Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
In praise of kludges...
by wings&wheels. 01/17/19 02:11 PM
Has Mobil 1 0w40 been discontinued?
by Doublehaul. 01/17/19 01:17 PM
Some questions for the home theater gurus
by grampi. 01/17/19 12:55 PM
Weird side problems after doing repairs
by mclasser. 01/17/19 12:31 PM
Shell Rotella Gasoline Truck.
by JHogan. 01/17/19 12:14 PM
Sears to stay open, for now
by addyguy. 01/17/19 11:35 AM
What Have I Gotten Myself Into?
by Gebo. 01/17/19 11:17 AM
Car stereo FM/ AM Reception Problems
by LazyDog. 01/17/19 11:13 AM
PPHM uoa requests
by aquariuscsm. 01/17/19 11:00 AM
Odd issue in Tacoma 3.5L V6 (2GR-FKS)
by 2019StingrayZ51. 01/17/19 10:58 AM
Alternative to Gillette Fusion razor
by gman2304. 01/17/19 10:55 AM
CAFE standards
by otis24. 01/17/19 10:01 AM
5w30 vs 5w40 Mercedes E220 BLUETEC
by Costas00. 01/17/19 09:56 AM
Moving mobility scooters
by supton. 01/17/19 08:59 AM
Car stumbling in idle
by dan765. 01/17/19 08:58 AM
Fiat 9.55535-GS1 Certification - Ravenol
by RamFan. 01/17/19 08:35 AM
Bigyetti83, Drava, supertrucker, neiltt, Drspel
66960 Registered Users
115 registered members (Andy636, anndel, addyguy, aquariuscsm, 28oz, AandPDan, 13 invisible), 2,188 guests, and 48 spiders.
Topics296,731
Posts4,957,830
Members66,960
Most Online2,577
Jan 14th, 2019
Can ps fluid eat through a gallon jug? #4496739
08/24/17 07:31 AM
08/24/17 07:31 AM
PENNSYLVANIA
JeepWJ19 Offline OP
JeepWJ19  Offline OP
PENNSYLVANIA
Silly question, I know...
It's time I switched out the power steering fluid on my jeep. It's been the most neglected and I feel bad for allowing it to go this long. I don't plan on flushing the whole system, just using a turkey baster method and getting as much out of the reservoir as I can. Going to be using Valvoline PS fluid since it's the only one I can find that actually states it meets MS5931 spec. I didn't think there could be much difference between PS fluid and ATF+4 but if Chrysler says so then I'd rather just go with what is spec'd.
Anyway onto the question:
I don't have any other left over empty bottles (like oil bottles etc) but I do have an empty gallon milk/water jug. I just need to hold the power steering fluid until I get it recycled which will be done ASAP. Will the jug be fine?
Thank you
If gallong jug is ambiguous:
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
Re: Can ps fluid eat through a milk jug? [Re: JeepWJ19] #4496748
08/24/17 07:37 AM
08/24/17 07:37 AM
new jersey
hemitruck Offline
hemitruck  Offline
new jersey
I would just use the PS fluid from Mopar. Had trouble with the Valvoline ps in my 04 grand Cherokee.
Re: Can ps fluid eat through a milk jug? [Re: hemitruck] #4496754
08/24/17 07:41 AM
08/24/17 07:41 AM
PENNSYLVANIA
JeepWJ19 Offline OP
JeepWJ19  Offline OP
PENNSYLVANIA
From researching, The traditional Mopar PowerSteering Fluid was discontinued and they only have Mopar PowerSteering Fluid +4 available.
Re: Can ps fluid eat through a milk jug? [Re: JeepWJ19] #4496794
08/24/17 08:10 AM
08/24/17 08:10 AM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Could use the moo jug for temporary and pour it back into the power steering jug you used. I don't think its going to eat through in 30 minutes or so
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Can ps fluid eat through a milk jug? [Re: JeepWJ19] #4496822
08/24/17 08:38 AM
08/24/17 08:38 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Keep the jug out of the sunlight. They will bio-degrade. I would use the turkey baster to empty the pump reservoir so I could remove the return line and plug the gazinta without making a mess. Then collect the return in the jug as you pour the fluid of your choice into the system.
