New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
not sure what spark plugs to buy now
by MrTruckDriver. 03/19/19 11:33 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
140 registered members (01rangerxl, 1foxracing, 2015_PSD, 2010Civic, 2004tdigls, 14 invisible), 2,060 guests, and 57 spiders.
Topics286,084
Posts4,902,266
Members67,560
Most Online2,967
Mar 10th, 2019
1996 chrysler sebring convertible transmission leak #4497504
08/25/17 06:56 AM
08/25/17 06:56 AM
United kingdom, Essex
GotaScrewLoose Offline OP
Anyone know anything about the automatic transmission on a 96 chrysler sebring convertible I changed my transmission fluid and filter didn't have a leak but now I do but it's not leaking from the sump where I did the filter any help would be appreciated
Re: 1996 chrysler sebring convertible transmission leak [Re: GotaScrewLoose] #4497554
08/25/17 08:10 AM
08/25/17 08:10 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
You have a Chrysler Sebring convertible there in the UK?
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: 1996 chrysler sebring convertible transmission leak [Re: kschachn] #4497574
08/25/17 08:26 AM
08/25/17 08:26 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
+1 I was thinking the same thing.
That being said it sounds like there might be a gasket failure. Did you torque the bolts down properly? It is easy to over-torque and cause a leak. My advice would be to replace the gasket with a rubber (if possible, versus cork) and determine the torque specs and go from there. Transmission pans and gaskets are usually sensitive to warping if over-torqued and can cause leaks. If you are looking for a "fix it" bottle, ATP-205 does a nice job fixing leaks but honestly I would replace the gasket and check the pan for any warping.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: 1996 chrysler sebring convertible transmission leak [Re: Bgallagher] #4497577
08/25/17 08:27 AM
08/25/17 08:27 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Yep, maybe just a loose screw.
Ya know.
1994 BMW 530i, 241K
Re: 1996 chrysler sebring convertible transmission leak [Re: GotaScrewLoose] #4497581
08/25/17 08:35 AM
08/25/17 08:35 AM
USA, FLA
David1 Offline
David1  Offline
USA, FLA
Try ATP 205 re-seal... I have seen many Transmission that leak ATF and 1 bottle of that cured it..
It sounds like a gasket / seal leak...
AT205
You can call Advacne Auto Parts and tell them to type AT205 as the part number as if your were buying and it will pop up what stores in there area have it then you can have it sent to that store... I guess it beats ordering online...
Google the reviews of ATP205 reseal.
Good Luck
2002 Honda Accord V6 3.0 Automatic Trans 250K Miles
Valvoline Maxx Life FULL SYN 5W30
HAMP or FULL Or HONDA Filtech A01s
Re: 1996 chrysler sebring convertible transmission leak [Re: GotaScrewLoose] #4497622
08/25/17 09:41 AM
08/25/17 09:41 AM
Reno, NV
redbone3 Offline
redbone3  Offline
Reno, NV
heck the solenoid shifting valve. I had that trouble on a Cloud Car.
2014 Passat Wolfsburg, 1995 Miata.
Re: 1996 chrysler sebring convertible transmission leak [Re: GotaScrewLoose] #4498343
08/26/17 05:37 AM
08/26/17 05:37 AM
Thanks everyone and yes I have a chrysler sebring convertible in the UK was originally from Orlando florida the leak is not coming from the pan I've checked all around it and it's dry but the the trans fluid is dripping from all over the bottom of the gearbox and it seems some other parts of the engine like it's splashed everywhere while I was driving
Re: 1996 chrysler sebring convertible transmission leak [Re: David1] #4498344
08/26/17 05:41 AM
08/26/17 05:41 AM
Thanks
Re: 1996 chrysler sebring convertible transmission leak [Re: GotaScrewLoose] #4498552
08/26/17 10:26 AM
08/26/17 10:26 AM
Ok I've had a look under the car and as I said it's not leaking from the sump where I did the filter but it looks like it's coming from both sides where the half shafts go into the gearbox could it be seals gone both sides ?
Re: 1996 chrysler sebring convertible transmission leak [Re: GotaScrewLoose] #4499152
08/27/17 06:25 AM
08/27/17 06:25 AM
