Review: CVJ Remanufactured CV Axles
by The Critic
Today at 03:40 AM
Towing without 85w140?
by OilFilters
Today at 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
Yesterday at 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
Yesterday at 11:13 PM
Darn dogs
by AZjeff
Yesterday at 10:21 PM
New GC?
by Bullwinkle007
Yesterday at 10:04 PM
The guy with the plexiglass head on you tube
by andyd
Yesterday at 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
Yesterday at 09:10 PM
SAE 90 v 85/140
by Knuckle078
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
Yesterday at 08:45 PM
what happened to merk
by ernied
Yesterday at 08:34 PM
Schaeffer's oil reviews on Amazon
by zfasts03
Yesterday at 07:41 PM
Decent MP3 player
by Ed_T
Yesterday at 07:08 PM
Letgo
by Donald
Yesterday at 06:52 PM
Tire buying advice
by supton
Yesterday at 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
Yesterday at 06:21 PM
No older cars in New York State?
by Oldtom
Yesterday at 06:19 PM
2009 Taurus strut mount noise
by terry274
Yesterday at 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
Yesterday at 03:36 PM
2003 Honda power steering problem
by hogpops
Yesterday at 03:29 PM
lozpxs, danthemanx07, FunktasticLucky, Knuckle078, penncove
65317 Registered Users
39 registered (2015_PSD, Bailes1992, bmod305, billt460, Astro_Guy, bbhero, 2 invisible), 826 Guests and 37 Spiders online.
65317 Members
67 Forums
285954 Topics
#4497902 - 08/25/17 04:15 PM 2011 Murano rear brakes - tips?
greenjp Offline
Loc: Germantown, MD
Howdy folks,
In a couple of weekends I'm going to be helping a relative (well more like doing it for him grin ) with the rear brakes on his 2011 Murano. He's buying the parts (Wagner rotors, Akebono pads) and I'm bringing the tools. He provides the beers for afterwards.
I've watched a few videos and determined that aside from a clearance/interference issue with the lower caliper bolt it doesn't look like there's anything tricky to expect. Nevertheless I'll bring my impact driver, mini-sledge, and full assortment of ratches and box wrenches.
Just wanted to check with BITOG to see if anyone can verify or has any tips for this particular car. Thanks,
jeff
#4497982 - 08/25/17 05:48 PM Re: 2011 Murano rear brakes - tips? [Re: greenjp]
Char Baby Offline
Loc: ROCHESTER, NY
I don't think this brake job is anything out of the ordinary and should be a quite simple job. [You probably know all this]. After the hold down bar is taken off to remove the rotors, make sure the hub is clean so the rotor fits flush to it. Also wire brush the hold down bar where the pads slide in and replace the anti-rattle clips or at least make sure they're in good condition.
Lube the sliders and add some lube to the pads ears and the Akebonos should work just fine. Bleed the calipers after all is installed and call it a day...I may have missed a step however, this Murano should be as simple as your used to seeing.
Edited by Char Baby (08/25/17 05:50 PM)
"Retired"
'06 Mazda 3i 2.0L
'15 Nissan Altima 2.5 SV
#4498005 - 08/25/17 06:08 PM Re: 2011 Murano rear brakes - tips? [Re: greenjp]
JTK Offline
Loc: Buffalo, NY
Worst part can be getting the rear rotors to come off on vehicles with the parking brake built into the hat of the rear rotors. If things are in bad shape, be prepared to replace parking brake parts.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
#4498339 - 08/26/17 05:15 AM Re: 2011 Murano rear brakes - tips? [Re: JTK]
Char Baby Offline
Loc: ROCHESTER, NY
I've had some pretty good success with Nissan rear brake rotors coming off easily even after 4-5 years. Although, if these rear rotors on the posters car are still OE, they may give some trouble. MD doesn't use the same amount of salt(if any) in their winters as our(ROC/BUFF) winters.
"Retired"
'06 Mazda 3i 2.0L
#4498867 - 08/26/17 06:01 PM Re: 2011 Murano rear brakes - tips? [Re: greenjp]
greenjp Offline
Loc: Germantown, MD
The car is in Allentown PA, which is a pretty snowy area, so we'll see. I find a few shots of knocker loose and a mini sledge will dislodge most rotors wink
Question on the parking brake - I've only had one car with the drum style parking brake, my old Saab, and all I had to do to get the rotor off was release the brake. Will that work OK on the Murano?
