Diagnosing gas furnace
by Oro_O. 09/19/18 01:16 PM
Let's talk dipsticks and oil capacity
by csandste. 09/19/18 12:32 PM
Here's my fram filter at least 18 thousand miles
by Ablebody. 09/19/18 11:31 AM
How much is my truck worth?
by wallyuwl. 09/19/18 09:56 AM
Looking for Spray Detailer Advice
by knerml. 09/19/18 09:51 AM
LUBRICATION ENGINEERS LE1605 NO LONGER GL5!?
by dedonderosa. 09/19/18 09:28 AM
by dedonderosa. 09/19/18 09:26 AM
When you're too old to drive
by Speak2Mountain. 09/19/18 09:22 AM
Another VW Thread
by Zee09. 09/19/18 09:21 AM
Tremec HP MTF - No more ATF?
by ABomb369. 09/19/18 09:02 AM
Is 0W weight oil the perfect oil?
by Baas95. 09/19/18 08:01 AM
2014 Durango ZF8 transmission fluid recommendation
by MoparMan12. 09/19/18 06:45 AM
Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
101 registered members (Ablebody, Abax25, 2004tdigls, 53' Stude, 13 invisible), 1,809 guests, and 32 spiders.
Topics290,668
Posts4,848,001
Members66,011
Most Online3,590
Jan 24th, 2017
Adding ZDDP plus to CK-4 oil??? #4496193
08/23/17 03:06 PM
08/23/17 03:06 PM
South Florida
Invasivore Offline OP
South Florida
Just to be safe, would one 4 ounce bottle of ZDDP plus in 15 quarts of CK-4 oil raise the Zinc and Phosphorus levels to CJ-4 standards??? I don't know how many PPM one bottle will raise the levels.
Re: Adding ZDDP plus to CK-4 oil??? [Re: Invasivore] #4496227
08/23/17 03:59 PM
08/23/17 03:59 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
I'm nowhere near the most knowledgeable party on this, but assuming that one bottle of ZDDPlus is formulated to bring zinc from about 800 PPM to somewhere just under 2,000, wouldn't it raise 15 qts. @ 800 PPM to about 1,200?
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 113K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 169K
'67 Suburban, 350, 331K
Re: Adding ZDDP plus to CK-4 oil??? [Re: Invasivore] #4496234
08/23/17 04:03 PM
08/23/17 04:03 PM
USA
Reddy45 Offline
Reddy45  Offline
USA
Who is spreading this misinformation that CK-4 specifies less zddp?
Re: Adding ZDDP plus to CK-4 oil??? [Re: Reddy45] #4496238
08/23/17 04:12 PM
08/23/17 04:12 PM
South Florida
South Florida
So you are saying the CK-4 oils have higher levels of Zinc and Phosphorus than CJ-4?
Re: Adding ZDDP plus to CK-4 oil??? [Re: Invasivore] #4496244
08/23/17 04:23 PM
08/23/17 04:23 PM
USA
Reddy45 Offline
Reddy45  Offline
USA
Not necessarily. The CK-4 spec does not seem to directly specify lower levels of ZDDP based on what I have seen on the information published on the web. I think a lot of the early CK-4 adopters were foolish enough to rate their oils for BOTH SN and CK-4, and the API SN spec DOES limit ZDDP.
Now.. how the oil companies interpret the spec (and if they are shifting from ZDDP to other anti-wear compounds) is another consideration. A VOA of a CK-4 oil that has less ZDDP than the CJ-4 variant does not directly mean that CK-4 caused that lowering of ZDDP.
Re: Adding ZDDP plus to CK-4 oil??? [Re: Invasivore] #4496247
08/23/17 04:26 PM
08/23/17 04:26 PM
South Florida
South Florida
Then why would Ford's new spec call for a minimum level of phosphorus that supposedly is not met by CK-4 oils?
Re: Adding ZDDP plus to CK-4 oil??? [Re: Invasivore] #4496361
08/23/17 06:52 PM
08/23/17 06:52 PM
USA
Reddy45 Offline
Reddy45  Offline
USA
I'm just saying that the specification and the implementation are 2 different things.
