Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
65 registered members (Best F100, aquariuscsm, BeerCan, Boomer, Bailes1992, Atesz792, 10 invisible), 1,089 guests, and 36 spiders.
Topics290,928
Posts4,852,600
Members66,055
Most Online3,590
Jan 24th, 2017
Castrol GTX synblend 5w-20 in a Mazda5 2.5? #4495707
08/22/17 11:09 PM
08/22/17 11:09 PM
Oregon
MrQuackers Offline OP
Oregon
The manual only suggests 0w-20 for USA. Vehicle is well beyond warranty concerns.
Master the 1000 yard stare
coffeeMobil 1 USA
Re: Castrol GTX synblend 5w-20 in a Mazda5 2.5? [Re: MrQuackers] #4495732
08/23/17 12:00 AM
08/23/17 12:00 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
I dont see why it wouldnt work fine.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Castrol GTX synblend 5w-20 in a Mazda5 2.5? [Re: MrQuackers] #4495805
08/23/17 05:38 AM
08/23/17 05:38 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
0/20 is for gas mileage in the USA, many mazdas outside USA say 5/30 is ok which is higher then the 5/20 your asking about.
Not that it matters or means anything.
I never used 0/20 in our 2012 Skyactive Mazda because of the above. Also the direct injection engine is known to dump a bit of fuel into the oil and thins it out. (not that it means anything as well)
Once or twice I used 5/20 (and I truly mean once or twice) but last couple years only use 5/30 We live in hot climate. Your good to go with your 5/20. No engine, not just Mazda would care if it was 0/20 or 5/20 or 5/30. Ok, wouldnt hurt if in sub zero weather to use a 0/20 or 5/20 ...
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Castrol GTX synblend 5w-20 in a Mazda5 2.5? [Re: MrQuackers] #4495859
08/23/17 07:21 AM
08/23/17 07:21 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
I'm sure you will be fine on 5W20 or even 5W30.
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
Re: Castrol GTX synblend 5w-20 in a Mazda5 2.5? [Re: MrQuackers] #4496019
08/23/17 10:33 AM
08/23/17 10:33 AM
Kevil,Ky
vwmaniaman Offline
vwmaniaman  Offline
Kevil,Ky
I use 0-20 synthetic oil in mine and wix filter and change at 7.5k. Has worked great. Love the Mazda5 that we have and is just over 90k now.
Don't waste your time on a slipshod repair.
Re: Castrol GTX synblend 5w-20 in a Mazda5 2.5? [Re: MrQuackers] #4496053
08/23/17 11:41 AM
08/23/17 11:41 AM
Oregon
Oregon
Great! Will this synblend be OK for 5k miles?
coffeeMobil 1 USA
Re: Castrol GTX synblend 5w-20 in a Mazda5 2.5? [Re: MrQuackers] #4496061
08/23/17 11:53 AM
08/23/17 11:53 AM
Kevil,Ky
vwmaniaman Offline
vwmaniaman  Offline
Kevil,Ky
I am sure it will be. Just enjoy that simple reliable 2.5L motor.
Re: Castrol GTX synblend 5w-20 in a Mazda5 2.5? [Re: MrQuackers] #4496123
08/23/17 01:22 PM
08/23/17 01:22 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
I remember when 5w30 didn't exist.
Don't worry about the W's until its 20 below.
You should run a straight 20 Spring through Fall smile
and ... Lemme know if you find a good one.
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Castrol GTX synblend 5w-20 in a Mazda5 2.5? [Re: MrQuackers] #4496125
08/23/17 01:24 PM
08/23/17 01:24 PM
N.H, U.S.A.
N.H, U.S.A.
BP 5w20 MagnAtec is Stunning - try it!
Re: Castrol GTX synblend 5w-20 in a Mazda5 2.5? [Re: MrQuackers] #4496565
08/24/17 12:00 AM
08/24/17 12:00 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
I'm afraid 10k miles OCI should be considered for Castrol blend.
Re: Castrol GTX synblend 5w-20 in a Mazda5 2.5? [Re: MrQuackers] #4496575
08/24/17 12:48 AM
08/24/17 12:48 AM
Pennsylvania
K23Turbo Offline
K23Turbo  Offline
Pennsylvania
Nike. Just do it.
I'd run it.
Re: Castrol GTX synblend 5w-20 in a Mazda5 2.5? [Re: alarmguy] #4496606
08/24/17 03:45 AM
08/24/17 03:45 AM
NC
Vladiator Offline
Vladiator  Offline
NC
Mostly true, except for some Hemi 5.7 engines, with cylinder deactivation... Those will even start acting up if you simply use a "thick" 0w20/5w20. That is according to Hemi forums. Never had one myself, yet.
2000 Lexus GS300-361k
1999 Lexus GS400-213k
2006 Toyota Camry-187k
2006 Toyota Highlander Hybrid-125k
2009 Scion xB-120k
2013 VW Tiguan-120k
2009 Toyota Tacoma-60k
Re: Castrol GTX synblend 5w-20 in a Mazda5 2.5? [Re: vwmaniaman] #4496792
08/24/17 09:07 AM
08/24/17 09:07 AM
Virginia
Hoot_r Offline
Hoot_r  Offline
Virginia
Have a 2014 Mazda 5 2.5L with just over 60K; been using 0-20 AFE pretty religiously, but may start looking at something a bit thicker. Love this vehicle; too bad Mazda decided to pull them from the US sales market.
On a different note, does the 2.5 non-Skyactiv engine use direct injection? Might explain some of the knocking of late at low revs under load. Use 87 Costco fuel almost exclusively, but wondering about carbon buildup if this is a DI engine.
