PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
125 registered members (2015_PSD, 01rangerxl, 2K2AcuraTL, 12 invisible), 2,017 guests, and 61 spiders.
Topics286,162
Posts4,903,342
Members67,569
Most Online2,967
Mar 10th, 2019
What does Audi use for brake caliper pin grease? #4496766
08/24/17 08:46 AM
08/24/17 08:46 AM
Cleveland, Ohio, USA
RobM Offline OP
RobM  Offline OP
Does anyone know what kind of grease Audi uses on their caliper pins? I know I can just get silicone paste grease, but would like to know what they actually use.
Re: What does Audi use for brake caliper pin grease? [Re: RobM] #4496801
08/24/17 09:13 AM
08/24/17 09:13 AM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
VW and Audi do not grease their caliper guide pins at all.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: What does Audi use for brake caliper pin grease? [Re: UG_Passat] #4496805
08/24/17 09:15 AM
08/24/17 09:15 AM
RobM Offline OP
RobM  Offline OP
That's interesting. Dry lube?
Re: What does Audi use for brake caliper pin grease? [Re: UG_Passat] #4496810
08/24/17 09:24 AM
08/24/17 09:24 AM
SW Ontario Canada
KGMtech Online happy
KGMtech  Online Happy
SW Ontario Canada
I don't agree, based on my experience with VAG products. From where do you get this information?
I use ATE brand brake lube on the slider pins and on the lip of piston seal to prevent sticking as I wind back the parking brake adjuster.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: What does Audi use for brake caliper pin grease? [Re: RobM] #4496811
08/24/17 09:26 AM
08/24/17 09:26 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
If it is the same as BMW then there is no lube at all, dry pins in the rubber sheath. At least on my old BMW per the MM.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: What does Audi use for brake caliper pin grease? [Re: RobM] #4496820
08/24/17 09:33 AM
08/24/17 09:33 AM
RobM Offline OP
RobM  Offline OP
Re: What does Audi use for brake caliper pin grease? [Re: RobM] #4496825
08/24/17 09:39 AM
08/24/17 09:39 AM
Slovenia EU
Kamele0N Online sick
Kamele0N  Online Sick
Slovenia EU
Lithium grease...well thats interesting...
So they are are using different typ of rubber on pins and for dust boots?
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: What does Audi use for brake caliper pin grease? [Re: RobM] #4496832
08/24/17 09:48 AM
08/24/17 09:48 AM
RobM Offline OP
RobM  Offline OP
That's what I'm wondering now. Doesn't make sense for rubber parts.
Re: What does Audi use for brake caliper pin grease? [Re: Kamele0N] #4496835
08/24/17 09:48 AM
08/24/17 09:48 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Like many of those lubes, it is a little ambiguous whether it is intended to be used on caliper slide pins or not. At least that's the way I read it.
You are always better off following what the maintenance manual for your vehicle says rather than what it may or may not say on a tube of lubricant. I never like working on any vehicle without the FSM for this and other reasons.
What is the design of the pins and boots? My Asian vehicles which specify a pin lubricant in the FSM are the short type that only protect the exposed portion of the pin that extends out from the pad carrier. The portion of the pin that is within the carrier bore is going into a bare metal socket. On the BMW however, it is a full-length boot where it extends the entire length of the carrier bore (but interestingly the exposed portion of the pin has no boot protection). If you did grease this type of pin then the grease would be exposed to the environment unlike the design on my Asian cars. BMW compensates by giving the pins a heavy plating (looks like chrome or nickel) as opposed to the relatively light plating on the other ones.
What does rust on the BMW is the carrier bore hole in contact with the outside of the boot. That tends to compress the diameter of the hole and over time can cause the pins to stick. You need to make sure you pull the boots out of the carrier and clean up the carrier bore so it isn't reduced in diameter because of rust.
BMW brake pin boots:
Asian brake pin boots:
The above images are for my old cars, I don't know if it is the same for newer ones.
1994 BMW 530i, 241K
Re: What does Audi use for brake caliper pin grease? [Re: RobM] #4496847
08/24/17 10:02 AM
08/24/17 10:02 AM
RobM Offline OP
RobM  Offline OP
Yeah, I really need to buy/find a service manual. It's designed kind of like the Asian car boots.
Re: What does Audi use for brake caliper pin grease? [Re: kschachn] #4496854
08/24/17 10:18 AM
08/24/17 10:18 AM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
Those are the same type of boots VW/Audi uses, like the BMW ones.
If one purchased Tyrolsport metal guide bushings, they need to be greased annually per their instructions, especially the older ones that don't have a dust seal in the back.
Re: What does Audi use for brake caliper pin grease? [Re: kschachn] #4496862
08/24/17 10:30 AM
08/24/17 10:30 AM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Interesting as my E30 318i had what you classify as "Asian" boots for its calipers...
I need to look at the monster calipers on my 135i...
Re: What does Audi use for brake caliper pin grease? [Re: RobM] #4496876
08/24/17 10:54 AM
08/24/17 10:54 AM
Ga
DB_Cooper Offline
DB_Cooper  Offline
Ga
I have always lubed the brake pins on my VW/Audi cars...green grease works and I confirmed with the manufacturer it is safe with rubber or plastic parts..seems to work just fine.
In the Bentley for my Audi Cabriolet it indicates:
4 - Brake pad carrier with guide pins and protective cap
Replacement part supplied assembled with sufficient grease on guide pins
Install repair kit if protective caps are damaged
Use grease included with kit to grease guide pins
Re: What does Audi use for brake caliper pin grease? [Re: JHZR2] #4496880
08/24/17 11:00 AM
08/24/17 11:00 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
And I have to apologize, I was confused about where the pin boots are on my BMW. I kept saying they are located in the pad carrier, but it is actually in the caliper. After I wrote that I started doubting it and sure enough I had it wrong. The principle is the same however.
1994 BMW 530i, 241K
Re: What does Audi use for brake caliper pin grease? [Re: DB_Cooper] #4496898
08/24/17 11:52 AM
08/24/17 11:52 AM
RobM Offline OP
RobM  Offline OP
Thank you sir.
