UOA on BMW 0w-30 on BMW F10 M5 with S63 TVDI V8
by AirBull. 04/25/19 05:08 PM
What to drink with trail mix?
by das_peikko. 04/25/19 04:55 PM
And This Folks, Is How You Buy Guns
by billt460. 04/25/19 04:43 PM
Tire leak with new wheels. What would YOU do?
by Lolvoguy. 04/25/19 04:20 PM
Red battery light came on, Ford E150.
by laserred96gt. 04/25/19 03:34 PM
2019 NFL Draft
by JustN89. 04/25/19 03:10 PM
Crabgrass!!!!
by gregk24. 04/25/19 03:06 PM
Drain and fill 08 Kia Rio.
by Jetsfan421. 04/25/19 02:59 PM
Cut Open - Mazda OEM @ 7,000kms
by mcwilly. 04/25/19 02:50 PM
Fender bender...headache!
by gregk24. 04/25/19 02:44 PM
Cerwin Vega 10" Subwoofers - $14.37 Each
by Greg L. 04/25/19 01:53 PM
Blain's Farm & Fleet synthetic oil $2.19/qt.
by BrewCityR. 04/25/19 01:24 PM
F1 - 2019 Azerbaijan Grand Prix
by gofast182. 04/25/19 12:00 PM
Installing an additional fuel filter?
by Ed_Flecko. 04/25/19 11:46 AM
Honda self propel only spining left wheel
by Tundragod. 04/25/19 11:38 AM
Cabin Filter Pics (15k miles)
by DoubleWasp. 04/25/19 11:30 AM
LiquiMoly Jectron Fuel Injection Cleaner
by Ddub. 04/25/19 11:12 AM
servicing a 2018 GM 6speed transmission
by gotnogunk. 04/25/19 10:23 AM
Went 100% debt free today
by BeerCan. 04/25/19 10:04 AM
Wood9913, Lydia, jdar805866, PreludeDenarius, Ayodejidj
67902 Registered Users
116 registered members (240_Ed, AirBull, Andygold, ad_infinitum, Amenhotep, 01rangerxl, 11 invisible), 2,164 guests, and 20 spiders.
Topics288,045
Posts4,939,805
Members67,902
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Follow Inside Door Plaque Tire Pressure ? #4496226
08/23/17 03:58 PM
08/23/17 03:58 PM
GA.
ChrisD46 Offline OP
ChrisD46  Offline OP
GA.
Do you follow the inside door plaque for OEM vehicle recomended tire pressure - or do you prefer to go a little over by a few pounds ?
2017 Hyundai Sonata 2.4L GDI 4 cylinder
2010 Hyundai Elantra 2.0L 4 cylinder
2007 Kia Sedona 3.8L 6 cylinder
Re: Follow Inside Door Plaque Tire Pressure ? [Re: ChrisD46] #4496235
08/23/17 04:03 PM
08/23/17 04:03 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
I go a little over. I like the slightly firmer ride, and notionally it gives better load capacity and fuel economy.
Ive never had issues with longevity, our tires age out with 50k+ on them and plenty of tread.
Re: Follow Inside Door Plaque Tire Pressure ? [Re: ChrisD46] #4496237
08/23/17 04:07 PM
08/23/17 04:07 PM
GA.
ChrisD46 Offline OP
ChrisD46  Offline OP
GA.
Typically OEM reccomendations for tire pressure are for most comfortable ride - I usually go about 4 lbs. over when tires are cold .
Re: Follow Inside Door Plaque Tire Pressure ? [Re: ChrisD46] #4496256
08/23/17 04:39 PM
08/23/17 04:39 PM
Plano, TX
dparm Offline
dparm  Offline
Plano, TX
Yes, because this is something that's thoroughly tested. The OEMs don't just pull a number out of their [censored]. Being off by 1 or 2 psi is fine, but I wouldn't intentionally over or underinflate -- big safety risk.
Many manufacturers actually have a matrix on those plaques in case you will be running with a full load and/or an alternate snow tire.
2017 Chevrolet Corvette Grand Sport
Re: Follow Inside Door Plaque Tire Pressure ? [Re: ChrisD46] #4496265
08/23/17 04:49 PM
08/23/17 04:49 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Yes-No. The Ford dually is a strange bird. The fronts I run what they say but the rears they suggest 45? Local tire shop said no way if your mostly hauling a 5th wheel so close to the sidewall of 80.
