Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Ericbrooks, Japanese, lordcheeto, WondrousBread, slickoo9
66672 Registered Users
22 registered members (csandste, anndel, bbhero, ABCarr, BLND1, 4WD, 3 invisible), 892 guests, and 43 spiders.
Topics295,047
Posts4,926,744
Members66,672
Most Online2,553
Oct 27th, 2018
Rookie 2 stroke scooter questions #4497681
08/25/17 10:07 AM
08/25/17 10:07 AM
Michigan
slug_bug Offline OP
slug_bug  Offline OP
Michigan
I'm new to scooters and 2 stroke engines. The 2010 scooter I bought only had 56 miles on it. It seems to run well and the PO said he drained the gas out every winter, but I'd like to put some fuel system cleaner in the gas to potentially clean up any varnish. Is it ok to use fuel system cleaner in a 2 stroke engine?
2nd question. This is a Kymco scooter and the manual was obviously written for markets other than the U.S. It specifies "refill #92 or #95 nonleaded gasoline". I don't think they mean 92 or 95 octane? Do most 50cc scooters run fine on regular 87 octane?
2016 Miata 2.0l (12k)
2013 Fusion 2.5l(78k)
2013 Focus(56K)
2010 Linc MKX 3.5l(88k)
2007 Dodge Caravan 3.8l(179k)
2003 Merc. Mountaineer 4.6l(114k)
Re: Rookie 2 stroke scooter questions [Re: slug_bug] #4497686
08/25/17 10:18 AM
08/25/17 10:18 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
Yes, on the fuel system cleaner, in an appropriate amount.
I bet the manual is referring to RON, not R+M/2 like pumps are rated.
Premium fuel in your scooter is appropriate.
beanoil: Tough under heat, real dirty afterwards.
Re: Rookie 2 stroke scooter questions [Re: slug_bug] #4497691
08/25/17 10:25 AM
08/25/17 10:25 AM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Better stroke oils have fuel stabilizer. Some Seafoam won't hurt.
MO, while the little scooter may be OK on regular, giving it a better grade may prevent some other ignition issues if its air cooled. Your not filling up a 40 gallon tank so 30 cents won't break the bank
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Rookie 2 stroke scooter questions [Re: slug_bug] #4497709
08/25/17 11:00 AM
08/25/17 11:00 AM
Indiana
Phishin Offline
Phishin  Offline
Indiana
I'd run the highest octane fuel at the pump.
Is this scooter oil injected or must you pre-mix it?
I'd run Gumout with Regane through it. Just go easy on it....don't dump the whole bottle in a 2 gallon tank.
These air cooled 2T motors do well with a quality oil. Consider getting a good synthetic oil. It's worth it, believe me. Buy a gallon and your scoot will thank you.
Here are some of my favorites:
Maxima K2
RedLine Racing 2T
Torco
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: Rookie 2 stroke scooter questions [Re: slug_bug] #4497808
08/25/17 01:11 PM
08/25/17 01:11 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
1) what varnish are you dreaming about? smile If you want to clean something...find its fuel line and install additional fuel filter instead!
2) And yes.....they meant RON 91 or RON 95 octane fuel....if I am correct...that is your regular gasoline there
You dont need premium.......unless if you will tune that 2stroke engine
3) for non tweaked engine......API TC or API TD oil will suffice......you dont need to pay premium for oils mentioned above.....
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Rookie 2 stroke scooter questions [Re: slug_bug] #4497817
08/25/17 01:20 PM
08/25/17 01:20 PM
where the wind blows....OK
geekster Offline
geekster  Offline
This is oil injected...right?
I would make sure and get an oil that works for injected. I don't have a 2stroke scooter, but had multiple 2t bikes. My scooters are all 4t and I use the same Torco 4t that I have on hand for my quad. Torco is fantastic stuff, but can be a little pricey. I'm sure whatever oil you use will be fine, as long as it can be used in an oil injected setup. Most of my stuff is run on non-ethanol 89 octane.
I've used Techron or PEA type cleaner in my stuff and it had no ill effects. I use the appropriate amount as a treatment every so often. Mainly if it is at the beginning of the riding season. I always put in some type of stabilizer in my regular gas that's in a can anyway. I only use it towards the end of riding season to get the fuel/stabilizer distributed throughout the motor at the end of the season. During regular use and riding season I don't bother. I don't worry about my premix motors as the oil helps stabilize the fuel (could be wrong on this, but seems to work for me).
17 Nissan Frontier 4.0 Royal Purple 5w30
15 Nissan Rogue 2.5 Royal Purple 5w30
16 KIA Forte 1.8 Royal Purple 5w30
