Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
76 registered members (Alfred_B, andyd, 2010Civic, Ama0787, ABCarr, BHopkins, 8 invisible), 1,494 guests, and 61 spiders.
Topics286,215
Posts4,904,411
Members67,579
Most Online2,967
Mar 10th, 2019
Redline 0w20 OCI for 08 Honda Pilot #4498151
08/25/17 08:58 PM
08/25/17 08:58 PM
FL, USA
shurguywutt Offline OP
FL, USA
I usually follow the MM on my dash for OCI. It usually works out to 7-8k. I just put some 0w20 Redline in my 08 Pilot and was wondering what I should/could push the OCI to? Maybe Ill get it analyzed at 8k.
Last edited by Bill in Utah; 08/25/17 10:02 PM. Reason: Changed subject for easier search
2008 Pilot 2WD J35Z1 153k
Shell 5w-30
Re: Redline 0w20 OCI for 08 Honda Pilot [Re: shurguywutt] #4498161
08/25/17 09:04 PM
08/25/17 09:04 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
When you do the analysis at 8K, you'll find you can go longer.
Re: Redline 0w20 OCI for 08 Honda Pilot [Re: shurguywutt] #4498163
08/25/17 09:05 PM
08/25/17 09:05 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
You're in Florida - I think you'll be able to go 15K without any effort.
Re: Redline 0w20 OCI for 08 Honda Pilot [Re: Linctex] #4498172
08/25/17 09:10 PM
08/25/17 09:10 PM
FL, USA
FL, USA
Maybe Ill analyze at 10k
Shell 5w-30
Re: Redline 0w20 OCI for 08 Honda Pilot [Re: shurguywutt] #4498205
08/25/17 09:48 PM
08/25/17 09:48 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
10k sounds like a good plan. Keep in mind that TBN use is not linear....
Thick vs Thin test: 15k / 43k miles complete
Re: Redline 0w20 OCI for 08 Honda Pilot [Re: shurguywutt] #4498238
08/25/17 10:56 PM
08/25/17 10:56 PM
Spring,Texas
Bud_One Offline
Bud_One  Offline
Spring,Texas
Is this a VCM 3.5 ?
If it is, 5K mile OCI is what I would run regardless of brand.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3213814/New_Honda_Pilot:_3.5_VCM:_What
16 Civic-QSUD 0W-20, XG7317
14 Civic-Idemitsu Zepro 0W-20, XG7317
05 Chevy 2500HD-QSUD 10W-30, XG3675
97 Accord Wagon-Havoline ProDS 10W-30, TG7317
Re: Redline 0w20 OCI for 08 Honda Pilot [Re: shurguywutt] #4498296
08/26/17 01:12 AM
08/26/17 01:12 AM
Texas
FZ1 Offline
FZ1  Offline
Texas
Save the uoa money and just change it out at the mm.
Re: Redline 0w20 OCI for 08 Honda Pilot [Re: shurguywutt] #4498492
08/26/17 09:25 AM
08/26/17 09:25 AM
New York Queens
Ram02 Offline
Ram02  Offline
New York Queens
Also save money and use Valvoline 0w20 synpower
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: Redline 0w20 OCI for 08 Honda Pilot [Re: shurguywutt] #4498496
08/26/17 09:28 AM
08/26/17 09:28 AM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Overkill if you don't extend drains
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Redline 0w20 OCI for 08 Honda Pilot [Re: Bud_One] #4498567
08/26/17 10:49 AM
08/26/17 10:49 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Following that logic....... just use the very cheapest brand of oil available anywhere that meets minimum spec, and change it at 5K.
I personally think redline is good for far, far longer. Changing it early is a waste of $$$$$
Re: Redline 0w20 OCI for 08 Honda Pilot [Re: shurguywutt] #4498657
08/26/17 12:28 PM
08/26/17 12:28 PM
Canada
subzerospeed Offline
Canada
That oil will still be healthy to run after 10k in your engine.
15' fiST
Pennzoil Platinum 5w30
Michelin Pilot Sport All Season 3+
Escort IX
Only braking for Ka
Re: Redline 0w20 OCI for 08 Honda Pilot [Re: shurguywutt] #4498690
08/26/17 01:09 PM
08/26/17 01:09 PM
FL, USA
FL, USA
The main reason that I chose this oil was it uses high quality base oils and the noack value (9%) is lower than any other 0w20 I have seen specs on. Yes it is an expensive oil, we all know this. I could have used a cheap oil but I wanted to see how this top tier oil would perform. Many would argue that Redline after 8k of use is probably still better than most of the stuff you buy brand new off the shelf. It should be too as it cost more than twice as much as your "full synthetics" over the counter.
My engine does consume a little oil. I want to see how this oil lasts compared to its usual diet of 5w30 M1 Synthetic which I was having to add about a qt every 8k (not a strange phenomenon for the Honda J35 motor).
Shell 5w-30
Re: Redline 0w20 OCI for 08 Honda Pilot [Re: shurguywutt] #4498696
08/26/17 01:15 PM
08/26/17 01:15 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
There is a member here that has 62,000 miles on AmsOil (with by-pass filtration). But he does UOA's on schedule and tops off when he changes filter media.
Redline can prolly do the same in the same circumstances. But you have to approach this with facts and data. Just guessing will not do it. We can all spout off a good guess ...
Make a plan and see it through. You may get way more than 12K out of that oil, but you'll need data to do it safely smile
