http://www.tyrepress.com/2017/08/world-premiere-braided-carbon-wheels/
Quote:
...Porsche has become the world’s first vehicle manufacturer to produce lightweight wheels with braided carbon fibre. They will be available as an option for the Porsche 911 Turbo S Exclusive Series…
... the innovative wheels are not only lighter than standard alloys – Porsche reports that a set of four weighs around 8.5 kilogrammes or 20 per cent less than standard alloy wheels – they are also 20 per cent stronger…
...Manufactured entirely from carbon fibre reinforced polymer (CFRP), the wheel is essentially comprised of two components. The wheel centre is made from carbon-fibre fabric, its construction requiring the cutting and assembling over 200 individual components. The second component is the rim base, which is made from braided carbon fibre using what is, with a diameter of approximately nine metres, currently the world’s largest carbon fibre braiding machine….
...The new carbon wheels will be available as an option for the 911 Turbo S Exclusive Series from the beginning of 2018 in size 9 J x 20 for the front axle and 11.5 J x 20 for the rear...
I wonder what it would cost to replace a damaged or stolen wheel.