Everything else is at or now with falling temps a couple over. The vehicle that showed the most issue with not following guide was the Chevy HHR. If over, the center would wear, if low the mileage would take a beating
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Follow Inside Door Plaque Tire Pressure ? [Re: ChrisD46] #4496277
08/23/17 05:07 PM
08/23/17 05:07 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
It all depends on what you are doing ... Plain old street driving with OEM sized tires - yeah sure follow the door decal.
Going off road with oversized tires, low pressure. Going rock crawling, over pressure.
Re: Follow Inside Door Plaque Tire Pressure ? [Re: ChrisD46] #4496295
08/23/17 05:23 PM
08/23/17 05:23 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
I either do the exact amount or a little over. I found more than 2 PSI over makes the ride too harsh (although I get great mileage). Lower than what they recommend makes my mileage plummet. What they recommend seems to be the best compromise between harshness and mileage.
2015 Civic LX Coupe
Re: Follow Inside Door Plaque Tire Pressure ? [Re: ChrisD46] #4496316
08/23/17 06:06 PM
08/23/17 06:06 PM
Lima, Ohio, USA
earlyre Offline
earlyre  Offline
Lima, Ohio, USA
For some reason my dad insists on keeping the tires on Mom's Taurus at 38psi. Door placard says 32. If it gets below 35 (she does have 1 SLOOW leaker) he says it "steers like a log wagon"
I keep my same year sable at 35, and it drives just fine....
Mine:
13 Ford C-MAX hybrid: MC 5w20, & FL910s (in theory)
Re: Follow Inside Door Plaque Tire Pressure ? [Re: ChrisD46] #4496318
08/23/17 06:08 PM
08/23/17 06:08 PM
Southeast Alabama
SrDriver Offline
SrDriver  Offline
Southeast Alabama
I run one or two pounds over recommended pressure. Check in morning before vehicle is driven and top off. When on a trip freeway driving add about 3 pounds over making sure not that I exceed the max cold pressure warning on the side of the tire.
Re: Follow Inside Door Plaque Tire Pressure ? [Re: ChrisD46] #4496332
08/23/17 06:23 PM
08/23/17 06:23 PM
OBX & Central FL
NormanBuntz Offline
NormanBuntz  Offline
OBX & Central FL
Plus 1 or 2 pounds.
2017 Honda Odyssey SE, 19K
2013 Honda Accord LX, 61K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: Follow Inside Door Plaque Tire Pressure ? [Re: ChrisD46] #4496342
08/23/17 06:35 PM
08/23/17 06:35 PM
San Antonio, Texas
sasilverbullet Offline
San Antonio, Texas
I always go with the door placard.
03 Porsche 911 Liqui Moly Leichtlauf High Tech 5w-40 & Mahle filter
14 Honda Accord 4dr EX-L 4cyl-M1 0W-20 & WIX XP
02 Chevy 5.7L van-GTX HM 10W-40 & WIX filter
Re: Follow Inside Door Plaque Tire Pressure ? [Re: ChrisD46] #4496380
08/23/17 07:16 PM
08/23/17 07:16 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
3-5 psi over so I don't have to check them as frequently. When I had all 4 tires leaking around the rotting rims on my last daily driver, I put them 8 psi over and still had to refill them every few weeks around 28 psi.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Follow Inside Door Plaque Tire Pressure ? [Re: ChrisD46] #4496406
08/23/17 07:46 PM
08/23/17 07:46 PM
Port Aransas, TX
Stevie Offline
Stevie  Offline
Port Aransas, TX
Overinflating the recommended pressure on the front on my wife's Elantra makes the car wander and kind of skittish on the highway. Correct pressure and the car just tracks nice and true without any input.
My SLK just rides and handles nicer with the recommended pressures.
Re: Follow Inside Door Plaque Tire Pressure ? [Re: ChrisD46] #4496468
08/23/17 08:48 PM
08/23/17 08:48 PM
NC
Cgreene221 Offline
Cgreene221  Offline
NC
Normal on road driving my rule at the shop is 3-4 psi over door recommendation
Re: Follow Inside Door Plaque Tire Pressure ? [Re: ChrisD46] #4496594
08/24/17 01:52 AM
08/24/17 01:52 AM
Texas
FZ1 Offline
FZ1  Offline
Texas
Never more than the placard +1 or -1 for me. I equalize the pressure on all 4 tires. The dealer/tire people don't usually get all 4 exact.
Page 1 of 3 1 2 3
