Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
28 registered members (Atesz792, bmod305, Brad_C, Chesterr, carlprop, alcyon, 2 invisible), 691 guests, and 62 spiders.
Topics286,442
Posts4,908,225
Members67,622
Most Online2,967
Mar 10th, 2019
Recommend me a PAG oil #4498429
08/26/17 08:00 AM
08/26/17 08:00 AM
Indiana
dlundblad Offline OP
Indiana
Something locally available at parts stores. Thanks.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Recommend me a PAG oil [Re: dlundblad] #4498474
08/26/17 09:10 AM
08/26/17 09:10 AM
NorCal
Seventh Offline
Seventh  Offline
NorCal
Just get whatever they have.
They aren't going to have a selection of different pag oils to choose from.
I doubt anyone can make a case for one pag oil being "better" than the next one anyway.
Re: Recommend me a PAG oil [Re: dlundblad] #4498494
08/26/17 09:27 AM
08/26/17 09:27 AM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
You need the right PAG oil for the application?
PAG 46/100/150
PAO, Ester
Many choices
Gotta use what the application calls for
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: Recommend me a PAG oil [Re: dlundblad] #4498497
08/26/17 09:30 AM
08/26/17 09:30 AM
USA
mk378 Offline
mk378  Offline
USA
Look for "double end capped". This is a slightly different molecule that is more resistant to water and breakdown. Also it should be sold in a metal can not a plastic bottle. PAG absorbs water easily.
Re: Recommend me a PAG oil [Re: dlundblad] #4498499
08/26/17 09:31 AM
08/26/17 09:31 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
What kind of compressor? It matters.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Recommend me a PAG oil [Re: dlundblad] #4498518
08/26/17 09:52 AM
08/26/17 09:52 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
You MUST use the correct compressor oil. Research and see what the specified oil is and use only that. Ask me how I know....lol.
Re: Recommend me a PAG oil [Re: dlundblad] #4498578
08/26/17 10:55 AM
08/26/17 10:55 AM
Indiana
Indiana
It's the DENSO 4710400.
Rock Auto AC Compressors
For the Jeep in my signature.
Re: Recommend me a PAG oil [Re: dlundblad] #4498592
08/26/17 11:11 AM
08/26/17 11:11 AM
Southeastern USA
FowVay Offline
FowVay  Offline
Southeastern USA
ND8 OEM oil is a PAG46 product. The PAG is for R-134 systems and the 46 is the viscosity. There is 46, 100, and 150. The compressor design will dictate the viscosity. You need the 46 in your specific compressor.
Re: Recommend me a PAG oil [Re: FowVay] #4499159
08/27/17 06:40 AM
08/27/17 06:40 AM
Indiana
Indiana
How'd you know it needs the 46? Not questioning your answer, just curious for myself.
Re: Recommend me a PAG oil [Re: dlundblad] #4500339
08/28/17 12:17 PM
08/28/17 12:17 PM
California
nthach Offline
nthach  Offline
California
If you got a Carquest or AAP nearby, see if they can get ND-Oil 8 or 9 from Worldpac. It will be cheaper than getting the OEM-labeled version. Otherwise any PAG 46 oil without sealers will work, just be aware it's a one-time shot once you open it as the stuff absorbs water.
There's a sticker on the compressor that states the design specs and oil type. The AC info label on the core support or hood might also state the oil type. Denso uses an ISO46 PAG oil for most of their compressors, electric ones use ND-Oil 11 POE oil and there's ND-Oil 9 for scroll compressors.
