Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
40 registered members (Ag76, Bailes1992, BKlab, Blkstanger, AndyB, 4 invisible), 1,022 guests, and 35 spiders.
Topics290,918
Posts4,852,501
Members66,055
Most Online3,590
Jan 24th, 2017
2012 VW Golf 2.5L Spark Plugs #4495405
08/22/17 05:00 PM
08/22/17 05:00 PM
virginia
sparky123 Offline OP
virginia
Just changed out the OEM VW Bosch spark plugs on my 2.5L VW Golf. Not difficult at all. 28k miles and 5 1/2 yrs. of mostly short tripping. I noticed the engine not running as smooth so I decided not to wait any longer. What a difference w/new NGK (6737) PZFR5Q-11's! Fantastic plugs. IMO, much better than the Bosch's. I highly recommend all 2.5L owners seriously consider these plugs and NOT go past 30K on the original plugs if they're the Bosch's. Could not be more pleased....BTW, used a little
Permatex 81343 Anti-Seize Lubricant &
Permatex 81150 Dielectric Tune-Up Grease. Also, checked the air filter w/10k of use, very clean. I Could easy see this large filter going 30k miles easy. Cheers! Bill
2012 VW Golf 2.5L Auto Pennzoil Euro 5w-40
2005 Ford ZX5 2.0L Auto
1999 Mazda Protege 1.6L Auto
Re: 2012 VW Golf 2.5L Spark Plugs [Re: sparky123] #4495422
08/22/17 05:23 PM
08/22/17 05:23 PM
USA
NHGUY Offline
NHGUY  Offline
USA
VW fans seem to be sticklers when it comes to defending the Bosch brand,but aside from starters and alternators,Bosch stuff is so-so stuff.I've heard many stories of wire sets/spark plugs causing running issues and other brands solve the issues.Their O2 sensors have a bad rep too.
Re: 2012 VW Golf 2.5L Spark Plugs [Re: sparky123] #4495432
08/22/17 05:36 PM
08/22/17 05:36 PM
NC
Vladiator Offline
Vladiator  Offline
NC
How is your overall experience with that vehicle? I am seriously considering adding a Jetta/Golf or Passat with the 2.5L to my stable, but afraid of VW electrical issues. Has that been an issue for you? Have you had the vehicle for all of the 5.5 years? Thanks in advance.
2000 Lexus GS300-361k
1999 Lexus GS400-213k
2006 Toyota Camry-187k
2006 Toyota Highlander Hybrid-125k
2009 Scion xB-120k
2013 VW Tiguan-120k
2009 Toyota Tacoma-60k
Re: 2012 VW Golf 2.5L Spark Plugs [Re: sparky123] #4495490
08/22/17 06:35 PM
08/22/17 06:35 PM
virginia
virginia
Yes, I'm the original owner. Last of the German made Golf's. The 2.5L is bullet-proof. Not overly technical...no turbo, Variable Value Timing etc. Cast iron block AND the car has a full tire spare! A dinosaur which is the reason I bought this car. Very reliable. Downside...gobbles gas around town. Hwy. mileage is 32mpg. I'd buy a model made in Germany. (Test drove a Jetta one time and the Golf was a superior car IMO.) No problems at all. (Knock on wood!) I change the oil every 6 months and let the dealer change the oil/filter I bring in when the yearly vechicle inspection is due. (Dealer changes me $22 for the oil/filter change and doesn't charge for the yearly. inspection (-$15) The car is very well built and I feel safe in it. Drives very smooth and is a pleasure to drive. Excellent steering feel and brakes are top notch. Haven't done anything beyond maintenance.
Re: 2012 VW Golf 2.5L Spark Plugs [Re: sparky123] #4495531
08/22/17 07:15 PM
08/22/17 07:15 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I own a 2013 VW GTI I bought new which has 106K on it. I've never had a single electrical issue with it. The intake manifold did fail on it around 80K. It has butterflies that open at higher RPM's for more airflow. I got a code for it so it was a physical issue in the linkage, not the sensor. Went to a dealer, talked the parts department into giving me the same price I'd get from ordering one online from a dealer far away for $180. I replaced the clutch/flywheel/pressure plate/release bearing. Those have been my two repairs. I've owned more reliable cars in the past but this is by far my favorite car I've ever owned.
Speaking of Bosch O2 sensors, I owned a WRX I modified. I installed a bigger downpipe and put a new Bosch O2 sensor in it. The Bosch O2 sensor didn't last two months. I replaced it with an NTK O2 sensor and never had another problem.
Me: 13' VW GTI 3 door 6 speed manual
Re: 2012 VW Golf 2.5L Spark Plugs [Re: NHGUY] #4495588
08/22/17 08:44 PM
08/22/17 08:44 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
So true. When Bosch is the OE manufacturer, the part is usually OK. If you are talking any sort of aftermarket Bosch part, you might as well save your money.
1998 Honda Accord EX 2.3L Auto
2009 Scion TC Manual
Re: 2012 VW Golf 2.5L Spark Plugs [Re: Charlie2015] #4496267
08/23/17 04:53 PM
08/23/17 04:53 PM
USA
slacktide_bitog Offline
USA
approved
