Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
110 registered members (ARCOgraphite, acme, AandPDan, Aero540T, 13 invisible), 1,765 guests, and 61 spiders.
Topics286,229
Posts4,904,707
Members67,582
Most Online2,967
Mar 10th, 2019
NOACK - Pennzoil Platinum Euro 5W-40 #4495381
08/22/17 04:38 PM
08/22/17 04:38 PM
Greensboro, NC
agpatel Offline OP
agpatel  Offline OP
Greensboro, NC
Below is a NOACK results for Pennzoil Platinum Euro 5W-40 - from the same bottle I did a VOA from. NOACK value came in below anything I would of expected and wonder if its a highly variable test...
Link to VOA: https://bobistheoilguy.com/forums/ubbthr...o_5#Post4435754
Re: NOACK - Pennzoil Platinum Euro 5W-40 [Re: agpatel] #4495425
08/22/17 05:26 PM
08/22/17 05:26 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
It is highly variable, but that seems a bit much. wink
Plain, simple Garak.
Re: NOACK - Pennzoil Platinum Euro 5W-40 [Re: agpatel] #4495474
08/22/17 06:18 PM
08/22/17 06:18 PM
MN
oil_film_movies Online content
oil_film_movies  Online Content
MN
I've heard NOACK is hard to nail down. Variable, as they say.
This is ridiculous.
Re: NOACK - Pennzoil Platinum Euro 5W-40 [Re: agpatel] #4495564
08/22/17 08:14 PM
08/22/17 08:14 PM
il usa
merconvvv Offline
merconvvv  Offline
il usa
Noack of 3.6.
Wonder if they repeat the test if they have doubts.
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
Re: NOACK - Pennzoil Platinum Euro 5W-40 [Re: merconvvv] #4495580
08/22/17 08:33 PM
08/22/17 08:33 PM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
Originally Posted By: merconvvv
Noack of 3.6.
ASTM D5800 would specify a statistically valid number of samples either in the test itself or in some ancillary publication. It would also state if the test is prone to unusual variability.
It would also give reporting requirements for accuracy, which I assume Precision Petroleum Labs has followed when giving their result.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: NOACK - Pennzoil Platinum Euro 5W-40 [Re: agpatel] #4495582
08/22/17 08:36 PM
08/22/17 08:36 PM
il usa
merconvvv Offline
merconvvv  Offline
il usa
The pp 5w40 is probably close to a 10w40. Add in lil variability n u get 3.6 ????
Re: NOACK - Pennzoil Platinum Euro 5W-40 [Re: agpatel] #4495618
08/22/17 09:20 PM
08/22/17 09:20 PM
Greensboro, NC
agpatel Offline OP
agpatel  Offline OP
Greensboro, NC
I have asked what procedure was used, there are three options per the spec (A,B, and C) - see below regarding potential difference. If Procedure A was used it would explain the low value plus variability. I have typically seen B when looking at oil specs.
Quote:
1.1 This test method covers three procedures for determining the evaporation loss of lubricating oils (particularly engine oils). Procedure A uses the Noack evaporative tester equipment; Procedure B uses the automated non-Woods metal Noack evaporative apparatus; and Procedure C uses Selby-Noack volatility test equipment. The test method relates to one set of operating conditions but may be readily adapted to other conditions when required.
1.2 Noack results determined using Procedures A and B show consistent differences. Procedure A gives slightly lower results versus Procedure B on formulated engine oils, while Procedure A gives higher results versus Procedure B on basestocks.
Re: NOACK - Pennzoil Platinum Euro 5W-40 [Re: agpatel] #4496016
08/23/17 10:29 AM
08/23/17 10:29 AM
Greensboro, NC
agpatel Offline OP
agpatel  Offline OP
Greensboro, NC
Did confirm that Method A was used.
Re: NOACK - Pennzoil Platinum Euro 5W-40 [Re: agpatel] #4496138
08/23/17 01:39 PM
08/23/17 01:39 PM
Great Lakes
Quattro Pete Offline
Great Lakes
Yeah, that seems low. It should be around 6.2% according to SOPUS.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: NOACK - Pennzoil Platinum Euro 5W-40 [Re: agpatel] #4496154
08/23/17 02:03 PM
08/23/17 02:03 PM
GA
drtyler Offline
drtyler  Offline
GA
Maybe the formulation changed to pass the newest BMW LL-01 certification? I remember one poster indicated the test had changed fairly recently.
Re: NOACK - Pennzoil Platinum Euro 5W-40 [Re: Quattro Pete] #4611927
12/23/17 09:27 AM
12/23/17 09:27 AM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Remind me, did SOPUS actually provide that value? Thought it was from a Russian site.
Trying to determine my way ahead for oil in my 135, and a 6ish% NOACK is one of my criteria.
OP, thanks for doing this!
Re: NOACK - Pennzoil Platinum Euro 5W-40 [Re: JHZR2] #4616077
12/27/17 06:47 PM
12/27/17 06:47 PM
Great Lakes
Great Lakes
It was provided to me via email from a SOPUS product manager. It was a couple of years ago though, so who knows if it's still applicable.
