Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
91 registered members (ammolab, 2009Edge, 2015_PSD, bbhero, ArrestMeRedZ, 13 invisible), 2,141 guests, and 31 spiders.
Topics287,749
Posts4,933,806
Members67,850
Most Online2,967
Mar 10th, 2019
Mistakenly put diesel fuel into a gas lawn mower #4497018
08/24/17 02:04 PM
08/24/17 02:04 PM
TX
handyman Offline OP
handyman  Offline OP
TX
My neighbor mistakenly put diesel fuel into a new Kubota riding lawn mower that would normally require gasoline. We drain the fuel tank and replaced the fuel filter. I shot starter fluid down the carb and it smoked the yard. It would not continue to run. The fuel filter did not look like it was getting any gas. He had to leave on a trip and we are going to work on it this weekend. Any suggestions on fixing this issue.
2011 Prius III 111k
2006 Senna LE 160k
2001 Saturn L100 200k
1993 Corolla LE 200k
Re: Mistakenly put diesel fuel into a gas lawn mower [Re: handyman] #4497028
08/24/17 02:11 PM
08/24/17 02:11 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Flush out the fuel tank, drop the carb bowl and empty it. Then disconnect the fuel line from the carb and flush the carb out with some carb cleaner. Put it together add some fresh gas, change or clean the spark plug and give it a try. You might need a bit of ether/starting fluid to get it running.
God Bless Our Troops
Re: Mistakenly put diesel fuel into a gas lawn mower [Re: handyman] #4497038
08/24/17 02:16 PM
08/24/17 02:16 PM
USA
NHGUY Offline
NHGUY  Offline
USA
Change the plug,its going to have a big ball of carbon on it.
Re: Mistakenly put diesel fuel into a gas lawn mower [Re: handyman] #4497051
08/24/17 02:29 PM
08/24/17 02:29 PM
USA
mk378 Online content
mk378  Online Content
USA
You'll have to clear the fuel line and the carb. Most of the time there is a nut on the bottom of the carb bowl, loosen it holding a container underneath and let it drain. Remove the spark plugs, you will need to clean them, and with the plugs out the engine will spin faster in the next step. Disconnect the fuel hose input to the carb and hold it on a container, turn the key and crank until clean gas (that you have poured into the tank) comes out. Then tighten the nut, reattach the line, crank to fill up the bowl, reinstall plugs, and start.
Re: Mistakenly put diesel fuel into a gas lawn mower [Re: handyman] #4497113
08/24/17 03:46 PM
08/24/17 03:46 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
mk378 described the way I would attack the issue.
Attach a label close to the filler "Gas only"
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Mistakenly put diesel fuel into a gas lawn mower [Re: handyman] #4497348
08/24/17 09:21 PM
08/24/17 09:21 PM
Tn.
CourierDriver Offline
Tn.
My best answer,,,,don't do thattttttttttttttt anymore. thumbsup True story:Buddy of mine goes for a ride on his motorcycle,,stops, fills it up, not paying attention puts diesel in it,,,,why,,,I do not know,,,starts the engine and gets about 10 feet....after he gets it to the shop the next day, the bill was 150 to fix the mess..lol
Look into Forks Over Knives Official Plant-Based Group if you want to change your way of eating.
Re: Mistakenly put diesel fuel into a gas lawn mower [Re: demarpaint] #4497445
08/25/17 02:07 AM
08/25/17 02:07 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
This. That's pretty much what I did some years ago when my younger brother put diesel in the gasoline rototiller. wink It smoked a bit, of course, too, until things were normal again.
Plain, simple Garak.
Re: Mistakenly put diesel fuel into a gas lawn mower [Re: handyman] #4497616
08/25/17 09:25 AM
08/25/17 09:25 AM
MN
ironman_gq Offline
ironman_gq  Offline
MN
Shouldn't have done any real damage, just get it flushed out and change the spark plug. Might smoke a bit if it ran at all with the diesel until any in the muffler gets burned off.
Re: Mistakenly put diesel fuel into a gas lawn mower [Re: ironman_gq] #4497641
08/25/17 10:12 AM
08/25/17 10:12 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
This.
Diesel in a gas engine just makes a mess of the fuel system but won't cause any real damage. Gas in a diesel is where you get damage.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (38k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Mistakenly put diesel fuel into a gas lawn mower [Re: handyman] #4501228
08/29/17 11:44 AM
08/29/17 11:44 AM
TX
handyman Offline OP
handyman  Offline OP
TX
Well, I talked with his wife. He is going to have the Kubota dealer work on it. They say it is fuel injected and needs a special flush to clean it out. 250 bucks and they can get to it in a week or so.
I offered to work on it for him but I think he just wants the dealership to work on it.
Some people are just not mechanically inclined.
2011 Prius III 111k
2006 Senna LE 160k
