Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
104 registered members (2015_PSD, Anduril, Astro14, Avelectro, b1amgm47, ABCarr, 12 invisible), 2,186 guests, and 28 spiders.
Topics287,749
Posts4,933,778
Members67,850
Most Online2,967
Mar 10th, 2019
AC compressor issue (video) #4498520
08/26/17 09:55 AM
08/26/17 09:55 AM
NJ
civhatch90 Offline OP
NJ
Car is a 2007 Mazdaspeed 3, 100% stock , 180k miles.
Today coming from work all of the sudden the car starts blowing hot air and I check the temperature gauge to realize the needle is 3/4 of the way up, very close to the H. I turn the heating on max and the car begins to cool down.
Pull over and when the AC is on, this is what the compressor is doing: https://www.youtube.com/watch?v=d_QuhECEhyM
I should note I have not seen the radiator fan come on, either when the AC was or on off and the car was fully warmed up and the temperature gauge was higher than normal. Is this related to the AC issue?
A week later: Found a clutch/bearing replacement in Amazon and installed it this past weekend. The clutch appears to no longer "slip" but it does turn on and off as it pleases. Here is a video: https://www.youtube.com/watch?v=wMlhTfqfHkQ AC was on all the time while recording the video.
Before this all happened the car was blowing ice cold air, so I assume it is not an issue with lack of refrigerant in the system.
Any feedback is appreciated before my last resort which would be to take it to a shop.
Thanks!
Re: AC compressor issue (video) [Re: civhatch90] #4498531
08/26/17 10:09 AM
08/26/17 10:09 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Did you measure the pressure on hi and lo side?
These measurement will determine if the compressor is good or bad.
  • 2017 Toyota Sienna
Re: AC compressor issue (video) [Re: civhatch90] #4498542
08/26/17 10:22 AM
08/26/17 10:22 AM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
First you should address the fact the cooling fans have not come on as you don't want to over heat the engine. Most modern automobiles will shut off the air conditioning should the engine go over a pre determined temperature. This is probably why the AC shut down in the first place.
Re: AC compressor issue (video) [Re: civhatch90] #4498543
08/26/17 10:22 AM
08/26/17 10:22 AM
USA
mk378 Offline
mk378  Offline
USA
Does the A/C operate properly when the car is moving? When the car is moving, air is forced through the condenser and radiator, so it does not matter that the fan does not work.
The compressor appears to be tripping off due to high pressure, because the condenser fan does not work. With no airflow the high side pressure rises very high and the controls will disengage the compressor to protect it.
The condenser fan must come on when the car is sitting still with the A/C on. It may not stay on constantly, but it should be on at least part of the time.
Re: AC compressor issue (video) [Re: mk378] #4498574
08/26/17 10:54 AM
08/26/17 10:54 AM
NJ
NJ
Unfortunately I do not. I know working on an AC issue without the gauges is difficult but due to the AC working at highway speeds I am assuming the compressor works and the system is properly charged.
I think you two may have hit the nail on the head. I went for a 20 minute ride after reading your feedback and as the car was moving the AC kept blowing cold air. I stopped twice on the drive and the fan was never on. Your feedback will shift my focus from the AC system to the cooling fan. Worth noting the car only has one radiator fan and it did not overheat during the drive, temp gauge stayed where it usually did before this all started.
Off I go to read up on diagnosing the cooling fan.
Re: AC compressor issue (video) [Re: civhatch90] #4498583
08/26/17 11:02 AM
08/26/17 11:02 AM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Check the fan connections, fuse or breaker and wiring first. Look for the easy stuff 1st. I had a similar issue with a Taurus with fan not operating and I had done a rad repair in February and forgot to reconnect the fan and since most of my driving is freeway or open road was not an issue till I did some in town driving after 3 hour freeway drive on a hot July day. whistle
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: AC compressor issue (video) [Re: civhatch90] #4498703
08/26/17 01:31 PM
08/26/17 01:31 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
You have to fix the cooling fan asap. It will destroy the compressor if you dont.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: AC compressor issue (video) [Re: JMJNet] #4498746
08/26/17 02:37 PM
08/26/17 02:37 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
A bad compressor with show higher than normal low side pressures; am I correct ?
