Motorcraft 5/20 Blend - 2015 3.7l TiVTC. (5421Mi)
Scruffy City
2184 total hrs running, 1387 total hrs idle (427/317) 39% Oil Life
Filter
Bumped for comparison to jimbrewer's uoa. I believe that the universal averages were based on 5900 miles when DuckRyder sent his first sample, but don't hold me to it. I'm close, anyway.
From the first sample:
Quote:
Universal averages for this type of Ford engine are based on about 6,700 miles of oil use
I would caution a couple of things about comparisons to mine.
  • The hours may be a better comparator than miles, frequent high idle times for me.
  • This vehicle almost never has a short trip where it does not reach operating temperature.
Thanks DuckRyder. I was a little farther off than I thought. The idle hours don't show up in wear metals, as your iron wear rate is about the same in a ppm per 1k comparison to jimbrewer's. The TBN is reduced by the extra idle time, though.
Thanks for the extra effort/cost of running two different lab tests, too.
