Small Trolling Motors
by wings&wheels. 12/15/18 12:49 PM
Toyota Corolla, good and bad?
by jongies3. 12/15/18 12:35 PM
Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
80 registered members (53' Stude, 4WD, 71Chevyguy, 93cruiser, bbhero, 77GrandPrix, 10 invisible), 2,221 guests, and 45 spiders.
Topics295,107
Posts4,927,941
Members66,688
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
What year did the Civic get a timing chain? #4495216
08/22/17 12:18 PM
08/22/17 12:18 PM
OH
grampi Offline OP
grampi  Offline OP
OH
If ever?
Re: What year did the Civic get a timing chain? [Re: grampi] #4495229
08/22/17 12:35 PM
08/22/17 12:35 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
Speaking of,why is Honda still using a belt on their V6? Isn't everyone else using chains now?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 5W20
Re: What year did the Civic get a timing chain? [Re: grampi] #4495232
08/22/17 12:37 PM
08/22/17 12:37 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
The R18 engine used starting in the 2006-2011 (8th generation) which I own, uses a timing chain. The 7th generation right before uses the D17 engine which uses a timing belt. I assume the 8th is the first time they switched, all subsequent generations 8th and onward use timing chains. The last one to use a timing belt was 2005 Civic, first one to use timing chain is 2006 Civic.
2015 Civic LX Coupe
Re: What year did the Civic get a timing chain? [Re: grampi] #4495233
08/22/17 12:37 PM
08/22/17 12:37 PM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
2006+ with the R18s. The previous generation SIs had K20s (chains), also, but the regular LX/DX/EX had belts. I think that era Hybrid Civic also had a chain.
Re: What year did the Civic get a timing chain? [Re: grampi] #4495254
08/22/17 01:02 PM
08/22/17 01:02 PM
OH
grampi Offline OP
grampi  Offline OP
OH
Thanks! Are the '06 and newer ones pretty reliable?
Re: What year did the Civic get a timing chain? [Re: grampi] #4495260
08/22/17 01:07 PM
08/22/17 01:07 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
As in what? The timing components or the car overall?
I have an 09 that I maintain religiously and have had no issues, except for the passenger side airbag recall and the idiot kid who did it messing everything up along the way.
Some of the 2006 to early 2009 had an issue with the aluminum short blocks cracking in specific locations due to weak casting. Honda extended the warranties on those to ten years with no mileage limit (TSB 10-048) provided the car has a clean title (not salvage). I have not had the issue and mine is in the early 2009 batch to my knowledge.
2015 Civic LX Coupe
Re: What year did the Civic get a timing chain? [Re: NoNameJoe] #4495264
08/22/17 01:12 PM
08/22/17 01:12 PM
OH
grampi Offline OP
grampi  Offline OP
OH
Some of the 2006 to early 2009 had an issue with the aluminum short blocks cracking in specific locations due to weak casting. Honda extended the warranties on those to ten years with no mileage limit (TSB 10-048). I have not had the issue and mine is in the early 2009 batch to my knowledge.
The reason I'm asking is because I'm looking at buying an '09. I'm usually a Corolla person, but I would also consider a Civic...I have always liked the generation that began in '06...
Re: What year did the Civic get a timing chain? [Re: grampi] #4495267
08/22/17 01:14 PM
08/22/17 01:14 PM
Minnesota
2010Civic Offline
2010Civic  Offline
Minnesota
If that 2009 was built later in the year it has the updated block which is very good. You can use the VIN to find out.
The 09's have a lot of nice updates over the 06-08. They look nicer. I have a 2010 and my wife has a 2008. Great cars!
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: What year did the Civic get a timing chain? [Re: grampi] #4495272
08/22/17 01:15 PM
08/22/17 01:15 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
I'd say go for it if it's an 09. It certainly has my seal of approval. I drive it all the time, haven't had any issues and work needed other than the necessary stuff (brake, lube and filter changes).
I live in New York too and for a car this old it has startlingly little rust on the underside, compared to cars I've seen with subframes rotted through, but that might be due to how I hose it down often. The exhaust system itself, I don't know what they make it out of (stainless?) but there's also very little rust, just heat discoloration and all of the fasteners down the whole system come out nice and easy.
2015 Civic LX Coupe
Re: What year did the Civic get a timing chain? [Re: grampi] #4495277
08/22/17 01:20 PM
08/22/17 01:20 PM
NC
BigD1 Offline
BigD1  Offline
NC
Cracked blocks. https://www.consumerreports.org/cro/news...ivics/index.htm
The 2008 Civic that I service has bad peeling paint. Block not cracked on it, and it has been very reliable for the owner. In 1.5 years, it has gone through one set of brakes, a new starter, and I just had to change the brake light switch assembly yesterday, which only cost $6.99 at NAPA. The threaded portion broke because the whole assembly is nothing but plastic.
1992 Toyota Pickup--Harvest King Premium 10W-30--Fram PH3614
Re: What year did the Civic get a timing chain? [Re: grampi] #4495321
08/22/17 02:15 PM
08/22/17 02:15 PM
Outer Banks, NC
NormanBuntz Offline
NormanBuntz  Offline
Outer Banks, NC
My grandson has owned a 2009 Civic LX since new. The only complaints he's had is the high wear rate on the factory brake pads and also problems with hardware and trim pieces like around the side windows, the windshield and the two trim pieces on the roof that run front to back. Drivetrain has been fine for 126,000 miles.
2017 Honda Odyssey SE, 16K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 88K
2007 Infiniti M35, 107K
Re: What year did the Civic get a timing chain? [Re: NormanBuntz] #4495338
08/22/17 02:45 PM
08/22/17 02:45 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Just sounds like the brakes are not being serviced often enough or properly. OE pads should easily last 100k km.
Love my 2010 Si (K series engine with a chain). The K series is probably the best mass produced engine Honda ever offered. Flog it all day at the track and it does not care. With a good set of winter tires, is unstoppable in the winter slush/snow/ice, even lowered.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: What year did the Civic get a timing chain? [Re: grampi] #4495371
08/22/17 03:26 PM
08/22/17 03:26 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I'm a big fan of the 8th Gen Civics as well, especially the later ones (09+) due to the short block issue. We had an '09 EX-L that was perfectly reliable while we had it, although it was still young with only ~60k on it when it was totaled. We fully expected it to be our future childrens' first car (we don't even have any kids!). The change to a timing chain was a big bonus, maintenance-wise.
My family has a very early 7th gen Civic as well that has been very reliable, but definitely feels like an inexpensive commuter car. It's incredible how much the Civic matured between those two generations. I never liked how the 9th gen Civics looked, but the current 10th Generation, yes please!
Re: What year did the Civic get a timing chain? [Re: grampi] #4495396
08/22/17 03:56 PM
08/22/17 03:56 PM
USA
slacktide_bitog Offline
USA
The Si got it in 2002. The other Civics got it in 2006.
Re: What year did the Civic get a timing chain? [Re: grampi] #4495426
08/22/17 04:26 PM
08/22/17 04:26 PM
USA
NHGUY Offline
NHGUY  Offline
USA
Somebody needs to reintroduce gears...
Page 1 of 3 1 2 3
