New Struts and Springs
by Mathew_Boss. 04/21/19 05:36 PM
Float chargers?
by buck91. 04/21/19 05:32 PM
Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
103 registered members (ammolab, 2015_PSD, alphadog, AdditiveOCD, 53' Stude, 2009Edge, 11 invisible), 2,028 guests, and 28 spiders.
Topics287,854
Posts4,935,613
Members67,865
Most Online2,967
Mar 10th, 2019
A matter of reduced pressure. #4495878
08/23/17 07:40 AM
08/23/17 07:40 AM
Va.
Piston_slap Offline OP
Va.
On my Ford van I have a decal in the door jam listing the proper size of tire and recommended air pressure.(235*75*15) I run that tire size and have always kept the pressure at the recommended 41psi. I recently had the tires rotated and the shop changed the pressure to 32psi. I noticed the softer ride but was curious what the lower pressure would do to tire wear and longevity? The title shows the weight to be 5400lbs so I don't require the max load capacity of the tires. I value whatever mpg gains I can get. What would you do?
1994 Ford Econoline w/302 & 4R70W
Valvoline 10W-40, Motorcraft FL1
Isotope U235
Re: A matter of reduced pressure. [Re: Piston_slap] #4495890
08/23/17 07:49 AM
08/23/17 07:49 AM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
Well the tire shop is just helping you to your next shopping experience in their store. I always check my tire pressure right after I leave from having my tires rotated.
2004 Corolla 130880
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: A matter of reduced pressure. [Re: Piston_slap] #4495917
08/23/17 08:15 AM
08/23/17 08:15 AM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Lower pressure will result in slightly lower mpg as the rolling resistance increases.
I've got some experience with tire pressure changes, and instead of even wear, you will likely see the outside of the front tires begin to wear more rapidly than the center. This is more noticeable in heavier vehicles.
The bulk of my experience is from 2000 and 2004 Jeep Grand Cherokees of around 4000 pounds. I bought one with 72k and the other with 18k; both had badly worn outer edges on the front tires, and were inflated to the factory specified 30psi. I immediately went to max rated pressure (35) and kept those tires awhile, until they started washing out in the wet. Upon replacement my new tires were rated for 44psi max; after some experimentation I found that 40-42psi was a pressure that gave even wear as well as noticeably crisper handling.
The ride was not a cushy as it had been before, but for me it was worth it to have tires that kept their wet handling capabilities their entire life and lasted 60k rather than 35k.
You're going to get a lot of opinions on this one, many of which will preach to use the placarded pressure.....so popcorn Ultimately test different pressures and decide for yourself.
Agreed!
Thick vs Thin test: 15k / 43k miles complete
Re: A matter of reduced pressure. [Re: Piston_slap] #4495938
08/23/17 08:48 AM
08/23/17 08:48 AM
Michigan
khittner Offline
khittner  Offline
Michigan
Your door jamb decal may state that 41psi is the max recommended pressure for the vehicle's max load, or it may simply be a "recommended pressure". If the former, less pressure for less-than-maximum loads may be fine for the longest/most even tire wear. If the latter, pump them back up to Ford's recommended pressure. My local Discount Tire routinely over-fills my tires at rotations on the assumption that I, like most, will pay no attention to their handiwork, and they assume that there will be enough seepage through the alloy wheels over time to bring the pressure down, something 98% of their customers never check between rotations. Most folks don't read the decals on their vehicles.
Re: A matter of reduced pressure. [Re: Piston_slap] #4495945
08/23/17 08:50 AM
08/23/17 08:50 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
The tech working on the vehicle is just lazy. Probably sets ALL tires to 32#. We have techs here at the dealer that do the same thing. Drives me mad.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: A matter of reduced pressure. [Re: Piston_slap] #4495950
08/23/17 08:55 AM
08/23/17 08:55 AM
MN
oil_film_movies Offline
MN
True, tire neglect is a problem out there.
Your 41 psi is made for maximum loads with max speeds on that van.
Going down to 32 psi is a bit excessive though. The tire shop was lazy.
I'd allow maybe as low as 35 psi IF you can be sure you aren't using that van to max capacity, and keeping your speeds down to 75 mph max at the lower 35 psi.
If you are loading the van up to max capacity, do use the 41 psi standard.
Re: A matter of reduced pressure. [Re: Piston_slap] #4495954
08/23/17 08:59 AM
08/23/17 08:59 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Tire stores techs are not super trained. They just bang on tires and move on to next car.
2015 Ford F250 w/Powerstroke
Re: A matter of reduced pressure. [Re: Piston_slap] #4495964
08/23/17 09:12 AM
08/23/17 09:12 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Are these LT tires? If so you need to run them a bit higher than 32 psi. For P rated tires I find you can up a bit to 35-36 psi without affected NVH too much, so give that a try.
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: A matter of reduced pressure. [Re: Piston_slap] #4496043
08/23/17 11:22 AM
08/23/17 11:22 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
What I was about to say light truck tires are a different ball of wax than P-metric. Whats the sidewall max pressure of the new ties? 55lbs/sqin gauge?
What tonnage is the van and what do you carry?
Shaggin wagon or work truck?
2019 VW Jetta S,6M OCI#0 2103mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: A matter of reduced pressure. [Re: Piston_slap] #4496047
08/23/17 11:24 AM
08/23/17 11:24 AM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Inflate to 41 psi. You don't want your van to imitate the Explorers of the 90s and roll over from a blowout.
2015 Hyundai Sonata 2.4L 93k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: A matter of reduced pressure. [Re: Piston_slap] #4496156
08/23/17 02:05 PM
08/23/17 02:05 PM
Oklahoma
CELICA_XX Offline
CELICA_XX  Offline
Oklahoma
Go back to 41 for sure
15 Toyota Prius - M1 EP 0w20 SN+
06 Acura MDX - Valv MaxLife Syn 5w20 SN+
02 Toyota ECHO - Valv MaxLife Syn 5w30 SN+
97 Lexus LX450 - M1 EP HM 5w30 SN+
93 Lexus LS400 - Valv MaxLife Syn 5w30
Re: A matter of reduced pressure. [Re: CELICA_XX] #4496294
08/23/17 05:23 PM
08/23/17 05:23 PM
Nevada, USA
gaijinnv Offline
gaijinnv  Offline
Nevada, USA
Your Econoline came with P235/75R15/XL 108S tires and a recommended Cold Tire Inflation Pressure of 41psi Front/Rear.
For best overall performance, and safety, you should run them at the specified 41psi.
The tire store folks you dealt with do not have a clue ...
Of course, if they put a P-Rated tire that was not XL on, then you are really in trouble - there is no way to inflate a non-XL P-Metric tire to sufficient pressure to meet the minimum load requirements for your Econoline.
HTH
USN NAVSECGRU 1970-1974
Re: A matter of reduced pressure. [Re: Nick1994] #4496593
08/24/17 01:47 AM
08/24/17 01:47 AM
Texas
FZ1 Offline
FZ1  Offline
Texas
This^^^^. Go back to 41.
