Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
35 registered members (97K15004WD, CC1981, 69Torino, bbhero, Black_Thunder, aleneros, 4 invisible), 908 guests, and 42 spiders.
Topics295,207
Posts4,929,901
Members66,711
Most Online2,553
Oct 27th, 2018
B+s 11 hp MODEL 256707 type 0026-01 code 96012810 #4498028
08/25/17 05:34 PM
08/25/17 05:34 PM
Marshfield , MA
andyd Offline OP
andyd  Offline OP
Marshfield , MA
vertical flat head. 2 questions. First, what is the oil capacity? I wrote down it was a 1.5 qt.(48 oz) I only drained out 26 oz and it only 38 oz to fill to the full line on the dip stick. Should I add the 10 oz?
2 question. can I get the date of manufacture from the code TIA
Thick oil is better grin2
Re: B+s 11 hp MODEL 256707 type 0026-01 code 96012810 [Re: andyd] #4498033
08/25/17 05:41 PM
08/25/17 05:41 PM
USA
mk378 Offline
mk378  Offline
USA
These have a problem with oil backing up in the dipstick tube causing a falsely high reading. Pull the dipstick out and wipe it off. Reinsert until the cap touches the top of the tube but don't screw it down. Pull it out and take the reading.
Re: B+s 11 hp MODEL 256707 type 0026-01 code 96012810 [Re: andyd] #4498085
08/25/17 06:30 PM
08/25/17 06:30 PM
Marshfield , MA
andyd Offline OP
andyd  Offline OP
Marshfield , MA
Mk378 Thank you for your prompt reply I haven't run the engine since the oil change . I have been checking the level with the cap screwed in. I'll try it in the morning grin2
Re: B+s 11 hp MODEL 256707 type 0026-01 code 96012810 [Re: andyd] #4498096
08/25/17 06:41 PM
08/25/17 06:41 PM
Virginia
GravelRoad Offline
GravelRoad  Offline
Virginia
DOM 01/28/1996
2016 Subaru Outback Premium 2.5. PP 5w30 oem filter
2018 Hyundai Kona 1.6T. Lifetime dealer free oil/filter change
Re: B+s 11 hp MODEL 256707 type 0026-01 code 96012810 [Re: GravelRoad] #4498104
08/25/17 06:51 PM
08/25/17 06:51 PM
Virginia
GravelRoad Offline
GravelRoad  Offline
Virginia
OP, you are correct, approx. 48oz.
Re: B+s 11 hp MODEL 256707 type 0026-01 code 96012810 [Re: mk378] #4498177
08/25/17 08:14 PM
08/25/17 08:14 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Yes, many people don't realize this.
Still - lots of folks DON'T ever even CHECK their oil level!
Re: B+s 11 hp MODEL 256707 type 0026-01 code 96012810 [Re: andyd] #4498214
08/25/17 09:04 PM
08/25/17 09:04 PM
Marshfield , MA
andyd Offline OP
andyd  Offline OP
Marshfield , MA
Thank you, Gravel Road and Linctex. This jewel is a re-power on a '77 IH Cadet 80. I got the mower about 2002. It is a very battered example. It mows and uses SAE hardware. Engine has been looked after somewhat. I have been mostly trying to bodge the worn out bushings and elongated holes on the chassis. 2 of the 4 engine mounts were sheared. Partstree wanted like $70 apiece for them. I bought 4 vibration isolators from Grainger that will work. Less than $15. I used Valvoline dino 10w30 from AutoZone and will use the leftover pint in my Toro. The engine was a minor pain to remove because it has 20 yrs of oily grass clippings and belt dust surrounding the mounts. The engine is presently on a couple 2x8s laid across some saw hosses in the yurt. Im gonna push the Inty onto some cardboard and scrape, then wash off the muck with some de-greaser. I have a new air cleaner coming too.
Re: B+s 11 hp MODEL 256707 type 0026-01 code 96012810 [Re: andyd] #4498595
08/26/17 10:13 AM
08/26/17 10:13 AM
Marshfield , MA
andyd Offline OP
andyd  Offline OP
Marshfield , MA
Yep. With a few trys to read the stick the level is 8 oz low. right at the fill line with cap jut touching the neck. Thanks again guys grin2
