Self defense
by Camprunner
28 minutes 5 seconds ago
Any apple experts here?
by maverickfhs
51 minutes 14 seconds ago
Cost-no-object 75W-90 GL-5 for a differential?
by d00df00d
Today at 02:34 PM
Pittsburgh Dad, this guy is a trip
by Rat407
Today at 02:06 PM
14 Jeep GC 5.7, PP 5w20 & 0w20
by Vigg
Today at 01:52 PM
Sell me on a SSD drive...........
by ZZman
Today at 01:07 PM
need some ideas on my issue
by matrass
Today at 12:36 PM
Put Pennzoil Platinum Euro L in a Honda.
by dunlop0078
Today at 12:36 PM
BMW V8 Oil Consumption Fix
by doc540
Today at 11:25 AM
More info on Valvoline Modern Engine Oil
by buster
Today at 11:07 AM
Shelf life of synthetic 2 stroke engine oil ?
by ScottMill
Today at 10:34 AM
Oil sample extraction
by Tikka
Today at 10:30 AM
Re-using building materials esp nails
by andyd
Today at 08:57 AM
Central A/C [censored] out
by TOMJ
Today at 08:43 AM
08 Scion tC under valve cover pics
by Highboy
Today at 08:39 AM
Storing extension ladded in garage?
by maverickfhs
Today at 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
Today at 07:20 AM
Any news on what happened to this plane?
by Exhaustgases
Today at 02:36 AM
E4OD fluid ?
by Exhaustgases
Today at 02:23 AM
Update password ?
by meadows
Yesterday at 11:59 PM
WtsTacoma01, Orion62, Revd, blinky1041, mostdecent
65262 Registered Users
84 registered (379KITTY, 2015_PSD, 2strokeNorthstar, 2009Edge, 5 invisible), 1774 Guests and 37 Spiders online.
65262 Members
67 Forums
285527 Topics
#4497257 - 08/24/17 07:32 PM Overseeding an established lawn
Donald Offline
Loc: Upstate NY
What is the best way to overseed an established lawn? Rent a slice seeder from a rental place?
What about the coated grass seeds? Given the coating, can one just spread them one the ground and expect them to grow.
2015 Ford F250 w/Powerstroke
#4497265 - 08/24/17 07:46 PM Re: Overseeding an established lawn [Re: Donald]
Bronco1 Offline
Loc: Colorado
if you are talking about over seeding with winter rye, you can mow it down short, sow your seed with a broad cast spreader (like the old whirly bird (i think my age is showing)). some people use manure on it, some a topper or mulch with a starter fertilizer. I used to do the later because I usually got more weeds with manure. as for the coated seeds, I'd still use a topper or mulch over it.
Edited by Bronco1 (08/24/17 07:48 PM)
07 F150 Lariat 4x2
07 Honda Fit
96 Ford Bronco 4x4
"If you always do what you always did, you will always get what you always got" Albert Einstein
#4497266 - 08/24/17 07:46 PM Re: Overseeding an established lawn [Re: Donald]
Oli20 Offline
Loc: Michigan
I highly recommend core areating first. As soon as you areate then spread the seed. Wait as long as you can after that to mow. This gives the seed time to settle in the holes as well as the cores will start to break down and cover some seed that isn't in the hole. Make sure it gets watered if possible. After 2-3 weeks you should fertilize with a starter fertilizer. I've done this a few times with fabulous results.
The coating just helps with water retention, the seed needs good soil contact to germinate properly and not die out immediately.
2014 Silverado LTZ 5.3 3.42
#4497300 - 08/24/17 08:22 PM Re: Overseeding an established lawn [Re: Donald]
oilpsi2high Offline
Loc: NY, USA, etc.
You need to first dethatch and aerate.
You can put the seeds down with a spreader. Also do a soil test and fertilize as needed.
Good luck.
