Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
77 registered members (Astro14, Al, Anduril, Alfred_B, 240_Ed, badduxx, 8 invisible), 1,960 guests, and 54 spiders.
Topics296,776
Posts4,958,680
Members66,969
Most Online2,577
Jan 14th, 2019
Battery Charger ... yes time for a new one but ... #4498068
08/25/17 06:15 PM
08/25/17 06:15 PM
Chicagoland, IL
tgrudzin Offline OP
tgrudzin  Offline OP
Chicagoland, IL
I have this old Century battery charger. Probably brought it from Montgomery Wards. Model 87062. 12v/6amp, 12v/2amp, 6v/6amp. Chasing down a problem with MIL's
lawnmower. I was trying to turn a brand new starter (Toro electric start) and I could with a battery reading 13 volts. With the battery charger, i tried to start the starter at the 12v/2amp setting and nothing happen. Switch, by chance to the 12v6amp setting at it turned nicely. Connect a Harbor Frieght mutilmeter and discover the following.
Setting: 12/6amp Output: 12.06 volts DC
12/2amp 10.43 volts DC
6/6amp 7.38 volts DC
So the 12/2 setting is [censored]. The unit has a build date of 01/97.
Two questions I want answered,
1. Anyone care to recommend a battery charger I hardly use? (It is so hard to get opinions from this forum). I have purchased a Noco Genius G3500 for maintaining lawnmower and scooter batteries. Just want a car charger in case battery dies in Chicago winter that will get me though a cold spell or a charge or two until I by a new battery or the nieghbors need help.
2. Since it is my belief that a battery charger is suppose to have slightly more voltage than the battery it was charging, what happen when I tried to charge 12volt batteries with a charger putting out 10.43 volts. I often used the 12/2 setting, as this is a manually only charger and I had the fear of overcharging.
Re: Battery Charger ... yes time for a new one but ... [Re: tgrudzin] #4498076
08/25/17 06:20 PM
08/25/17 06:20 PM
ME
eljefino Offline
eljefino  Offline
ME
Seems weak. Can it power a headlight to regular brightness?
Re: Battery Charger ... yes time for a new one but ... [Re: tgrudzin] #4498092
08/25/17 06:38 PM
08/25/17 06:38 PM
Florida
SilverSnake Offline
SilverSnake  Offline
Florida
2016 Charger, 6.4L-485 HP (PUP 0W-40)
2017 BMW 330i, 2L-248 HP (BMW 0W-20)
2018 Jeep GC, 5.7L-360 HP (PUP 5W-20)
2008 20KW Generac (Amsoil 10W-30/30)
Re: Battery Charger ... yes time for a new one but ... [Re: tgrudzin] #4498146
08/25/17 07:47 PM
08/25/17 07:47 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
I don't need a $149 battery charger. I went to Walmart and bought a 10/6/2 amp charger for ~ $18 several years ago and added a $10 0.75A battery minder that you hook up and leave it connected. When the voltage drops it turns on and then turns off when the voltage comes back to normal? I feel the Shumacher chargers are a good value and dependable. Ed
CX5 Touring 2.5L :-)
Re: Battery Charger ... yes time for a new one but ... [Re: tgrudzin] #4498149
08/25/17 07:51 PM
08/25/17 07:51 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Solar pro logix 2310
Battery minder 2012
Tecmate my-191
Are my choices. If just maintaining, I'd go with the 2012 as my first choice.
Re: Battery Charger ... yes time for a new one but ... [Re: tgrudzin] #4498190
08/25/17 08:32 PM
08/25/17 08:32 PM
CA
CharlieBauer Offline
CA
For your use case, I would get a Lithium jump starter or a SOLAR Pro-Logix PL2520.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Battery Charger ... yes time for a new one but ... [Re: Eddie] #4498227
08/25/17 09:34 PM
08/25/17 09:34 PM
USA
ArcticDriver Offline
USA
Based on your description I would bet my charger is much smarter than your charger.
NOCO and CTEK.
Multiple Diesel and Gasoline vehicles
Re: Battery Charger ... yes time for a new one but ... [Re: tgrudzin] #4498235
08/25/17 09:52 PM
08/25/17 09:52 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Can't your NOCO handle the situation you're asking about?
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Battery Charger ... yes time for a new one but ... [Re: tgrudzin] #4498242
08/25/17 10:03 PM
08/25/17 10:03 PM
Chicago, IL
EdwardC Online content
EdwardC  Online Content
Chicago, IL
I think something like this manual Schumacher would work great. The high current setting should be better for getting a car started: https://www.amazon.com/Schumacher-SE-105...battery+charger
I actually have this automatic version that I use to float charge the car periodically over the winter: https://www.amazon.com/Schumacher-SE-521...battery+charger
Make sure you check the model, get one that CAN'T be shipped to California. They're older school, in my opinion, more durable technology.
Re: Battery Charger ... yes time for a new one but ... [Re: Garak] #4498243
08/25/17 10:05 PM
08/25/17 10:05 PM
Chicagoland, IL
tgrudzin Offline OP
tgrudzin  Offline OP
Chicagoland, IL
My Noco is only 3.5 amps. Not helpful if I discover my battery is dead because of weather or I left lights own and need to get something going in a hurry. Thanks for the thought.
Re: Battery Charger ... yes time for a new one but ... [Re: tgrudzin] #4498281
08/25/17 11:39 PM
08/25/17 11:39 PM
Garak Offline
Garak  Offline
No, in that situation, it certainly wouldn't do. But, it is a capable charger in its own right. Hoping to get it up to charge in half an hour in an emergency could certainly be problematic, though. wink
Re: Battery Charger ... yes time for a new one but ... [Re: tgrudzin] #4498377
08/26/17 05:48 AM
08/26/17 05:48 AM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
actually it is normal.
it goes up on a fully charged battery.
open circuit you read the rms.
the battery acts like a capacitor and you read the peak.
just use your old one.
or keep it around for charging batts that are too low for your new fangled computer based thing to see.
and of course for equalising abused neglected batts.
i have a smart charger but i only use it for gel/agm.
wet go on the old school.
Re: Battery Charger ... yes time for a new one but ... [Re: kc8adu] #4498399
08/26/17 06:25 AM
08/26/17 06:25 AM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
You are correct ArticDriver. Your $149 charger is much smarter than my $19 charger. I suspect your charger is so smart it does your income tax. Just funing. Ed
Re: Battery Charger ... yes time for a new one but ... [Re: Eddie] #4498415
08/26/17 06:40 AM
08/26/17 06:40 AM
USA
USA
Ed,
It is so smart it refuses to work on the weekends... grin
But I paid $65 on Amazon about 18 months ago so it may not be as smart as the $165 model.
Re: Battery Charger ... yes time for a new one but ... [Re: tgrudzin] #4498431
08/26/17 07:03 AM
08/26/17 07:03 AM
Johnny2Bad Offline
Johnny2Bad  Offline
This has been discussed a dozen or more times here at BITOG. Maybe do a search, all your questions are answered there.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
