Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
104 registered members (andyd, AdditiveOCD, addyguy, Bailes1992, ARCOgraphite, 14 invisible), 1,805 guests, and 71 spiders.
Topics286,446
Posts4,908,477
Members67,626
Most Online2,967
Mar 10th, 2019
Question on Honda brake fluid condition. #4496568
08/24/17 12:08 AM
08/24/17 12:08 AM
Colorado
Chris B. Offline OP
Chris B.  Offline OP
Colorado
2012 Accord EXL V6 73,000 total miles. I have been flushing my brake fluid at the dealer every 3 or so years and 36-40K miles. When it is new it is a nice clear amber color and after a year or so it gets super cloudy and almost like it has chunks in the master cylinder. I just had it flushed again by the dealer for $70 and it is much cleaner but still a bit cloudy. Is this anything to be concerned about? How does your brake fluid look? Thanks!
Re: Question on Honda brake fluid condition. [Re: Chris B.] #4496574
08/24/17 12:29 AM
08/24/17 12:29 AM
NorCal
Seventh Offline
Seventh  Offline
NorCal
The only way to make the fluid in the reservoir look super clear is to suck it all out and refill before performing the flush. Otherwise the new fluid is mixing with the old during the service and it would take forever until the reservoir looked totally clean.
They likely just attached the power bleeder and performed the fluid exchange.
Don't worry about it. The fluid in the calipers and wheel cylinders (if you have drum brakes) is what matters.
Re: Question on Honda brake fluid condition. [Re: Chris B.] #4496578
08/24/17 12:50 AM
08/24/17 12:50 AM
Colorado
Chris B. Offline OP
Chris B.  Offline OP
Colorado
It is 4 wheel disc all the way around. Does that make any difference? Thank you!
Re: Question on Honda brake fluid condition. [Re: Chris B.] #4496587
08/24/17 01:26 AM
08/24/17 01:26 AM
workbench CZ-USA KS KC
Marco620 Offline
Marco620  Offline
Gonna change mine to either Motul or Ate Super Blue. Mine has stayed clear...only thing I got is a Skunk2 reservoir cover on top.
15' Civic 1.8 i-vtec 222,222+ mi Redline oil/cvt fluid & Archoil9100
Just say no to drugs, union made cars and amsoil.
Son of a Navy Corpsman. Support vets!
Re: Question on Honda brake fluid condition. [Re: Chris B.] #4496591
08/24/17 01:38 AM
08/24/17 01:38 AM
NorCal
Seventh Offline
Seventh  Offline
NorCal
Doesn't matter. The point is, the fluid in the reservoir doesn't get subjected to any stressors besides the potential for moisture contamination.
The fluid in the actual brake components is subjected to your nuclear hot brakes, which causes the fluid to deteriorate. Moisture also causes deterioration of the fluid boiling point and possible corrosion of components.
Re: Question on Honda brake fluid condition. [Re: Chris B.] #4496674
08/24/17 07:01 AM
08/24/17 07:01 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
I would recommend going to two years, like the rest of the industry. My'12 Accord was done by the dealer only half way, the front portion of,the reservoir was clear but the back half cloudy. My guess is they just sucked out what they could and just refilled without cracking a bleeder.
My '14 Accord was under 10k miles when I got it and the fluid at the 3-year mark was nasty. Cloudy with chunks, like you said. I changed it then traded it in shortly after.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Question on Honda brake fluid condition. [Re: Chris B.] #4496714
08/24/17 08:02 AM
08/24/17 08:02 AM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
Are you sure you are getting a full flush? I read few times that a lot of dealers just siphon out the reservoir, refill and call it a flush.
I don't recall having a cloudy looking brake fluid in my cars, even after 3-4 years. It usually has a darker color, like a black tea, but it's clear.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: Question on Honda brake fluid condition. [Re: Chris B.] #4496736
08/24/17 08:27 AM
08/24/17 08:27 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
As far as the fluid in the reservoir , buy a $ 2 turkey baster at Walmart & suck all that you can from the reservoir . Fill with new fluid . Go drive it .
Repeat as many times as you wish .
But , I do not call this a flush .
Wyr
God bless
Re: Question on Honda brake fluid condition. [Re: Chris B.] #4496737
08/24/17 08:28 AM
08/24/17 08:28 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
From the reservoir to the nipple, at all four corners.
Anything else is just a waste of time.
Cable ties should hold it
Re: Question on Honda brake fluid condition. [Re: Chris B.] #4496758
08/24/17 08:43 AM
08/24/17 08:43 AM
N.H, U.S.A.
ARCOgraphite Online content
ARCOgraphite  Online Content
N.H, U.S.A.
You have a leak on the MS reservoir lid? That is just under the windscreen base were water might get at it. Check you underhood water management at the HVAC air inlet screens; You might have organic material blocking water drainage.
No cloudy fluid ever seen (ex maybe in a slave hanging out in the slush).
Recall DOT 3 fluid is hygroscopic.
2019 VW Jetta S,6M OCI#0 2103mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Question on Honda brake fluid condition. [Re: Chris B.] #4496878
08/24/17 11:00 AM
08/24/17 11:00 AM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
DOT 3 or DOT 4
Re: Question on Honda brake fluid condition. [Re: Olas] #4496912
08/24/17 12:02 PM
08/24/17 12:02 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Yes, this. The gravity bleed went very well on my G37. I never believed it could work before, and regret a lot of wasted years doing things the hard way now. smile
Plain, simple Garak.
Re: Question on Honda brake fluid condition. [Re: Chris B.] #4497231
08/24/17 06:38 PM
08/24/17 06:38 PM
Colorado
Chris B. Offline OP
Chris B.  Offline OP
Colorado
Appreciate the help gentleman! So would any amount of "cloudy" fluid mean the fluid is bad or "worn out"? I flushed out the last time 2 years ago and it was very cloudy but still amber in color. Can brakes worked great still.
Re: Question on Honda brake fluid condition. [Re: Yah-Tah-Hey] #4497232
08/24/17 06:39 PM
08/24/17 06:39 PM
Colorado
Chris B. Offline OP
Chris B.  Offline OP
Colorado
Originally Posted By: HosteenJorje
DOT 3 or DOT 4
In my Honda? I'll have to check the owners book when I get back to the car. Not sure off the top of my head.
Re: Question on Honda brake fluid condition. [Re: Chris B.] #4499979
08/28/17 03:18 AM
08/28/17 03:18 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
Cloudiness in the fluid is NOT there in the bottle, only in the car. This shows the fluid is being contaminated after being poured into your reservoir. Contaminated fluid should always be drained and replaced with fresh.