#4499143 - 08/27/17 05:39 AM Re: 2011 Murano rear brakes - tips? [Re: greenjp]
Char Baby Offline
Loc: ROCHESTER, NY
It should! However if there is rust build up, the rotors could give some fight! You'll be fine. Keep us posted. smile
Just be careful when using a sledge as you don't want to damage any ABS sensors or tone ring...Sadly, I've done this! frown
Edited by Char Baby (08/27/17 05:39 AM)
"Retired"
'06 Mazda 3i 2.0L
#4499440 - 08/27/17 12:57 PM Re: 2011 Murano rear brakes - tips? [Re: greenjp]
JTK Offline
Loc: Buffalo, NY
A trick I learned from a dealer mechanic.. and it sounds horrible, is to actually drive the car around the lot with the parking brake on. This will wear enough clearance between the P-brake shoes and "drum" part of the rotor to allow for easy removal. Plus it heats things up which helps with the removal.
Beating them off poses more risks IMO. I've done that too and broke the P-brake shoes, springs, clips, etc. The star-wheel adjusters are typically rusted beyond use after 4-5 winters where I live depending on the vehicle.
#4500119 - 08/28/17 08:26 AM Re: 2011 Murano rear brakes - tips? [Re: greenjp]
greenjp Offline
Loc: Germantown, MD
Good stuff guys, thanks. Hopefully no tricks or sledge hammers will be required...
I've got my full set of sockets, extensions, breakers, combo wrenches (flex head ratcheting and offset), caliper tool, torque wrenches, impact screwdriver and some miscellaneous stuff packed up. Anything weird I might need? My Saab required an E-torx socket for removing the front brakes. Don't want to get caught with my pants down.
Anyone have the torque specs for the caliper bolts, mounting frame, lug nuts?
jeff
#4500340 - 08/28/17 12:19 PM Re: 2011 Murano rear brakes - tips? [Re: greenjp]
razel Offline
Loc: Los Angeles, CA
Worked on a 2007 Murano. 1st gen, yours is 2nd. Just a tip. The rear brakes were a combo disc regular brakes / drum for the parking brake. Constant complaint of the owner (family member) was a squeal only on the 1st few brake presses often after parked for awhile (when brakes are cold). It ended up being the worn drum material somewhere inside the drum squealing when it's cold. When cold it's just slightly smaller enough for something to scrape with all that worn drum brake material inside the drum. Opening it, cleaning it out and spraying it all down with BrakLeen and checking the parking brake clearance did not help. Completely replacing the worn drum pad did. I suspect me futzing with springs inside the when replacing drum pad was beyond enough to flex that squeal.. wherever it was coming from.
#4500439 - 08/28/17 02:09 PM Re: 2011 Murano rear brakes - tips? [Re: greenjp]
JTK Offline
Loc: Buffalo, NY
jeff
Probably not what you're looking for, but I snug caliper bolts with a standard 3/8" ratchet handle and snug mounting frame bolts with a 1/2" handle. I've never once used a torque wrench on them. Same with lug nuts.
#4501137 - 08/29/17 09:50 AM Re: 2011 Murano rear brakes - tips? [Re: greenjp]
KGMtech Offline
Loc: SW Ontario Canada
OEM Nissan rear rotors for "pb in hat" style will have a access hole with rubber plug to allow you to get at parking brake pawl if you need to back it off for removal of the rotor. Should not be needed, but nice feature if you do.
Edited by KGMtech (08/29/17 10:04 AM)
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
#4509527 - 09/06/17 09:33 PM Re: 2011 Murano rear brakes - tips? [Re: greenjp]
greenjp Offline
Loc: Germantown, MD
Fellers,
The job went well. The parking brake did not prove to be a problem at all, nor did any of the bolts. Had to whack the rotors a bit with the mini sledge to get them off but nothing ridiculous. The fit of the Akebono pads was a little weird; the piston side pad was extremely tight but the outside pad was quite loose. Anyway it went together with a bit of wiggling and there were no odd noises, vibrations, etc in subsequent driving. Thanks,
jeff
#4509710 - 09/07/17 07:35 AM Re: 2011 Murano rear brakes - tips? [Re: greenjp]
KrisZ Offline
Loc: Toronto, Canada
Good to hear everything went well, however in my experience, if the pads didn't go in as easily as the OE ones, I experienced overheating and glazing issues very shortly after the job was done.
If it were me, I would monitor the brakes for signs of overheating, like bad smells or one wheel being hotter than the other.
2015 Dodge Grand Caravan-21k miles.
2006 Mazda 3-155k miles
#4509957 - 09/07/17 01:01 PM Re: 2011 Murano rear brakes - tips? [Re: greenjp]
JTK Offline
Loc: Buffalo, NY
Yes! Good to hear it went well for you. If only most of my rust-belt brake jobs went so easy! I too have found minor fitment issues with aftermarket pads. Never had a long term issue that I noticed.
