Diesel lube in Petrol Engine
by Ducked
06/20/18 07:46 PM
New key programming cost
by 92saturnsl2
06/20/18 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
06/20/18 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
06/20/18 07:08 PM
Wheel says 50 mph max
by pda1122
06/20/18 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
06/20/18 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
06/20/18 06:36 PM
Old Engine SOUND
by MasterSolenoid
06/20/18 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
06/20/18 04:54 PM
go green or Dexcool?
by umungus1122
06/20/18 04:50 PM
Latest info on ExxonMobil synthetic base stocks
by Gokhan
06/20/18 04:49 PM
Pennzoil Platinum 5w30 - $3.21/qt Amazon
by SnowmanCO
06/20/18 04:37 PM
What Is Dexos Oil?
by mx5miata
06/20/18 04:27 PM
Hail damage means newer vehicle time!
by ZZman
06/20/18 03:39 PM
Trouble with Grease Gun
by tc1446
06/20/18 02:30 PM
Toyota brand conventional (TGMO)
by Jaha24k
06/20/18 01:45 PM
Any synthetic oil rebates currently or soon?
by 07Piloteer
06/20/18 01:32 PM
2018 Hyundai elantra motor oil
by kapama
06/20/18 01:00 PM
SN Plus on shelves
by 03s
06/20/18 12:23 PM
Group 90 Battery - 45 vs 60aH rating
by The Critic
06/20/18 12:19 PM
Ilia, nmac9, Theraven, battleman13, Shassis
65278 Registered Users
112 registered (2009Edge, 01rangerxl, 10WSmuckers, 2002 Maxima SE, 2K2AcuraTL, 04sierrashortbed, 12 invisible), 1267 Guests and 61 Spiders online.
65278 Members
67 Forums
285669 Topics
#4498478 - 08/26/17 09:13 AM mobil 1 Racing 4T
mobilaltima Offline
Loc: Golden Meadow, LA
I have a few quarts of Mobil 1 Racing 4T 10W40, would it be ok to use in a Honda GX390 generator at 50 hr intervals? My only concern is its API SH.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
#4498483 - 08/26/17 09:19 AM Re: mobil 1 Racing 4T [Re: mobilaltima]
FordCapriDriver Offline
Loc: Balearic Islands , Spain
M1 Racing 4T is SH because it contains a fairly high concentration of ZDDP, around the 1300ppm mark i believe, but it's a very good oil, here in Europe we have Racing 4T 15W-50, no 10W-40, a friend of mine has run it in his TVR 3000M Race car ( Ford V6 with Triple Weber carbs ) and it is perfect and squeaky clean inside.
I think it should be perfectly fine.
1975 Ford Capri II Ghia 3000 V6, - Valvoline VR1 20W-50
1988 Ford Escort MkIV 1.6 Xr3i Cabrio, - Shell Rimula R4X 15W-40 HDEO.
#4498489 - 08/26/17 09:24 AM Re: mobil 1 Racing 4T [Re: mobilaltima]
mobilaltima Offline
Thanks. Ive always noticed what Cujet said about running 15W50 in these engines, I'm not doubting what he said at all, I'm just hesistant to run a 50 weight in it. Im sure a 40 will do fine, I usually run a 15W40 in it.
#4498504 - 08/26/17 09:34 AM Re: mobil 1 Racing 4T [Re: mobilaltima]
CT8 Offline
Loc: Idaho
Originally Posted By: mobilaltima
Thanks. Ive always noticed what Cujet said about running 15W50 in these engines, I'm not doubting what he said at all, I'm just hesistant to run a m0 weight in it. Im sure a 40 will do fine, I usually run a 15W40 in it.
I use What ever Xw-40 HDEO I have left over from My wife's Ford diesel trucks oil change. 15W-50 works great in ope engines . I would run 15w-50 if I were to make a special trip buy an ope oil. Starting temps considered.
#4498525 - 08/26/17 10:02 AM Re: mobil 1 Racing 4T [Re: mobilaltima]
mobilaltima Offline
I was worried about 15W50 being too thick as its not a pressurized system, almost certain it has a slinger.
#4498596 - 08/26/17 11:14 AM Re: mobil 1 Racing 4T [Re: mobilaltima]
Linctex Offline
Loc: Waco, TX
Ive always noticed what Cujet said about running 15W-50 in these engines, I'm not doubting what he said at all, I'm just hesitant to run a 50 weight in it.
I don't know what he says, but I've never had any issues with a -40 or -50 oil in any OPE engines.
#4498664 - 08/26/17 12:37 PM Re: mobil 1 Racing 4T [Re: mobilaltima]
Cujet Offline
Loc: Jupiter, Florida
This subject comes up once in a while. Interestingly, again and again, certain oils provide excellent protection in air cooled engines. Among them are the Mobil 1 oils: Mx4t 10W-40 and the associated 20W-50 V-Twin, 5W-40 TDT and the robust 15W-50.
All of those oils have a stout ability to provide excellent lubrication under very high heat conditions without excessive shearing. High HTHS.
The 10W-40 is an ideal choice for that engine in hot climates.
#4498787 - 08/26/17 03:45 PM Re: mobil 1 Racing 4T [Re: mobilaltima]
FZ1 Offline
Loc: Texas
If that is motorcycle oil it doesn't have as much friction modifiers as automobile oil.
