Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
Diesel engines and emissions
by spasm3. 12/16/18 03:31 PM
Experiment time
by 53' Stude. 12/16/18 02:52 PM
2019 2.7L EB - Edge ST & Catch Can
by -SyN-. 12/16/18 02:51 PM
15 Grand Caravan
by zrxkawboy. 12/16/18 02:18 PM
Pennzoil Platinum 5w30 at walmart.com
by Irishman. 12/16/18 11:08 AM
Brandon9797, Landngroove, DanielH, Cpcz9382, PPWarrior
66699 Registered Users
115 registered members (901Memphis, 2003f7, 2009ram2500, 69Torino, 53' Stude, 14 invisible), 2,025 guests, and 44 spiders.
Topics295,165
Posts4,928,957
Members66,699
Most Online2,553
Oct 27th, 2018
differential setup - hard to find shop - ez to do #4497269
08/24/17 06:54 PM
08/24/17 06:54 PM
Chicago, IL
tomcat27 Offline OP
tomcat27  Offline OP
Chicago, IL
took apart a ford 9" differential to install a locker. got lazy and tried to find a shop to set it up. first place I called was an axle shop that was recommended plus they did some Jeep work for me in the past. no dice. they didn't wanna touch it. tried two more shops. nobody wanted to touch it. fine. my 13 year old and I started through the process: backlash, preload, we checked the pattern: coast was perfect, drive side was low and too much to the heel. my 13 yo son finished it today by himself;
so.... If a 13 year old can do it, why don't shops wanna touch it?
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: differential setup - hard to find shop - ez to do [Re: tomcat27] #4497272
08/24/17 06:58 PM
08/24/17 06:58 PM
Georgia
AVB Offline
AVB  Offline
Georgia
They don't want to be responsible for something that you could mess up after it left their shop.
Re: differential setup - hard to find shop - ez to do [Re: tomcat27] #4497290
08/24/17 07:14 PM
08/24/17 07:14 PM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
I don't know any place that wants to finish someones else's unfinished job
2004 Prius; 102K; ASL
2007 Yaris 78K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: differential setup - hard to find shop - ez to do [Re: simple_gifts] #4497295
08/24/17 07:18 PM
08/24/17 07:18 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
'Zactly my thought.
Thick oil is better grin2
Re: differential setup - hard to find shop - ez to do [Re: tomcat27] #4497342
08/24/17 08:12 PM
08/24/17 08:12 PM
Chicago, IL
tomcat27 Offline OP
tomcat27  Offline OP
Chicago, IL
It would not have been an unfinished job. they would have gotten a complete 3rd member/carrier with all of the pieces in it. they could have replaced the bearings and done a complete rebuild. 3 bearings and all of the setup. how is this any different than removing a transmission or an engine and taking it for a rebuild.
Re: differential setup - hard to find shop - ez to do [Re: tomcat27] #4497349
08/24/17 08:25 PM
08/24/17 08:25 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
It's not installed in the vehicle yet? I wouldn't declare success just yet.
I would have done it for you, 9" Fords are easy & I'm very familiar with them.
I only warranty against gear noise if NEW OEM or Yukon Ring & Pinion set are used, No warranty on overheated gear sets from incorrect break-in/overloading/fluid level, No warranty from damage caused by contaminates that came from the differential axle housing on carry in 9" center sections (not my fault the housing in your car has a pound of metal shavings in it), Last but not least.....No warranty on customer supplied parts.
If I build the differential from scratch, Buy the parts, Install it, Break it in.....I give a 2 year unlimited mileage parts/labor/noise warranty (minus the gear oil).
2001 Chevy Camaro L92/4L80E
Re: differential setup - hard to find shop - ez to do [Re: tomcat27] #4497352
08/24/17 08:27 PM
08/24/17 08:27 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
5 Bearings in a 9" center section.
Re: differential setup - hard to find shop - ez to do [Re: tomcat27] #4497361
08/24/17 08:35 PM
08/24/17 08:35 PM
Chicago, IL
tomcat27 Offline OP
tomcat27  Offline OP
Chicago, IL
sounds good to me! all new parts that you source? fine! Yukon gears and locker? fine! I'm not looking to save pennies here - almost everything else on the car is new and improved: engine, transmission, wilwood brakes, suspension, all accessories. there's only 2 parts under the hood that are original: the distributor hold down, and the oil pressure sensor adapter. only thing left after the rear end is steering.
Re: differential setup - hard to find shop - ez to do [Re: clinebarger] #4497362
08/24/17 08:36 PM
08/24/17 08:36 PM
Chicago, IL
tomcat27 Offline OP
tomcat27  Offline OP
Chicago, IL
I never said that I could count.
Re: differential setup - hard to find shop - ez to do [Re: AVB] #4497428
08/24/17 11:51 PM
08/24/17 11:51 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
Yep, he would've got turned around at my door too. He's already complaining.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: differential setup - hard to find shop - ez to do [Re: tomcat27] #4497429
08/24/17 11:52 PM
08/24/17 11:52 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Race shops will do it, at Race Shop labour charges, which can be less than ordinary car shops but at worst, no more. Talk to the racers in your area and they will put you on the right guys.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: differential setup - hard to find shop - ez to do [Re: tomcat27] #4497467
08/25/17 04:35 AM
08/25/17 04:35 AM
California
Errtt Offline
Errtt  Offline
California
Don't know if it's still around but we had not far away a dedicated differential shop.
Although back then they generally didn't accept customers bringing in parts to use.
Another shop up the hill would do complete rear & front ends mainly for the off road crowd. Had complete units lined up on the floor all clean & pretty ready to go out the door. Just no mounted wheels/tires on them.
Re: differential setup - hard to find shop - ez to do [Re: tomcat27] #4497587
08/25/17 07:40 AM
08/25/17 07:40 AM
Onondaga County
Miller88 Offline
Miller88  Offline
Onondaga County
What type of locker?
Full carrier locker or a detroit/spartan/aussie auto locker?
I'd check if there are any off road shops. Any off road shop should know their way around differentials.
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
Re: differential setup - hard to find shop - ez to do [Re: tomcat27] #4497650
08/25/17 09:26 AM
08/25/17 09:26 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
It's hard to find good shops that aren't just parts swappers. They are used to someone coming in with a blown up rear axle that they can just swap a junkyard axle with. Much easier to do and can still charge a bunch of money. There are a few really good professional shops around here, and they are constantly busy for that reason. I agree with Miller88 that your best bet would have been an offroad shop.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (36k) - Castrol Edge Euro 0w40, MANN HU816X
Re: differential setup - hard to find shop - ez to do [Re: tomcat27] #4497659
08/25/17 09:39 AM
08/25/17 09:39 AM
South Carolina
pcoxe Offline
pcoxe  Offline
South Carolina
It's time consuming to do a setup correctly. Lots of other quicker jobs to make money on. Even setup correctly it may have noise. Most shops don't want the potential hassle.
