: Boston, MA
When the first level of save us from smog rules hit many car makers backed idle timing to zero advance or even AFTER TDC. This reduced idle vacuum to a very low level and VOLVO, for example, grafted a vacuum pump to the top of the valve cover. It was discovered by many that the pump could be removed and there would still be enough vacuum for brakes and HVAC switching. Cars have gone through many levelws of "anti smog" since and there's still smog in LA. Now they blame grills, lawn mowers, and motor bikes.
#4498709 - 08/26/17 01:46 PM Re: Vacuum pumps on petrol engines. [Re: Colt45ws]
CR94 Offline
Loc: Western S.C. since 1996
Originally Posted By: Colt45ws
Will probably become more common. ...
Yes, because manifold vacuum indicates wasted energy. Diesels, CVTs, Atkinson cycle engines, and the "valvematic" intake are all examples of ways to reduce the waste. Nothing says a mechanically or electrically driven vacuum pump has to be noisy, though.
Edited by CR94 (08/26/17 01:47 PM)
2011 Toyota Prius now at 88K
#4498728 - 08/26/17 02:18 PM Re: Vacuum pumps on petrol engines. [Re: CR94]
shDK Offline
Loc: Denmark
Well..to be fair the pump is noisy due til the pumping action. It is the air moving you can hear. Not a mechanical noise. If you place your ear on the air filter box. It is also clear to hear the air pumping.
#4498738 - 08/26/17 02:30 PM Re: Vacuum pumps on petrol engines. [Re: shDK]
CR94 Offline
They could've used a more expensive, quieter type of pump. Or could've muffled the existing one better, but that too would add cost, plus add weight, and take space. Fair trade-off or not? Automotive design involves numerous compromises.
#4498757 - 08/26/17 03:01 PM Re: Vacuum pumps on petrol engines. [Re: shDK]
Shaman Offline
Loc: Frankfort, Kentucky
Saab 9-3 with the 2.8 have them.
#4498920 - 08/26/17 07:44 PM Re: Vacuum pumps on petrol engines. [Re: shDK]
Silk Offline
Loc: New Zealand
Back in the '50's and '60's when Fords had vacuum wipers - full throttle and the wipers stopped. The English Zephyr had a vacuum pump combined with the fuel pump, so there was vacuum for the wipers even under low manifold vacuum. There is never annything new.
1987 BMW R65 - Penrite V Twin 20/50
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
#4499094 - 08/27/17 01:06 AM Re: Vacuum pumps on petrol engines. [Re: HerrStig]
Falcon_LS Offline
Loc: Kuwait
Add cows to that list. smile
GC 0W40 or Motul X-Cess 5W40:
99 Explorer EB: XG8A
00 Pajero: MD352626
01 Grand Marquis: XG2
03 Expedition SSV: XG2
05 Envoy: 51522XP
07 SRX: XG8765
#4499100 - 08/27/17 01:23 AM Re: Vacuum pumps on petrol engines. [Re: shDK]
Ducked Offline
Loc: Taiwan
How about a return to non-servo brakes? I used to like them. Better brake feel, and made engine-off coasting on long descents much easier.
Page 1 of 2 1 2 >
