Nasty looking oil filter
by atikovi. 09/21/18 12:43 PM
Laughing hard.
by StevieC. 09/21/18 12:26 PM
Apologies
by Drew99GT. 09/21/18 12:15 PM
Would Like the Manual Transmission to Make a Comeback?
by Speak2Mountain. 09/21/18 11:39 AM
Leaf Mulcher
by kwijibo. 09/21/18 11:32 AM
Pizza dough too crusty
by zorobabel. 09/21/18 11:26 AM
Lubegard Red or Platinum
by diyjake. 09/21/18 11:01 AM
Storing Car Outside
by Delta. 09/21/18 10:47 AM
Looking at a cheap commuter!
by ryan2022. 09/21/18 09:46 AM
Does Your 3.5EB Make Oil
by Gene K. 09/21/18 09:07 AM
F150 Front Differential
by hatt. 09/21/18 08:45 AM
EU version of Subaru 2.5 FB engine
by IMPALA08. 09/21/18 08:40 AM
New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
105 registered members (Bandito440, ARCOgraphite, Balrog006, atikovi, ArazelEternal, 7 invisible), 1,746 guests, and 42 spiders.
Topics290,764
Posts4,849,936
Members66,034
Most Online3,590
Jan 24th, 2017
Valvoline Brake fluid / Honda #4498077
08/25/17 07:23 PM
08/25/17 07:23 PM
PA
Chester11 Offline OP
PA
Hi guys:
It's time to replace brake fluid again. I noticed that the Valvoline fluid is Dot 3 or 4. How is that possible? I always read that the two could not be mixed.
Also - the Honda manual specifically recommends Honda Heavy Duty fluid. What are you folks doing in this regard?
Re: Valvoline Brake fluid / Honda [Re: Chester11] #4498098
08/25/17 07:44 PM
08/25/17 07:44 PM
Tennessee
ChevyMan93 Offline
ChevyMan93  Offline
Tennessee
A reputable DOT 3 or DOT 4 are fine. Boiling points in DOT 4 are a bit higher than DOT 3, but DOT 3 is fine for daily driving. DOT 3 will absorb water faster than DOT 4 and DOT 5.1 so it may need changed more often. DOT 5 is a fluid with silicone and you do not want that in your system. Stick with DOT 3 or 4 and you will be fine. DOT 5.1 is a more race oriented fluid.
DOT 3: fine for daily driving
DOT 4: good for daily driving, slightly higher boiling point.
DOT 5.1: racing oriented fluid, unnecessary for daily driving.
DOT 5: fluid with silicone content and not to be used in systems unless specifically specified. Also not for use in ABS systems.
2016 Chevrolet Silverado Z71 5.3
2017 Honda CR-V 2.4
Re: Valvoline Brake fluid / Honda [Re: Chester11] #4498099
08/25/17 07:45 PM
08/25/17 07:45 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
The only difference between DOT 3 and DOT 4 is the dry boiling point. DOT 5 is incompatible with DOTs 3+4. Now there's a DOT 5.1 That will mix with 3+4, but NOT 5.
Thick oil is better grin2
Re: Valvoline Brake fluid / Honda [Re: Chester11] #4498122
08/25/17 08:22 PM
08/25/17 08:22 PM
FL, USA
shurguywutt Offline
shurguywutt  Offline
FL, USA
I use it in my Honda, good stuff, price is good, spec is good and it works great
2008 Pilot 2WD J35Z1 148k
Maxlife Blend 10w-30
FRAM Ultra Synthetic
Fumoto F106SX
Re: Valvoline Brake fluid / Honda [Re: Chester11] #4498135
08/25/17 08:38 PM
08/25/17 08:38 PM
USA
slacktide_bitog Offline
USA
Any DOT 3 or DOT 4 is fine smile
Regular fluid changes are MUCH more important than what brand you actually use. Even Walmart DOT3 is fine as long as you replace it regularly.
