Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
20 registered (Deltona_Dave, Falcon_LS, car51, CleverUserName, Bjornviken, 1 invisible), 721 Guests and 33 Spiders online.
65265 Members
67 Forums
285574 Topics
#4497670 - 08/25/17 10:54 AM CV shaft play?
IndyIan Offline
Loc: Ontario, Canada
I am chasing a large vibration in the rear of the CRV. I thought it was an unbalanced or out of round tire but swapping tires hasn't helped.
So I guess that leaves driveshafts? The rear CV half shafts have some play when I grab the middle of the shaft from the back of the car and pull forward and back but not very much, like ~1/8". The CV shaft ends where they go into the diff and hub seem to tight. I tried pulling on a newer front CV shaft and it has no play, so I guess the small amount of CV shaft slop is shaking the whole rear of the car? I've had bad CV joints before but they never seemed to shake the car like this.
The drive shaft to the rear diff seems tight everywhere.
Also the vibration goes from 30-35mph, then stops and starts again at 45mph and up.
07 Focus ZXW, 5spd manual, 206km M1 5W30
18 Outback 2.5 CVT 5km FF
#4497685 - 08/25/17 11:17 AM Re: CV shaft play? [Re: IndyIan]
ArcticDriver Offline
Loc: USA
When did you last change fluids including rear differential fluid with DP-2 ?
Multiple Diesel and Gasoline vehicles
#4497723 - 08/25/17 12:14 PM Re: CV shaft play? [Re: ArcticDriver]
IndyIan Offline
It was done 30-40k miles ago by the Honda dealership when my parents owned it, so its probably due again. The diff and 4wd engagement system seems to work silently, and all the shafts ends on it are tight.
#4497773 - 08/25/17 01:18 PM Re: CV shaft play? [Re: IndyIan]
Loc: USA
Old DP-2 can reult in a shudder.
#4497779 - 08/25/17 01:29 PM Re: CV shaft play? [Re: ArcticDriver]
IndyIan Offline
Didn't know that, this feels like the tire is out of round or balance. Just wondering if the small amount of CV play could cause that much shaking?
#4497780 - 08/25/17 01:31 PM Re: CV shaft play? [Re: IndyIan]
HangFire Offline
Loc: Central Maryland
You discussed End Play. Here are the axle nut torque specs for just about everything, including your 06 Honda CR-V's front and rear:
http://www.skf.com/binary/81-66360/457377.pdf
I would start by checking the one with 1/8" play.
As for the rest of your inspection, I'm not sure if your "tight" covers CV joint wear. With the wheel in the air, when you rotate the wheel, how much can it turn before the axle stub at the diff (or transaxle) turns? Is all that slop in one or both CV joints?
Rear Diff- here is an 06 maintenance schedule:
https://www.hamiltonhonda.net/2004-2006-CR-V-Maintenance-Schedule.html
It says to check condition and level every 20K and replace diff fluid at 90K. Personally I would not wait that long, plus I would do it myself. Of course, just like my Pilot VTM-4, they sell DP-II in bottles just under the quantity needed, so you have to buy two.
#4497792 - 08/25/17 01:48 PM Re: CV shaft play? [Re: HangFire]
IndyIan Offline
I don't recall that they had much twist(torsion?) play, but the shaft between the two joints had the 1/8" play when pushed and pulled at right angles to the shaft. So I guess the joints must be pretty shot?
#4497796 - 08/25/17 01:50 PM Re: CV shaft play? [Re: IndyIan]
kschachn Offline
Loc: Upper Midwest
The joints themselves should have zero play in them. The inner tripod joint can move laterally by design but that is well over 1/8" of movement.
If you have 1/8" of play in a joint then yes, that is a lot of play and can easily give rise to a vibration when driving.
1994 BMW 530i, 227K
1996 Honda Accord, 262K
1999 Toyota Sienna, 394K
2000 Toyota ECHO, 267K
#4497815 - 08/25/17 02:18 PM Re: CV shaft play? [Re: kschachn]
IndyIan Offline
Alright, off to rock auto I go to get some new CV shafts.
#4497940 - 08/25/17 04:54 PM Re: CV shaft play? [Re: IndyIan]
Loc: USA
Does it occur at all times or just while turning?
#4498931 - 08/26/17 07:59 PM Re: CV shaft play? [Re: ArcticDriver]
IndyIan Offline
All the time, so I was near 100% sure it was a tire out of round.
