Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
jefe_de_estado, CM613, Geardaddies, 01ws666, ariefnrst
66660 Registered Users
107 registered members (bbhero, 53' Stude, BigShug681, ammolab, Aero540T, 13 invisible), 1,848 guests, and 38 spiders.
Topics294,992
Posts4,925,594
Members66,660
Most Online2,553
Oct 27th, 2018
Best lube for disassembled door locks? #4495743
08/22/17 11:31 PM
08/22/17 11:31 PM
Denmark, Europe
LucasDK Offline OP
LucasDK  Offline OP
Denmark, Europe
Hi,
I am about to restore my car which means I have fully disassembled all parts. It also means I have all 5 lock cylinders as single units in my hand.
I do understand many people suggest graphite or some dry lube for installed locks as some sort of quick fix if there are any problems.
I am looking for a long term solution because now I have a chance of providing the best lubrication while the locks are out.
Can anyone recommend a solution?
I was thinking of fully submerging all lock cylinders in a synthetic 0W40 engine oil. A 0W40 should stay thin at cold temperatures, the synthetic oil should never gum up as a mineral oil. I would let it drip off and occasionally wipe the excess off until I will install them again in 6 months.
Lucas
Toyota Hiace 2,4D (2L engine)
Toyota Corolla AE92, (4A-FE engine)
Ford Model A (3,4 liter engine)
Re: Best lube for disassembled door locks? [Re: LucasDK] #4495744
08/22/17 11:36 PM
08/22/17 11:36 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: Best lube for disassembled door locks? [Re: LucasDK] #4495751
08/22/17 11:57 PM
08/22/17 11:57 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
Wd40
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Best lube for disassembled door locks? [Re: LucasDK] #4495791
08/23/17 03:51 AM
08/23/17 03:51 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Not sure Id want oil in there. It will get gummy over time and hold dirt/grit.
Thought silicone or graphite were the right options. Certain rub points internal to the door skin but external to the assembly might get a thin coat of grease like one of the molykote options, shin etsu, etc.
Re: Best lube for disassembled door locks? [Re: FermeLaPorte] #4495804
08/23/17 04:37 AM
08/23/17 04:37 AM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Originally Posted By: FermeLaPorte
Wd40
Don't use WD-40. It will attract dirt and dust and gum up your locks. I've used white lithium grease with good results.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Best lube for disassembled door locks? [Re: JC1] #4495902
08/23/17 07:03 AM
08/23/17 07:03 AM
Va.
Piston_slap Offline
Piston_slap  Offline
Va.
Wd40
What allows white lithium grease to repel dirt and dust? ???
1994 Ford Econoline w/302 & 4R70W
Valvoline 10W-40, Motorcraft FL1
Isotope U235
Re: Best lube for disassembled door locks? [Re: LucasDK] #4495916
08/23/17 07:14 AM
08/23/17 07:14 AM
midwest
JamesBond Online content
JamesBond  Online Content
midwest
I use Remington dri-lube on all my locks.
Re: Best lube for disassembled door locks? [Re: LucasDK] #4495920
08/23/17 07:18 AM
08/23/17 07:18 AM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
I've rebuilt all the lock cylinders on my BMW and a couple on my Toyota, and the thing that works best for me is the little tube of lubricant BMW gives you when you buy a wafer set. I've been unable to find it separately from the kits and I'd like to find something similar. I don't know what that grease is exactly but it works great down to low temperatures and the cylinders never get stiff or gooey.
Originally Posted By: LucasDK
Hi,
1994 BMW 530i, 238K
1996 Honda Accord, 266K
1999 Toyota Sienna, 407K
2000 Toyota ECHO, 280K
Re: Best lube for disassembled door locks? [Re: kschachn] #4495931
08/23/17 07:41 AM
08/23/17 07:41 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Hi,
Honda provides a similar grease. It is a very, very light silicone grease.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Best lube for disassembled door locks? [Re: LucasDK] #4496010
08/23/17 09:14 AM
08/23/17 09:14 AM
PENNSYLVANIA
JeepWJ19 Offline
JeepWJ19  Offline
PENNSYLVANIA
I'm not too familiar with grease, but what about something like Napa SylGlyde?
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
Re: Best lube for disassembled door locks? [Re: LucasDK] #4496063
08/23/17 10:54 AM
08/23/17 10:54 AM
Modesto,CA
mehullica Offline
mehullica  Offline
Modesto,CA
My friend is a professional locksmith for the last 30 years & he recommends cleaning all the internals with electrical contact cleaner & using no lubricating products at all. Just keep the keys clean. If the lock has problems already, then use Tri-Flow sparingly.
Re: Best lube for disassembled door locks? [Re: LucasDK] #4496135
08/23/17 12:37 PM
08/23/17 12:37 PM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
I use 5W-30. If I lived in Denmark, I might be tempted to use a lighter grade oil.
Re: Best lube for disassembled door locks? [Re: zzyzzx] #4496155
08/23/17 01:05 PM
08/23/17 01:05 PM
Denmark, Europe
LucasDK Offline OP
LucasDK  Offline OP
Denmark, Europe
For how many years have you been doing that?
Lucas
Re: Best lube for disassembled door locks? [Re: LucasDK] #4496167
08/23/17 01:25 PM
08/23/17 01:25 PM
Virginia
bigt61 Offline
bigt61  Offline
Virginia
GM makes a door lock lube - but they also recommended Mobil 1 as a substitute. My 92 Suburban has a TSB regarding door lock lube. I always used M1 5W-30 on the doors and the ignition - I lube them every 5 years or so.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: Best lube for disassembled door locks? [Re: LucasDK] #4496203
08/23/17 02:22 PM
08/23/17 02:22 PM
California
nthach Offline
nthach  Offline
California
When I lube door locks, I prefer a dry film lube or a PTFE-containing product like Super Lube or Tri-Flow grease.