That said, Castrol DOT 4 brake fluid (formerly LMA) is supposed to absorb moisture more slowly, allowing for longer service life. LMA actually stands for Low Moisture Activity (Castrol doesn't call it LMA anymore, but the fluid itself is the same). It can be used wherever DOT 3 or DOT 4 is called for. Boiling points are 509 dry, 329 wet.
Autozone has Bosch brake fluid that's supposed to be good, High boiling points, low viscosity, which is good for ABS systems.
Re: Valvoline Brake fluid / Honda [Re: Chester11] #4498141
08/25/17 08:40 PM
08/25/17 08:40 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
My latest Honda brake flush I used 'Prestone DOT3 High Temperature Synthetic' BF from Walmart. Ordered online for store pick up, only $1.71 12oz bottle. I bought 3 bottles, took ~2&1/2.
Any DOT3 or DOT4 will work. And they can be mixed. Valvoline DOT3/4 also an option.
Re: Valvoline Brake fluid / Honda [Re: Chester11] #4498206
08/25/17 09:49 PM
08/25/17 09:49 PM
CA
CharlieBauer Offline
CA
See this post that explains the difference between DOT 3 & DOT 4.
https://bobistheoilguy.com/forums/ubbthr...be_#Post4137864
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Valvoline Brake fluid / Honda [Re: Chester11] #4498255
08/25/17 11:32 PM
08/25/17 11:32 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I've used Valvoline DOT 3/4 in all my vehicles. Hondas call for DOT 3, motorcycles want DOT 4. No issues!
Re: Valvoline Brake fluid / Honda [Re: Chester11] #4498306
08/26/17 01:38 AM
08/26/17 01:38 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Originally Posted By: Chester11
Hi guys:
What Honda considers heavy duty? What Honda is it? Do you do a lot of mountain driving?
Valvoline will be fine for some grocery getting, school pick up, basically daily driving.
I use Valvoline to clean my vacuum pump before I change fluid on my vehicles smile
15' Toyota Sienna AWD (Mobil1 0W20 EP+ FRAM Ultra).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Valvoline Brake fluid / Honda [Re: Chester11] #4498372
08/26/17 06:42 AM
08/26/17 06:42 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
I would personally just buy what the car requires and avoid the Valvoline DOT 3/4 stuff. Plenty of "real" options out there.
If I had to use it, I would be more inclined to run it in a DOT3 requiring vehicle. My .02.
03 Jeep WJ 4.0 200k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 149k Rotella T5 10w30 Supertech ST3980
Re: Valvoline Brake fluid / Honda [Re: Chester11] #4498488
08/26/17 09:24 AM
08/26/17 09:24 AM
New York Queens
Ram02 Offline
Ram02  Offline
New York Queens
What is everybody using to replace there brake fluid ??
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: Valvoline Brake fluid / Honda [Re: Chester11] #4498502
08/26/17 09:32 AM
08/26/17 09:32 AM
mississippi
hiflo Offline
hiflo  Offline
mississippi
Hello always used prestone or valvoline brake fluid in my truck. but 2 weeks ago used LUCAS DOT 3 brake fluid it made a big difference better pedal feel and the truck stops better with less pedal pressure .lucas dot 3 at autozone.
Re: Valvoline Brake fluid / Honda [Re: Ram02] #4498733
08/26/17 02:24 PM
08/26/17 02:24 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I use Castrol LMA DOT 4. At like $4 a pint, it's impossible to beat here.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Valvoline Brake fluid / Honda [Re: Ram02] #4498933
08/26/17 08:03 PM
08/26/17 08:03 PM
PA
PA
Thanks all. After hitting up Walmart and Autozone - I got annoyed that filters were not in stock and went to the Honda dealer.
32oz of Honda fluid was $11. 12oz was $6 - so it was pretty much a no brainer to pick up everything in one place.
Re: Valvoline Brake fluid / Honda [Re: Ram02] #4499102
08/27/17 01:31 AM
08/27/17 01:31 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
ATE TYP200.
