March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
125 registered members (02z, albenjoseph, 92saturnsl2, 928, 4WD, 77GrandPrix, 10 invisible), 2,001 guests, and 53 spiders.
Topics286,087
Posts4,902,304
Members67,560
Most Online2,967
Mar 10th, 2019
Checking dip stick #4495305
08/22/17 02:58 PM
08/22/17 02:58 PM
Nebraska
Duffyjr Offline OP
Duffyjr  Offline OP
Nebraska
Was just reading the post about checking oil on first or second pull and want to see what every does with small engines.
My Toro has a yellow dip stick and you have to unscrew it and wipe it off and reinsert but not screw it in to get a reading. First, with clean oil the yellow is hard to read, have to tilt it in the light just right. Second is it never reads the same on both sides, one side always has oil higher than the other no matter how I put it in even cold so not sure where to keep the level, somewhere in between I suppose.
My old MTD snowblower has a metal dip stick and is very easy to read, they should all be like this.
My new Toro snowblower has a little dip stick but it's at the base of the motor so all you have to do is fill it until it starts coming out a bit. I remember back in the day all mowers were like this.
89 GMC Sierra VWB 5w30/TG3980
08 Lucerne CX Magnatec 5w30/TG3387A
02 DeVille VWB 5w30/CQ Blue
18 Toro Super Recycler T5 10w30
Re: Checking dip stick [Re: Duffyjr] #4495334
08/22/17 03:39 PM
08/22/17 03:39 PM
alabama
wayne50 Offline
wayne50  Offline
alabama
I have a Murray with a Briggs Twin. The oil will creep up the dipstick when stopped so I have to wipe it first and then re-check. It has a hole at full and one at the add mark and is easy to read.
Re: Checking dip stick [Re: Duffyjr] #4495337
08/22/17 03:44 PM
08/22/17 03:44 PM
Oklahoma
CELICA_XX Offline
CELICA_XX  Offline
Oklahoma
Ugh I hate that...
The method of "insert but not screw-in" doesn't seem very accurate to me in the first place.
I feel like different people would get different results based on how exactly the cap was sitting
15 Toyota Prius - M1 EP 0w20 SN+
06 Acura MDX - Valv MaxLife Syn 5w20 SN+
02 Toyota ECHO - Valv MaxLife Syn 5w30 SN+
97 Lexus LX450 - M1 EP HM 5w30 SN+
93 Lexus LS400 - Valv MaxLife Syn 5w30
Re: Checking dip stick [Re: Duffyjr] #4495380
08/22/17 04:35 PM
08/22/17 04:35 PM
MD
AirgunSavant Offline
MD
I just did this on a Kohler with a yellow dipstick.
Even 15w50 flings off as you are pulling the dipstick up to read. As you said you need to quickly tilt it. You would think we could get a sight glass view like we have on metal lathes etc. It would be nice.
Re: Checking dip stick [Re: Duffyjr] #4495413
08/22/17 05:04 PM
08/22/17 05:04 PM
ME
eljefino Offline
eljefino  Offline
ME
Open the dipstick then stick your finger in the hole. Use the calculated eyeball. How we used to check oil in OPE way back when.
Re: Checking dip stick [Re: eljefino] #4495594
08/22/17 08:54 PM
08/22/17 08:54 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Wash your hands first. After is optional, unless you object to skin cancer on principle.
Re: Checking dip stick [Re: Duffyjr] #4495733
08/23/17 12:01 AM
08/23/17 12:01 AM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
Common on Japanese engines and Chinese clones I think.
I got the oil at the proper level then screwed the dipstick in and
filed a small notch at that level so no more fiddling around with
"insert but not screw-in".
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Checking dip stick [Re: CELICA_XX] #4496695
08/24/17 07:37 AM
08/24/17 07:37 AM
Cleveland, Ohio, USA
RobM Offline
RobM  Offline
Originally Posted By: CELICA_XX
Ugh I hate that...
Yeah, and if you're like my brother and don't pay attention on how to check the oil you'll seize your engine. My brother had a Honda mower and was screwing in the dipstick to check the oil- well the Honda is no longer.
Re: Checking dip stick [Re: RobM] #4496824
08/24/17 09:39 AM
08/24/17 09:39 AM
Minnesota
Lenny5160 Offline
Lenny5160  Offline
Minnesota
You think the engine seized because the oil level was maybe 1/2" too high?
Re: Checking dip stick [Re: Duffyjr] #4496829
08/24/17 09:46 AM
08/24/17 09:46 AM
RobM Offline
RobM  Offline
Too low. Screwing it in gave false reading that level was ok, when actually low.
Re: Checking dip stick [Re: RobM] #4496851
08/24/17 10:08 AM
08/24/17 10:08 AM
Minnesota
Lenny5160 Offline
Lenny5160  Offline
Minnesota
Ah, yes. I am an idiot.
However, if the oil was being checked and was on the stick with it screwed in, that is enough oil for the engine to live on.
Re: Checking dip stick [Re: Duffyjr] #4496864
08/24/17 10:32 AM
08/24/17 10:32 AM
RobM Offline
RobM  Offline
He may have been running it that way for a while before it seized.
Re: Checking dip stick [Re: Duffyjr] #4496923
08/24/17 12:13 PM
08/24/17 12:13 PM
California
boom10ful Offline
boom10ful  Offline
California
Stupid question: How would you check the oil level on a Toro 20016 Recycler with a Tecumseh engine? I've been screwing it in to check the oil level that way. The manual only states to "fully install the dipstick".
Re: Checking dip stick [Re: Duffyjr] #4496929
08/24/17 12:21 PM
08/24/17 12:21 PM
RobM Offline
RobM  Offline
I would: Unscrew, wipe off, screw it in all the way, unscrew, check. Sounds like you're doing it correctly.
Re: Checking dip stick [Re: boom10ful] #4497161
08/24/17 04:58 PM
08/24/17 04:58 PM
Nebraska
Duffyjr Offline OP
Duffyjr  Offline OP
Nebraska
My old blower has a Tecumseh and in the owners manual it does say to screw it in. That one screws in so far that if you weren't screwing it in to check the lever it would be way off, probably close to an inch.
