Fullers Vintage Ale anyone?
by Lolvoguy. 12/18/18 11:23 PM
Got an alignment
by michaelluscher. 12/18/18 11:18 PM
Castrol Edge 0W-40; 9,762 mi; 2016 Ford Fiesta ST
by asiancivicmaniac. 12/18/18 10:50 PM
Windows Defender Error Code
by ZeeOSix. 12/18/18 10:20 PM
UOA Motul 300V, 5w40, 2013 BMW S1000RR
by Sportbiker. 12/18/18 09:53 PM
Under valve cover pics
by barkingspider. 12/18/18 09:47 PM
Kubota Super UDT2? Anything better?
by Jmoney7269. 12/18/18 09:23 PM
Car Door Fabric Glue
by cb450sc. 12/18/18 08:57 PM
Canadian Uber
by StevieC. 12/18/18 08:13 PM
71141 / Lifeguard 5
by chefwong. 12/18/18 07:52 PM
Tested Positive for Flu
by john_pifer. 12/18/18 07:37 PM
Cooper RTX?
by 01rangerxl. 12/18/18 07:25 PM
IPhone SE or flip phone?
by 53' Stude. 12/18/18 05:49 PM
1993 K1500 hard cold start
by BrianF. 12/18/18 05:43 PM
Put my wife's dog down yesterday
by Stelth. 12/18/18 05:04 PM
ATF Filter oem vs aftermarket any differences?
by 97prizm. 12/18/18 03:50 PM
Depth-Fiberglass Filter Media.
by Al. 12/18/18 03:43 PM
Sportbiker, trollhattan, MuhThugga, wxo, dbierman
66718 Registered Users
22 registered members (Bjornviken, Bailes1992, DoubleWasp, Edmundo, bbhero, bozo66), 826 guests, and 38 spiders.
Topics295,248
Posts4,930,863
Members66,718
Most Online2,553
Oct 27th, 2018
Mix 30ND with 30wt HD for rear diff? #4498117
08/25/17 07:16 PM
08/25/17 07:16 PM
NY
Clarkbug Offline OP
Clarkbug  Offline OP
NY
Question for the gurus here..
I have an EzGo golf cart that specs 30wt Non-detergent oil for the rear transaxle. I drained and dumped in a quart of NAPA 30ND. But it looks like I'm 8 or so Oz short of a fill. Van I use some 30HD oil I have for my other OPE? Or should I go get another quart of the Non-detergent?
Re: Mix 30ND with 30wt HD for rear diff? [Re: Clarkbug] #4498166
08/25/17 08:06 PM
08/25/17 08:06 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
It's a such a Low-RPM and Low-HP application, you can use just about any oil & you won't wear it out.
Re: Mix 30ND with 30wt HD for rear diff? [Re: Clarkbug] #4498345
08/26/17 04:42 AM
08/26/17 04:42 AM
NY
Clarkbug Offline OP
Clarkbug  Offline OP
NY
Thats sort of what I figured, but I try to use whats spec'd when I can. I figure a little detergent oil in the rear end wont hurt it, especially since the changer interval is 5 years, and it probably went much longer than that previously.
Re: Mix 30ND with 30wt HD for rear diff? [Re: Clarkbug] #4498379
08/26/17 05:54 AM
08/26/17 05:54 AM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
I'm curious why they spec'd a non-detergent oil in the first place. Detergents probably won't be very useful but I don't think they will do any harm. Plus, detergent oils have anti-wear additives that aren't found in non-detergent oil. If it was mine I'd call the factory and ask why they spec non-detergent. Maybe they have a good reason.
Re: Mix 30ND with 30wt HD for rear diff? [Re: Clarkbug] #4498383
08/26/17 05:59 AM
08/26/17 05:59 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Your diff is probably better off than 99.9% of all other golf cart's out there. smile
03 Jeep WJ 4.0 202k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Mix 30ND with 30wt HD for rear diff? [Re: Clarkbug] #4498434
08/26/17 07:09 AM
08/26/17 07:09 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
You're spot on.
The 'concern' that detergent oils dislodge old sludge/dirt resulting in components longevity decrease is ,IMHO, based on invalid speculation/extra-polation.
OTOH, the little additives in detergent oils provides the much needed anti-wear performance in the rear end.
Re: Mix 30ND with 30wt HD for rear diff? [Re: Clarkbug] #4498508
08/26/17 08:39 AM
08/26/17 08:39 AM
CA
spackard Offline
spackard  Offline
CA
Much-needed?
If it was designed for ND30 then those anti-wear additives aren't "needed".
Re: Mix 30ND with 30wt HD for rear diff? [Re: Clarkbug] #4498522
08/26/17 08:57 AM
08/26/17 08:57 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
How is a rear differential/transaxle being designed for ND30 ?
Read rolling and sliding relative motion between two surfaces.
Go read up on gear designs!
Edit:add notes.
Re: Mix 30ND with 30wt HD for rear diff? [Re: Clarkbug] #4498538
08/26/17 09:19 AM
08/26/17 09:19 AM
NY
Clarkbug Offline OP
Clarkbug  Offline OP
NY
My thought was that the lack of detergent would cause any wear particles to fall out of suspension. Detergent oils keep the particles in suspension so they can be filtered. Since this is a differential, they assume the wear bits will settle on the bottom of the housing, so want no detergent.
Re: Mix 30ND with 30wt HD for rear diff? [Re: dlundblad] #4498572
08/26/17 09:52 AM
08/26/17 09:52 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I've never heard of anyone changing that oil until now!
Again:
They are VERY overbuilt for the task.
Re: Mix 30ND with 30wt HD for rear diff? [Re: Clarkbug] #4498586
08/26/17 10:04 AM
08/26/17 10:04 AM
USA
slacktide_bitog Offline
USA
30LD? laugh
Re: Mix 30ND with 30wt HD for rear diff? [Re: Linctex] #4498936
08/26/17 07:10 PM
08/26/17 07:10 PM
NY
Clarkbug Offline OP
Clarkbug  Offline OP
NY
Again:
This is BITOG.... Of course it has to be changed!
Re: Mix 30ND with 30wt HD for rear diff? [Re: Clarkbug] #4498994
08/26/17 08:36 PM
08/26/17 08:36 PM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
Pretty sure the detergents are intended to keep combustion by-products (which you of course don't have in your differential) in suspension so they don't form sludge. I don't think they are able to keep metallic particles in suspension. I could be wrong and I'd appreciate a clarification if anyone has one.
I'm curiuous about this, if you don't mind posting the model of your cart I'll call the factory and see if they can explain the advantage of the ND oil.
Re: Mix 30ND with 30wt HD for rear diff? [Re: Clarkbug] #4500674
08/28/17 06:45 PM
08/28/17 06:45 PM
NY
Clarkbug Offline OP
Clarkbug  Offline OP
NY
Sure, I have an EZGO GXT804D, or a Tuff1. The rear diff is the same off of an EZGO Marathon I believe.
My thought on that was based on also having an old Farmall M and H that used oil in the air cleaner cup. I believe that also called for non-detergent oil, but then again it was built back in the 1940's, so the engine often used it too!
Re: Mix 30ND with 30wt HD for rear diff? [Re: Clarkbug] #4503375
08/31/17 12:11 PM
08/31/17 12:11 PM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
Well, I tried alling the factory. The closest I could get to anyone who might have an explanation was the parts department. They said that they have a policy against direct communication between their engineers and end users. I would have to be a dealer to get any info. They recommended that I call a dealer. Don't have much faith that I'll get any valid info from a dealer but I called one and just got their voicemail system.
Guess my curiosity got me down a deadend road.
