Gift for young Army Cadet
by Snagglefoot. 12/16/18 12:33 AM
Instacart Grocery Delivery
by dogememe. 12/16/18 12:26 AM
My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
MikeMTL, AJ11, bandito, Spkrdctr, torchredone12
66691 Registered Users
25 registered members (dishdude, 69Torino, Char Baby, Duffyjr, Aero540T, c502cid, 2 invisible), 993 guests, and 39 spiders.
Topics295,135
Posts4,928,349
Members66,691
Most Online2,553
Oct 27th, 2018
Stainless steel brake tubing worth it? #4495364
08/22/17 03:15 PM
08/22/17 03:15 PM
Denmark, Europe
LucasDK Offline OP
LucasDK  Offline OP
Denmark, Europe
Hi,
Are there any advantages of stainless steel brake tubing compared to CuNiFer? Anyone with practical experience? For me, I need maximum corrosion resistance and not necessarily a nice look.
Lucas
Toyota Hiace 2,4D (2L engine)
Toyota Corolla AE92, (4A-FE engine)
Ford Model A (3,4 liter engine)
Re: Stainless steel brake tubing worth it? [Re: LucasDK] #4495366
08/22/17 03:19 PM
08/22/17 03:19 PM
Cedarbrae, Ontario
xxch4osxx Offline
xxch4osxx  Offline
Cedarbrae, Ontario
I would just go with the Nicopp lines if I was you. No need for stainless if its not for show.
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
Re: Stainless steel brake tubing worth it? [Re: LucasDK] #4495368
08/22/17 03:24 PM
08/22/17 03:24 PM
One Step Beyond
larryinnewyork Offline
One Step Beyond
I applied GREASE to mine when 2002 truck was purchased new.
I live in the rust-belt.
Today, if you wipe the grease off, the brake lines look brand new.
Every couple of years, I will mix Fluid Film and Never-Seize and smear it around (incase any of the grease was drying up).
I make an effort to also keep Bleeder Valves greased.
Re: Stainless steel brake tubing worth it? [Re: LucasDK] #4495404
08/22/17 04:00 PM
08/22/17 04:00 PM
ME
eljefino Offline
eljefino  Offline
ME
How would you flare stainless? It's brittle. Even if "they" flared it, if what you're joining it to isn't perfect the crush won't be very nice and you might get a leak.
+2 on NiCopp.
Re: Stainless steel brake tubing worth it? [Re: LucasDK] #4495442
08/22/17 04:44 PM
08/22/17 04:44 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Braided steel can give a more responsive pedal, rubber can stretch a little bit
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Stainless steel brake tubing worth it? [Re: LucasDK] #4495505
08/22/17 05:55 PM
08/22/17 05:55 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
NiCopp will look new decades from now, they simply do not rust.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Stainless steel brake tubing worth it? [Re: LucasDK] #4495513
08/22/17 06:03 PM
08/22/17 06:03 PM
CA
shinyWheels Offline
shinyWheels  Offline
CA
I had stainless steel lines on my Eclipse. The pedal was very firm after that modification. But I also had flushed the brake fluid, got new pads and rotors at the same time.
Re: Stainless steel brake tubing worth it? [Re: LucasDK] #4495518
08/22/17 06:05 PM
08/22/17 06:05 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Nicopp is all you need.
2015 Ford F250 w/Powerstroke
Re: Stainless steel brake tubing worth it? [Re: LucasDK] #4495523
08/22/17 06:09 PM
08/22/17 06:09 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
I replaced all the fuel, fuel vent and brake lines on my old BMW and I used NiCopp brand lines for most all of them (except some short pre-bent ones I got from BMW). In terms of being easy to use I don't know how it could be any easier. You can bend it with your bare hands into a small radius and it does not kink. Two years later here in the rust belt it still looks great.
1994 BMW 530i, 238K
1996 Honda Accord, 266K
1999 Toyota Sienna, 407K
2000 Toyota ECHO, 280K
Re: Stainless steel brake tubing worth it? [Re: LucasDK] #4495559
08/22/17 07:00 PM
08/22/17 07:00 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Originally Posted By: LucasDK
Hi,
Lucas
Stainless is more resistant (not immune) to dings and crushing than NiCopp but unless you do a lot of rock crawling or extreme off roading their drawbacks outweigh any benefit.
NiCopp/Cunifer is really great stuff.
Re: Stainless steel brake tubing worth it? [Re: Trav] #4495572
08/22/17 07:25 PM
08/22/17 07:25 PM
indianapolis in
bmwjohn Offline
bmwjohn  Offline
indianapolis in
I don't know currently, but Advance Auto Parts discount coupons DID apply to cu pro-nickle brake lines.
Re: Stainless steel brake tubing worth it? [Re: LucasDK] #4495723
08/22/17 10:35 PM
08/22/17 10:35 PM
Denmark, Europe
LucasDK Offline OP
LucasDK  Offline OP
Denmark, Europe
Thanks for all your answers. Just what I needed. I will go with the Nicopp :-)
Re: Stainless steel brake tubing worth it? [Re: LucasDK] #4495772
08/23/17 01:36 AM
08/23/17 01:36 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
Nicopp never rusts and is a lot easier to work with than stainless.
Cable ties should hold it
Re: Stainless steel brake tubing worth it? [Re: shinyWheels] #4496029
08/23/17 09:55 AM
08/23/17 09:55 AM
stl
MarkM66 Offline
MarkM66  Offline
stl
He's referring to the hard line, not hoses.
Re: Stainless steel brake tubing worth it? [Re: LucasDK] #4496812
08/24/17 08:27 AM
08/24/17 08:27 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I do not live in the rust / salt belt . Thank God .
In , maybe 50 years driving , the only time I have ever replaced the metal brake lines ( OEM are steel ? ) was due to physical damage in the line crossing one side of the rear banjo / deferential tube / housing . Exhaust pipe mount broke & the pipe had been vibration / bouncing on the steel line .
I saw a video of Eric O. using the Ni Cu lines . That is all I know about them , other than he spoke highly of it . No way I would fight stainless steel .
Best of luck , :-)
Wyr
God bless