Thick oil is better grin2
Re: Can ps fluid eat through a milk jug? [Re: JeepWJ19] #4496841
08/24/17 08:56 AM
08/24/17 08:56 AM
NC
ruhroh Offline
ruhroh  Offline
NC
Yep, for the WJ, you need to use the amber colored MS5931 PSF. Don't be tempted to throw ATF+4 in it.
The Carquest PSF meets the Chrysler spec too if that's easier to find than the Valvoline. I think at the time, the Oreilly-brand fluid met the spec too. Someone mistyped the Chrysler spec on the AAP product page and it hasn't been fixed in half a decade. I used almost one quart after disconnecting the return hose and draining the reservoir and then dry steer from end to end with the wheels off the ground and engine off. No problems or leaks after two years now with the CQ fluid. With your baster way, it might replace maybe 1/4 quart unless you do it multiple times.
If in doubt about the jug's long-term degradability, you can always pour the new fluid into the jug first when you're doing the work and use the emptied oil bottle to collect the waste...
Re: Can ps fluid eat through a milk jug? [Re: JeepWJ19] #4496848
08/24/17 09:06 AM
08/24/17 09:06 AM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
I've had coolant, but not ATF/PS in those jugs.
1997 Maxima 192k, QSGB 5w30+QSUD 5w30 (2:1), PL14477
2004 Corolla 195k, VWB 5w20 + SSS 10w40, MGL4967
Re: Can ps fluid eat through a milk jug? [Re: JeepWJ19] #4496873
08/24/17 09:48 AM
08/24/17 09:48 AM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
Cat litter jugs work fine and don't degrade.
Re: Can ps fluid eat through a milk jug? [Re: JeepWJ19] #4496932
08/24/17 11:23 AM
08/24/17 11:23 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Those jugs aren't the longest lasting plastic.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Can ps fluid eat through a milk jug? [Re: JeepWJ19] #4497260
08/24/17 06:37 PM
08/24/17 06:37 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
I've seen oil eat through those but it took about a year. As long as the fluid isn't super hot it should work for transport and dump
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Can ps fluid eat through a milk jug? [Re: JeepWJ19] #4497276
08/24/17 07:00 PM
08/24/17 07:00 PM
PENNSYLVANIA
JeepWJ19 Offline OP
JeepWJ19  Offline OP
PENNSYLVANIA
Thanks everyone! I'm doing the turkey baster method and every couple weeks I'm just gonna keep doing it until I use up the whole quart of PSF. Got 1/4 quart out today. Will take out another quart next week.
The jug won't be stored long and always stays cool in the garage where sun doesn't hit.
Re: Can ps fluid eat through a milk jug? [Re: JeepWJ19] #4497288
08/24/17 07:12 PM
08/24/17 07:12 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
You'll be fine if you move quickly. I've had more leakers from milk jugs than oil jugs that's for sure, but I am not sure if it was the oil eating through the plastic (obviously not oil rated like an oil jug) or a crack in the seam. Milk jugs I get rid of right away now as in I make a special trip that weekend. Oil jugs not quite as urgent as in next convenience when I'm thinking about it.
You are doing good by not adding ATF. I want to say the later model TJ's required ATF+4. I am not sure on anything newer. Meanwhile, I've read reports of the +4 making the systems scream and the MS5931 making systems scream. Some WJ era Chrysler systems required the +4 which just added to the confusion. I've had Oreilly brand and Valvoline PSF in my Jeep for years now. Issue free aside from a slow high pressure line leak. Probably wouldn't have happened if I used +4... whistle
*I am glad my truck's PS system can use both ATF and PSF. Being able to use 1 fluid is nice..
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Can ps fluid eat through a milk jug? [Re: JeepWJ19] #4497673
08/25/17 09:59 AM
08/25/17 09:59 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Milk jugs are unreliable for long term use, even with water. The clear one gallon juice bottles are great.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Can ps fluid eat through a milk jug? [Re: SHOZ] #4497683
08/25/17 10:13 AM
08/25/17 10:13 AM
PENNSYLVANIA
JeepWJ19 Offline OP
JeepWJ19  Offline OP
PENNSYLVANIA
Not for long term use. Recycling it today
