Any Synthetic 10W30 Users ?
PNW
Curious if any readers are using synthetic 10W30 in newer vehicles with lower mileage (i.e. not using 10W30 because of high mileage / older engine) ?
For those that do use synthetic 10W30 - your reasons ?
I've been running primarily 10w-30 syn oils for the past 12+ years. We live in a Mountain climate where winter temps routinely dip well below zero. Never had issues with cold starts. Running a lot of PP / Napa syn. / Oci 5-6K. /. This regimen sustained 2 so called problem engines. 1. '02 dodge stratus 2.7 V-6 ran it to 170K sold to my mechanic for his daughter. 2. '07 Saturn Aura 3.6 V-6 sold at 140k running great. I like The viscosity stability & lower NOAK.
I have some Castrol Edge 10W30 in my oil stash, probably use it for my next oil change. I doubt I will notice a difference over the M1 5W30 synthetic in there now. But in theory the 10W30 should have lower volatility and more shear stability, which I like.
When it comes to the cold start winter W rating, get as much as you need, but no more than you need.
Is your 10w30 Edge an A3/B4?
I like our Edge HM 10w40 for this reason. It's only available at parts stores, but buying it on sale brings it to normal-ish prices.
The Oz Castrol Edge 10W30 is A5/B5 so HTHS < 3.5 cP
But our Castrol Edge 5W30 is A3/B4 with HTHS > 3.5 cP
So for me the 10W30 is the thin oil and the 5W30 is the thick oil.
It was talked about on BITOG (Here)
I sometimes use Valvoline Synthetic w/Maxlife Technology because it has very low Noack (6%), and 10W-xx is perfectly fine in South Fl.
I run alot of 10w30. It is usually always what I put in my 06 Dodge which is spec'd for 5w20. I have also ran it in the Ford 4.6's and the Lincoln I traded actually got better fuel mileage on it over 5w20.
The Ford 5.4 has 10w40 in it now. I had 7 qts of Castrol Start up laying around and I heard it made them quieter.
Not much difference. The gas mileage went from 15.4 to 15 over 5w20.
I've been using Kendall GT-1 Full Syn 10w-30 in my 2014 Hyundai Santa Fe 3.3 V-6 and my 2016 Kia Cadenza (same engine). Kia and Hyundai both state in the owner's manual that 10w-30 is one of the recommended weights. I just prefer 10w or 5w.
Yes - spec'd in our 2007 V6 300 - went from normal Mobil 1 to 10w30 HM - but grabbed enough (clearance) QS Defy at year end to make 3 changes with that and XG16 ...
I use it in the summer because it was on sale and had a rebate. I switch back over to my on sale with rebate 5w-30 in the fall.
I have used 10w30 in all my vehicles past and present and could not physically tell any difference vs 5w30 which is what is oem recommended. I used it fir the same reasons listed by others and I got it on clearance. No temp issues in socal
Last year some Valvoline 10w30 was on sale, so I bought a couple years worth of Synpower for my Sonata.
Runs excellent, burns zero oil now, also good for this GDI pig, and Hyundai approved grade.
I notice a lot of users in warm climate OR only use it in the Summer ? I am due for a oil change and like all that a 10W30 synthetic provides for a GDI engine . Worse case my Winter temps can get down to the teens (F.) for a few days each year but the norm is high 20's to low 30's F. most nights . I know a 10W synthetic should be good down to 0F. but wonder if splitting the M1 10W30 with 2 qrts. of M1 5W20 would provide any noticeable benefit for cold starts - again at the cold start temps I listed above ?
I use Pennzoil Platinum 10W30 in my 300ZX that has 113,000 miles. That's the "thinnest" oil Nissan recommends for my car.
Oh yeah,a 10W will be just fine. I've used 20W50 dino in -7F and it started and ran impeccably.
