Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
121 registered members (1978elcamino, addyguy, 2015_PSD, Alfred_B, 11 invisible), 2,406 guests, and 52 spiders.
Topics286,019
Posts4,900,886
Members67,548
Most Online2,967
Mar 10th, 2019
Nissan FF; 2600 mi; Infinity Q50 #4496886
08/24/17 11:23 AM
08/24/17 11:23 AM
Mass.
Robertslowpoke Offline OP
Mass.
smile
I have a new Q 50 infiniti. Infiniti says to change the oil at 10,000 miles. this is a twin turbo, direct inject engine, so I changed it at 2600 miles.
the silicon and metals were high, "normal from wear in" but the insolubles were low, meaning oil filter worked. there was no way I would wait 10,000 miles!
iron was 41 instead of average 31
copper was 104 instead of 20
molybdenum was 616 instead of 172
silicon was 188 instead of 51
insoluble were 0.1%, should be less than 0.6%. good.
can anyone offer any further insight into these numbers? blackstone said to try 4500 miles next time.
best regards! bob
Re: first oil change [Re: Robertslowpoke] #4496891
08/24/17 11:43 AM
08/24/17 11:43 AM
Charlotte
planeman223 Offline
planeman223  Offline
Charlotte
Congrats on the new car. I've had a VQ engine in the fleet since 2006 and have tried every variety of synthetic 5w-30 out there with no noticeable difference. It will be a great car for years to come!
Re: first oil change [Re: Robertslowpoke] #4496892
08/24/17 11:45 AM
08/24/17 11:45 AM
Lynchburg, VA, USA
SF0059 Offline
SF0059  Offline
Lynchburg, VA, USA
All of what you are seeing can be attributed to engine break-in. Iron from the steel parts, copper from your turbo intercoolers, silicon from sealants. There is nothing abnormal or worth worrying about.
The numbers will come down over time. If you are going to take a UOA at the next oil change, just look for downward trends as everything gets washed out.
I'd keep a closer eye at the fuel dilution, being DI and TT.
Congrats on the new ride!
2014 Honda Odyssey EX-L/RES: 54K mi, M1 0w-40 & FU, VCMuzzler V2
2017 Mazda 6 Touring 6MT: 22k mi, M1 AFE 0w20, OEM Filter
Re: first oil change [Re: Robertslowpoke] #4496893
08/24/17 11:47 AM
08/24/17 11:47 AM
Danh Offline
Danh  Offline
Sounds pretty normal for a factory fill to me.
Higher iron is from cylinder walls conforming to piston rings, which is desirable and normal.
Copper is likely from an oil cooler, is normal and should decrease with time.
Molybdenum is probably from assembly lubes that wash into the engine oil on first start-up.
Silicon is from sealers applied at the factory. Again, these will decrease with time.
Re: first oil change [Re: Robertslowpoke] #4496896
08/24/17 11:50 AM
08/24/17 11:50 AM
Mass.
Mass.
great! that is a great explanation! how many miles should I let this oil go? it was mobil one full synthetic.
have a great day!
bob drive
Re: first oil change [Re: Robertslowpoke] #4496899
08/24/17 11:53 AM
08/24/17 11:53 AM
Mass.
Mass.
the fuel said less than 0.5%, should be under 2%, so that sounds good.
Re: first oil change [Re: Robertslowpoke] #4496918
08/24/17 12:06 PM
08/24/17 12:06 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
On the full synthetic, I'd think the 10,000 miles would be achievable. I worry about the people that try the 5w-30 conventional for 10,000 hard miles. wink
Plain, simple Garak.
Re: first oil change [Re: Robertslowpoke] #4496953
08/24/17 12:49 PM
08/24/17 12:49 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Danh summed it up. Do another UOA at about 20K miles and you should see the iron, copper, and silicon come down. Moly will be dependent upon the oil you use.
God Bless Our Troops
Re: first oil change [Re: Robertslowpoke] #4496963
08/24/17 12:59 PM
08/24/17 12:59 PM
Mass.
Mass.
THANKS SO MUCH GUYS!
Re: first oil change [Re: Robertslowpoke] #4497079
08/24/17 03:05 PM
08/24/17 03:05 PM
MN
oil_film_movies Offline
MN
Use the best oil available for a valuable engine like that. Mobil1 has their Annual Protection oil, and Castrol Edge has their gold jug Extended Performance. Fram Ultra oil filters filter great and last up to 20,000 miles, so a great choice there. ..... Then you can be more sure there is plenty of margin in your 10,000 mile oil change intervals.
It should have a dashboard light which tracks oil conditions (most other makes I know do anyway; not sure about Nissan/Infiniti). When you change the oil, you have to tell the engine computer you did it. When you changed at 2600 miles, did you reset the engine computer's oil life monitor algorithm?
