Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
Interesting FaceBook argument
by ad_infinitum. 03/18/19 04:36 PM
2000 Silverado Power Steering Pump
by Gito. 03/18/19 04:35 PM
New Full Synthetic Oil from Dollar General
by TheLawnRanger. 03/18/19 04:31 PM
Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
MadMikesMech, Indyfordfan, toplscuda, swrve, TomRx
67549 Registered Users
114 registered members (2012AccentSE, 853okg, Astro14, ad_infinitum, addyguy, Ben Boyle, 13 invisible), 2,376 guests, and 62 spiders.
Topics286,023
Posts4,900,991
Members67,549
Most Online2,967
Mar 10th, 2019
Best oil filter wrench for 2016 Camry #4496314
08/23/17 06:04 PM
08/23/17 06:04 PM
Georgia
Electromotive Offline OP
Georgia
My dad recently purchased a used 2016 Camry, which I will be doing the oil changes. Does anyone have any recommendation as far as a filter wrench for this car? Also, I have never changed a cartridge type oil filter. Any tips/advice would be appreciated .
Re: Best oil filter wrench for 2016 Camry [Re: Electromotive] #4496319
08/23/17 06:09 PM
08/23/17 06:09 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
It is not that bad.
A lot of Youtube video on it since Toyota uses the Cartridge Oil Filter since around 2007 or so in various different engines.
As for filter, there are lot of variety also.
I bought the Assenmacher brand from Amazon.
Some of them (cheap ones) tends to crack during use.
You may also get the hose connector to drain the filter, also available from a vendor @ Amazon.
Although, it is not necessary just a little bit more messy.
  • 2017 Toyota Sienna
Re: Best oil filter wrench for 2016 Camry [Re: Electromotive] #4496320
08/23/17 06:09 PM
08/23/17 06:09 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
X2 laugh
Thick oil is better grin2
Re: Best oil filter wrench for 2016 Camry [Re: Electromotive] #4496322
08/23/17 06:11 PM
08/23/17 06:11 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Hopefully it was properly torqued when was installed. Only vehicle I have that always needs a wrench is the big trucks and just can't get a good hold on them even when I just give them a hand torque. Good luck
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Best oil filter wrench for 2016 Camry [Re: Electromotive] #4496338
08/23/17 06:30 PM
08/23/17 06:30 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
https://www.amazon.com/Motivx-Tools-Toyota-Filter-Engines/dp/B00XTAGHU0/ref=sr_1_1?s=automotive&ie=UTF8&qid=1503531003&vehicle=2014-76-1027-269--40-6-5-7937-3093-1-1-2939-213-3-0&sr=1-1&ymm=2014%3Atoyota%3Asienna
Some of the other that depend only on the hex to loosen the canister will get stuck on the canister you need to whack them a few times to get them off.
When I tighten mine i only do it by hand just like a oil filter. I give it everything my hand can generate but never put a wrench to tighten it up. The large O-ring will keep it from unscrewing.
Then getting it off next time is just a little nudge to loosen it.
The first time I got my used 2014 sienna I could not get it off at all. I saw the dealership used what looked like a pipewrench to get it off. I used my beam torque wrench as a breaker bar to get some leverage and it was over 100ft/lbs to break! now I can get it off with a 12" socket wrench. (SMH)
Re: Best oil filter wrench for 2016 Camry [Re: Electromotive] #4496379
08/23/17 07:16 PM
08/23/17 07:16 PM
NC
BigD1 Offline
BigD1  Offline
NC
CTA Tools 2475 is a beast. It's pricey. Forged 6140 steel plays a nice tune while the oil is draining.
CTA Tools 2475 64mm x 14mm Extra HD Toyota/Lexus Oil Filter Wrench
1992 Toyota Pickup--PYB 10W-30--Fram PH3614
Re: Best oil filter wrench for 2016 Camry [Re: Electromotive] #4496390
08/23/17 07:24 PM
08/23/17 07:24 PM
N.C.
gman2304 Offline
gman2304  Offline
N.C.
Assenmacher...from Amazon.
Re: Best oil filter wrench for 2016 Camry [Re: Electromotive] #4496408
08/23/17 07:48 PM
08/23/17 07:48 PM
MN
WillsYoda Offline
WillsYoda  Offline
MN
I highly recommend this Motivx. It is priced well and people love it. I use it and it is solid...
Re: Best oil filter wrench for 2016 Camry [Re: bioburner] #4496416
08/23/17 07:54 PM
08/23/17 07:54 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
You must be a gorilla to remove the Camry cartridge by hand. It's on very tight.
Tips: Use a 1/2 inch ratchet to take it off and put it back on. You'll need the leverage. I tighten it until the housing stops turning. It stops abruptly.
I don't bother with the lower small drain plug. Just remove and replace the cartridge and treat it more or less like a regular can.
Replace the bigger o-ring each time. I lube the o-ring with oil. Don't know that matters. Make sure you put the o-ring in the correct groove.
Biggest issue I have is getting the filter wrench off the canister when I'm done. It takes a few good wacks with the ratchet handle to get it off.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Best oil filter wrench for 2016 Camry [Re: Electromotive] #4496498
08/23/17 09:28 PM
08/23/17 09:28 PM
South Louisiana
Soggydog Offline
Soggydog  Offline
South Louisiana
I'll second the Assenmacher. Cast aluminum. I bought it in 2012 when we bought the camry. I used it for the 10th time last week. I store it in an empty toyota oil filter box so i can always spot it among the 75 cent purolators I got at walmart on clearance.
Currently running...
2011 Ford F250 4x4 6.7L, 2011 Toyota Camry SE 2.5L, 2002 Dodge Caravan 3.3L,
2012 Honda Rincon,2012 Honda Rancher AT,09 Honda Trx90
Re: Best oil filter wrench for 2016 Camry [Re: Electromotive] #4496558
08/23/17 11:31 PM
08/23/17 11:31 PM
Connecticut 06033
oilmutt Offline
oilmutt  Offline
Connecticut 06033
Please dont waist your time and money/buy it from the dealer for $15.00,ask them for a 20% internet discount!The quality is their and it will fit correctly.
'05 Chevy Malibu 6cyl,119k, Syn. Oil (owned)
'16 Toyota Camry,4cyl 25k Syn oil (leased)
'92 Ford Tempo ,4cly 26k Conv oil (managed)
