Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
45 registered members (alarmguy, 97K15004WD, 2015_PSD, 87sammy, 77GrandPrix, aba4430, 3 invisible), 706 guests, and 45 spiders.
Topics286,220
Posts4,904,535
Members67,579
Most Online2,967
Mar 10th, 2019
Transmission Fluid Temperature #4495590
08/22/17 08:46 PM
08/22/17 08:46 PM
Canada
Spudislander Offline OP
Canada
I have a 2017 GMC Canyon V6 with towing package. Included in the vehicle information system display is the automatic transmission fluid temperature. However, the owners manual doesn't indicate what temperature is normal nor what is a concern, etc. Therefore, for an uninformed person like me, knowing the transmission fluid temperature is just useless information. Are there any websites or online articles where I might learn enough that the temperature reading might be of some use to me?
Re: Transmission Fluid Temperature [Re: Spudislander] #4495596
08/22/17 08:55 PM
08/22/17 08:55 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
160-200 is great. 200-220 is good. Above 250 is danger zone.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Transmission Fluid Temperature [Re: Colt45ws] #4495612
08/22/17 09:15 PM
08/22/17 09:15 PM
Utah
CKN Offline
CKN  Offline
Utah
With the Siverados and the Dex 6 a warning comes on the driver's information display at 265. GM states that the fluid is has a maximum temperature of 270-and the fluid has been tested up to 285 degrees-however it's the seals in the transmission that will start to degrade at that temperature-so they recommend a maximum temperature of 270 but states the fluid can actually take a lot more heat.
Most Silverado owners find about 80-100 degrees above ambient temperature is where they run.
Re: Transmission Fluid Temperature [Re: Spudislander] #4495626
08/22/17 09:30 PM
08/22/17 09:30 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Transmission Fluid Temperature [Re: Spudislander] #4495656
08/22/17 10:09 PM
08/22/17 10:09 PM
Utah
CKN Offline
CKN  Offline
Utah
That chart is a little conservative......
The issue being is these charts were around BEFORE the new fluids.
Re: Transmission Fluid Temperature [Re: CKN] #4495741
08/23/17 12:20 AM
08/23/17 12:20 AM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
Totally agree, that chart is apparently based on old whale-oil ATF... wink (FYI, not kidding).
Your excellent post above about the seals being the modern limit is what is worth focusing on regading temparture ranges and limits.
Re: Transmission Fluid Temperature [Re: Spudislander] #4495781
08/23/17 03:50 AM
08/23/17 03:50 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
This is useful.
http://www.lubegard.com/pdfs/HeatChart%28AL-516%29.pdf
The "thinking" man's friend.
Re: Transmission Fluid Temperature [Re: Spudislander] #4495962
08/23/17 09:10 AM
08/23/17 09:10 AM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Contrary to what ILI says, the only real way to lower transmission fluid temperatures is to use an external ATF cooler.
If you don't tow or race, I doubt you will have any over-temp problems with the ATF.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Transmission Fluid Temperature [Re: Lubener] #4496073
08/23/17 12:12 PM
08/23/17 12:12 PM
Utah
CKN Offline
CKN  Offline
Utah
Originally Posted By: Lubener
This is useful.
According to that chart my transmission should have blown up on my cross country trip towing my 5,500 pound travel trailer with my Silverado. ANOTHER purposely misleading chart to sell product-or it's just out dated altogether.
Re: Transmission Fluid Temperature [Re: CKN] #4496112
08/23/17 01:09 PM
08/23/17 01:09 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
This is useful.
You are probably doing 20k mile fluid changes too. All you offer is your outdated opinion for what it's worth.
Re: Transmission Fluid Temperature [Re: Lubener] #4496255
08/23/17 04:39 PM
08/23/17 04:39 PM
Utah
CKN Offline
CKN  Offline
Utah
This is useful.
Nope........personal experience and 50,000 mile intervals. And we can disagree on the value of my opinion. As I am disagreeing with yours.
If you don't like my posts they have a"block feature" on BITOG!
Re: Transmission Fluid Temperature [Re: Spudislander] #4496278
08/23/17 05:07 PM
08/23/17 05:07 PM
NY, NY
NYEngineer Offline
NYEngineer  Offline
NY, NY
I have a 2009 Suburban. It has the six speed automatic.
Since I had nothing but trouble with the 4L60E in my older Yukon, I had the trans in the Suburban serviced by the shop I've been using for years immediately upon purchasing. The truck had 9,000 miles on it when I got it.
I did it again at around 55,000 and again at 115. At 115,000, the trans fluid was a little burnt. A few weeks ago, truck had around 139,000 miles, I checked the fluid before a long trip and it was burnt again. I went to the shop, the owner looked at it and suggested a flush and a service. I suggested adding an external cooler. I had the truck for a week prior to the trip and I monitored the trans temp and the condition of the fluid. It was fine. Temps were awesome. 147 on the highway doing 70 on a 74 degree day.
Drove down to Florida. Saw trans temps as high as 190 in bumper to bumper traffic in 99 degree weather. As soon as traffic started moving it would creep down to 178-184.
Strangest thing was on the way home, as soon as we crossed from Florida into Georgia, the air temp dropped ten degrees and the trans temp down along with it to around 168.
Fluid has been in good shape. I'm pretty happy. I just bought a house and really don't want to drop 3500 bucks on a rebuild at the moment.
When Pat (the trans shop owner) serviced the trans, he said the inside looked better than the fluid would have hinted. That's why I went ahead and took it on the trip.
I only wish I had ever monitored the temp before the cooler install.
Re: Transmission Fluid Temperature [Re: CKN] #4496597
08/24/17 02:16 AM
08/24/17 02:16 AM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
This is useful.
I think it is simply outdated and like many other charts, it is based on the older mineral oil Dex/Merc and older PI formulas.
Re: Transmission Fluid Temperature [Re: Spudislander] #4496659
08/24/17 06:35 AM
08/24/17 06:35 AM
Margate England
Claud Offline
Claud  Offline
Margate England
just about every AT equipped car I've owned shifts smoothly from cold. I know too hot will lead to a transmissions repid demise, but can you overcool a transmission to the extent it also hurts it?.
Claud.
Re: Transmission Fluid Temperature [Re: Spudislander] #4496661
08/24/17 06:35 AM
08/24/17 06:35 AM
Margate England
Claud Offline
Claud  Offline
Margate England
Claud.