#4497307 - 08/24/17 08:26 PM Re: Overseeding an established lawn [Re: Oli20]
Donald Offline
Loc: Upstate NY
I have seen some products you tow behind a tractor that are like a wide drop spreader with rows of aerator teeth.
Then there are the power slit seeders you can rent.
#4497457 - 08/25/17 04:56 AM Re: Overseeding an established lawn [Re: Donald]
Rolla07 Offline
Loc: MTL, CANADA
You would need to do the following. Cut grass short, spread thin layer of compost or earth (compost is best). You will only need a 1/4 to 1/2 inch spread across your land and follow up by hand spreading the seed. After that gently rake it together so the seed mixes with the soil. This ensures good seed to soil contact. You can then follow directions on a starter fertilizer. If you have a large surface area you can go the slit seeder route. I follow the above way and it works well for me.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
#4497482 - 08/25/17 06:12 AM Re: Overseeding an established lawn [Re: Rolla07]
Egg_Head Offline
Loc: North Carolina
Not sure what type of grass you use in CO, I would only add to all the previously mentioned good advice is to get a ph test on your soil from your county ag dept. This will determine if you need to put out lime and at what rate per 1000 sq. feet.
1979 Garelli Rally Sport
2009 Cub Cadet LT1042
2002 BMW 540 M Sport (totaled)
#4497565 - 08/25/17 08:17 AM Re: Overseeding an established lawn [Re: Donald]
Bgallagher Offline
Loc: Boston, MA
Soil test is a good idea just to determine the acidity level and if your soil is lacking certain nutrients. If you want to skip that I would first clean up any thatch on the yard, lay a few bags of lime, starter fertilizer and rent a slice seeder and dump seed on it. Watering is the most crucial part of this. Also, it might not look like Augusta in a month but if you continue this process you will have a great lawn in a few seasons.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
#4497628 - 08/25/17 09:52 AM Re: Overseeding an established lawn [Re: Donald]
Indydriver Offline
Loc: Indiana
I have been doing this for 4 of 5 past years and it's really helped my lawn.
#1. Fall only. It's the only season grass seed has a chance.
#2. Aerate first. Leave the plugs on the grass. They will eventually break down and fill the holes back in and you will have some nicely deep rooted new grass.
#3. Choose the right seed for sun exposure. If you have mature trees or any other shade, forget about bluegrass.
#4. Apply seed 2x recommended coverage rate.
#5. Water immediately to get germination started asap. Gives a big headstart on getting established.
#6. Fertilize after the new grass is established.
#7. Repeat next year, this is not a 'one-and-done' deal.
2017 Mazda CX3 1000 FF
2014 Camaro 2SS/RS LS3 Vert 13,000 M1
2012 Sienna 75,000 M1
2011 Accord VCMV6 75,000 M1
2007 Tahoe 130,000 M1 HM
#4497678 - 08/25/17 11:03 AM Re: Overseeding an established lawn [Re: Donald]
Donald Offline
Loc: Upstate NY
What about the coated seed? Can that deal with my lack of ability to water my lawn? Not enough water in the well and do not want to chance it? Good for household use or washing a car. But not to leave a hose on for many hours.
Edited by Donald (08/25/17 11:04 AM)
#4498337 - 08/26/17 05:10 AM Re: Overseeding an established lawn [Re: Donald]
Lubener Offline
Loc: N.Ohio
I would slice and use a drop spreader(if available) to apply the seed. You will have better success by prepping the surface and not just applying seed to lay on the hard ground surface.The coated seed will help retain some moisture. Follow up with a starter fertizer. All you have to do is maintain surface moisture, you don't need to water for hours.You want a blend of different varieties. On large bare spots only, cover the seed with straw but don't overdo it.You can deal with the weeds next season. You want to plan your schedule so that you can mow it 2-3 times before winter to harden it off.
Edited by Lubener (08/26/17 05:17 AM)
The "thinking" man's friend.