It is not correct to directly assume that CK-4 has inferior wear protection qualities when we haven't had enough quantity or time to judge how the producers meet the spec.
Re: Adding ZDDP plus to CK-4 oil??? [Re: Invasivore] #4496365
08/23/17 06:56 PM
08/23/17 06:56 PM
South Florida
South Florida
I did a calculation off ZDDP Plus' website. I could be wrong but I think 4 ounces will raise Zinc 600ppm and Phosphorus 480ppm at 15 quarts.
Re: Adding ZDDP plus to CK-4 oil??? [Re: Reddy45] #4496366
08/23/17 07:00 PM
08/23/17 07:00 PM
South Florida
South Florida
Yes, I see what you are saying. To achieve the CK-4 spec, some blenders have chose to limit different additives to achieve the result which may or may not be ZDDP.
I think I might try Valvoline premium blue extreme CK-4 since it's on "The List." I will do a VOA, and UOA at 5k, change oil again and try it with Archoil UOA 5k. I have a 6.0 Powerstroke with 170k miles.
Re: Adding ZDDP plus to CK-4 oil??? [Re: Invasivore] #4496394
08/23/17 07:32 PM
08/23/17 07:32 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
There is one thing to watch, and that's how the ZDDP species isn't necessarily the same for a PCMO as for an HDEO. So, as always, one has to watch with what one expects from a ZDDP additive. A formulator would be better able to provide us with details on that.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Adding ZDDP plus to CK-4 oil??? [Re: Garak] #4496924
08/24/17 12:15 PM
08/24/17 12:15 PM
South Florida
South Florida
Yes, I would like to know if adding the bottle of ZDDP will negatively affect film strength, suspension of other additives, and effectiveness of other additives.
Re: Adding ZDDP plus to CK-4 oil??? [Re: Invasivore] #4496972
08/24/17 01:20 PM
08/24/17 01:20 PM
Europe
Ether Offline
Ether  Offline
Europe
If other additives have been substituted in place of ZDDP for CK-4 oils,could this mean that if you added ZDDP to the package, you may have a situation where the additives are forced to compete with each other,resulting in an unbalanced blend,and/or loss of some positive benefits?
Re: Adding ZDDP plus to CK-4 oil??? [Re: Invasivore] #4497434
08/25/17 01:34 AM
08/25/17 01:34 AM
Garak Offline
Garak  Offline
That's a very good question. To you and to Ether, as best as I recall, ZDDP has more than one function as an additive (or more accurately, additives), including not just anti-wear but as an anti-oxidant.
Just like an HDEO isn't an automatic substitute for a race oil for a gasser, I'd suspect a ZDDP additive designed for performance gasoline engines may not turn a lower phosphorus HDEO into a CI-4+ automatically. I wouldn't go so far as to talk about additive clash, but the intended benefits may just not be there.
Heck, as I recall, at least one car journalist (can't remember if it was print or TV off hand) found out the hard way that a ZDDP additive to an ordinary motor oil can at times be a poor substitute for a dedicated break in lubricant. I don't think we'd find that by running a CK-4 lubricant with a ZDDP additive, but there really isn't any evidence that the additive is needed in the first place.
For those who are worried, I suppose Ford's list is a good place to start. Of course, we are seeing CK-4 only oils, rather than dual rated options, too. I certainly understand everyone's concern. A diesel engine going south isn't like tossing in a cam and set of lifters into a 305 for $200 and an afternoon of work. However, sooner or later, CK-4 will be the only readily available product, and that's probably the case in some places by now.
Re: Adding ZDDP plus to CK-4 oil??? [Re: Invasivore] #4503505
08/31/17 03:28 PM
08/31/17 03:28 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
I'm thinking about dosing up my next fill of RT6 in the Dodge with a ZDDP additive to see if it affects the Iron wear rate. I'll have two complete OCI's of CK4 RT6 to compare it to.
Of course, I could go back to my old UOA's and compare Iron wear metals of CK4 RT6 to CJ4 RT6...
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
