Shell vs Sunoco
New Jersey
I was hoping someone might chime in and help me compare these two Brands of oil.
Shell Conventional vs Sunoco Ultra Synthetic Blend
Thanks for any help,
TDX
Product Code 5903 5913 5923
SAE J300 Vis Grade 5W-20 5W-30 10W-30
Viscosity, cSt @ 100 °C 8.5 10.8 10.8
Viscosity, cSt @ 40 °C 47 67 68
Viscosity, CCS, cP @ -30°C6,200 (-30) 6,000 (-30) 4,500 (-25)
Viscosity Index 150 160 150
Flash Point, °C 200 200 200
Pour Point, °C -41 -41 -45
NOACK, wt.% 14.5 14.5 14.5
HT/HS, cP @150°C 2.6 3.0 3.0
Density 7.16 7.17 7.25
Specific Gravity, 15.6°C .86 .84 .85
Formula Shell Conventional
TEST TYPICAL RESULTS
SAE Viscosity Grade 5W-20 5W-30 10W-30
API Gravity 33.01 33.08 30.68
Viscosity, cSt, 40°C 47.33 62.87 69.05
Viscosity, cSt, 100°C 8.4 10.61 10.42
Flash Point, °C 227 225 228
Pour Point, °C -48 -38 -43
CCS Viscosity, cP (°C) 5,350 (-30°C) 5,820 (-30°C) 6,100 (-25°C)
MRV Viscosity, cP (°C) 15,710 (-35°C) 22,100 (-35°C) 19,500 (-30°C)
I gotta say that those Sunoco oils aren't knocking my socks off based on the test results given...14.5% NOACK loss is right on the edge of the API SN limit and does not meet dexos1 requirements. 200C flashpoint is quite low and it's strange that they're all the same, maybe they're just guaranteeing >200C for the line?
Too bad NOACK is not given for the Shell conventional for a better comparison across the board.
Man, Id use FS all day over Sunoco.
SUN OIL just start marketing oil again? I don't recall seeing any on market for well over a decade. Bet you a beer they don't package their oil.
Thoughts on Mobil Special? I move a lot of oil. Bulk and cased goods. Shell prices have increased dramatically over the last few years. I guess they (SOPUS) prefers to sell Pennz/QS. Do not want to install a sub par engine oil but the price forces me to, at the least, compare products. A bit of research tells me the NOACK% is very important. I saw Formula Shell at 14.3% but the numbers were from 2008.
Thanks again for the replies. It is very helpful for me in my decision making process.
Mobil Special 5W-20 5W-30* 10W-30*
API Service Classification SN SN SN
Gravity, API 33.1 33.0 31.3
Specific Gravity 0.8596 0.8600 0.8692
Pour Point, °C (°F ) -36(-33) -36(-33) -33(-27)
Flash Point°C (°F)ASTMD92 224(435) 220(428) 220(428)
Viscosity
cSt at 40°C 49.2 60.42 69.4
cSt at 100°C 8.6 10.2 10.6
CCS, cP 5800@-30 ºC 6100@-30 ºC 6430@-25 ºC
MRV, cP 26,400@-35 ºC 29,330@-35 º 19,892@-30 ºC
Viscosity Index 153 157 141
Resource Conserving YES YES YES
The PQIA looked at the Mobil Special 5W30 a couple of years ago and the NOACK loss was nothing special at 14.4%...I would guess that a lot of conventional SN oils are just under 15%.
http://www.pqiadata.org/MobilSpecial5W30.html
Between the Mobil and Shell oils, I'd probably just pick the cheaper one...I guess Shell might have slightly more impressive results for the specs shown. I noticed that the Mobil 5W30 has a modest dose of moly and no boron while the PQIA shows the Shell 10W30 has healthy doses of both, but they don't have identical grades to compare head to head. The Mobil 5W30 has a strong virgin TBN of 8.6 if stretching OCIs might be a concern.
Thanks VP for the PQIA website.
Great way to compare different brands.
Appreciate all the responses.
You are welcome, glad to be of help!
The Russian Oil Club has a lot of very detailed VOAs with NOACK loss and cold cranking results, too, seems like kind of a weird source but they match up well with other published numbers when a direct comparison is possible. May not be the best place to look for US conventional oils, though.
Viscosity
One thing about Mobil Special is XOM only warratees it for 4K miles or OEM OCI (whichever is longer) not 5K. Dunno if this matters to you for your use.
https://mobiloil.com/en/article/warranties/limited-warranty/mobil-special-limited-warranty
https://mobiloil.com/en/article/warranties/limited-warranty/mobil-super-oil-warranty
Outside Sunoco branded gas stations, I have never seen their oil on any retailers shelf.
Just noticed that the PQIA looked at their conventional 5W30 about 6 years ago and the 5W20 very recently.
Both have pretty good doses of sodium (like Valvoline and Royal Purple), NOACK losses between 14-15%, very little boron or moly, and modest virgin TBNs around 7. Going to Mobil Special looks to give you a small dose of moly, while Pennzoil looks to have quite healthy doses of moly and boron. Doesn't mean that the latter brands necessarily have better conventional oils, but it seems like a lot of BITOGers are more comfortable with seeing moly and boron compounds...although some of the formulators on here have mentioned that newer organic compounds can do the same jobs well.
