More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
129 registered members (53' Stude, 2012AccentSE, addyguy, aquariuscsm, Aichiguy, albenjoseph, 12 invisible), 1,989 guests, and 64 spiders.
Topics286,113
Posts4,902,886
Members67,565
Most Online2,967
Mar 10th, 2019
New 4 runner oil #4495388
08/22/17 04:48 PM
08/22/17 04:48 PM
So. Texas
Moondawg Offline OP
Moondawg  Offline OP
So. Texas
My wife just bought a new 2017 toyota 4 runner, with the 4.0 V6. I must have 5 or 6 one gallon jugs of Mobil 1 -10w-30, Once the two free oil changes from Toyota, are done, will it hurt this engine to run the 10w-30 in it? I have been running Mobile One for 20 years with no complaints, but never in a engine that supposedly required 0w-20.
Re: New 4 runner oil [Re: Moondawg] #4495394
08/22/17 04:55 PM
08/22/17 04:55 PM
Midwest USA
LoneRanger Online content
LoneRanger  Online Content
Midwest USA
Under warranty I would certainly stay with the factory recommendation. I don't know about the Toyota motor but with the newer Subaru's that spec 0W-20 the variable valve timing system relies on oil pressure and is calibrated (supposedly) to 0W20.
'09 Subaru Forester ...................(QS HM 5W30)
'16 Moto Guzzi Stelvio 1200 .....(ENI i-Ride PG 10W60)
Re: New 4 runner oil [Re: Moondawg] #4495435
08/22/17 05:39 PM
08/22/17 05:39 PM
NEUS
Bandito440 Offline
Bandito440  Offline
NEUS
Anything from 0w-20 to 15w-40 will be fine in that engine in Texas heat.
Use 0w-20 until the warranty is up, and keep receipts.
I've been drooling over the TRD Pro lately.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
Re: New 4 runner oil [Re: Moondawg] #4495439
08/22/17 05:41 PM
08/22/17 05:41 PM
United We Stand
Cup of Joe Offline
Cup of Joe  Offline
United We Stand
Your in south texas I don't see an issue. I am running mobil 1 10w-30 in my 2015 now. I've been towing a 19' Jayco travel trailer extended distances all summer.
2015 Toyota 4runner mobil 1 10w-30
Re: New 4 runner oil [Re: Moondawg] #4495451
08/22/17 05:50 PM
08/22/17 05:50 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Congrats on the new 'Runner! Would love that to be my next vehicle.
Plenty of debate on this topic on the FJ Cruiser and 4Runner forums. The 4.0 was specified for Xw30 oils until 2010 when Toyota changed the valvetrain a bit. Since then, many have stuck with the 30 grade oils with no change in mpg or behavior.
I'd say in Texas, no issue running a 10w30 year around.
Plus check your OM. Doesn't it say a thicker oil is required for heavy duty/towing/mountains/sustained high speed/etc? I think TX highways qualify.....
Thick vs Thin test: 15k / 43k miles complete
Re: New 4 runner oil [Re: Moondawg] #4495455
08/22/17 05:55 PM
08/22/17 05:55 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Unless the manual verbiage switched between 2015 and 2017, you should be fine even under warranty.
The 2015 says something to the tune of, "0w20 is recommended, a 5w20 can be used if 0w20 isn't available, but you must use a 0w20 for the next oil change. You can also go up a weight if the vehicle is used for towing."
I personally take upping the weight to mean 0w30, 5w30 or 10w30 as long as they all meet the current oil requirements and are synthetic.. which reminds me, are the OCI's still 10k?
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: New 4 runner oil [Re: Moondawg] #4495458
08/22/17 05:59 PM
08/22/17 05:59 PM
United We Stand
Cup of Joe Offline
Cup of Joe  Offline
United We Stand
Still 10K. The engine holds 6.6 quarts of oil.
Re: New 4 runner oil [Re: Moondawg] #4495459
08/22/17 06:01 PM
08/22/17 06:01 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
It would work fine, but if you have some engine failure the dealership could give you hassle about warranty.
Do you have anything else you can run it in?
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: New 4 runner oil [Re: Moondawg] #4495460
08/22/17 06:02 PM
08/22/17 06:02 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
In south Texas I'd just mix a quart or two of that 10-30 into the mix on every OCI.
2004 Corolla 129932
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: New 4 runner oil [Re: Moondawg] #4495503
08/22/17 06:54 PM
08/22/17 06:54 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
My 4.0L 1GR-FE V6 is really similar and it specs 5W30...
Re: New 4 runner oil [Re: Moondawg] #4495597
08/22/17 08:56 PM
08/22/17 08:56 PM
WI.
dblshock Offline
dblshock  Offline
WI.
Actually better moving up a grade or two imo...if the temps a above 15F I have no issue with 10W either but I'd use a different car on colder days to avoid the starts, probably few and far between where your at, we only wish here.
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: New 4 runner oil [Re: Moondawg] #4498513
08/26/17 09:46 AM
08/26/17 09:46 AM
New York Queens
Ram02 Offline
Ram02  Offline
New York Queens
Use the oil you have you'll be fine
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: New 4 runner oil [Re: Moondawg] #4498537
08/26/17 10:17 AM
08/26/17 10:17 AM
Kathleen , FL
johnD2 Offline
johnD2  Offline
Kathleen , FL
I wouldn't run it under warranty. Do you have another vehicle you could put the 30w in ?
2000 Silverado Short Wheelbase 4.8 L 4x4
Wix 51522 / Pennzoil HM 10w40
2016 F150 crew cab 5.0 2WD
Wix 57502 / Rotella Gas Truck 5W20
