Self defense
by Camprunner
41 minutes 11 seconds ago
Any apple experts here?
by maverickfhs
Today at 02:50 PM
Cost-no-object 75W-90 GL-5 for a differential?
by d00df00d
Today at 02:34 PM
Pittsburgh Dad, this guy is a trip
by Rat407
Today at 02:06 PM
14 Jeep GC 5.7, PP 5w20 & 0w20
by Vigg
Today at 01:52 PM
Sell me on a SSD drive...........
by ZZman
Today at 01:07 PM
need some ideas on my issue
by matrass
Today at 12:36 PM
Put Pennzoil Platinum Euro L in a Honda.
by dunlop0078
Today at 12:36 PM
BMW V8 Oil Consumption Fix
by doc540
Today at 11:25 AM
More info on Valvoline Modern Engine Oil
by buster
Today at 11:07 AM
Shelf life of synthetic 2 stroke engine oil ?
by ScottMill
Today at 10:34 AM
Oil sample extraction
by Tikka
Today at 10:30 AM
Re-using building materials esp nails
by andyd
Today at 08:57 AM
Central A/C [censored] out
by TOMJ
Today at 08:43 AM
08 Scion tC under valve cover pics
by Highboy
Today at 08:39 AM
Storing extension ladded in garage?
by maverickfhs
Today at 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
Today at 07:20 AM
Any news on what happened to this plane?
by Exhaustgases
Today at 02:36 AM
E4OD fluid ?
by Exhaustgases
Today at 02:23 AM
Update password ?
by meadows
Yesterday at 11:59 PM
WtsTacoma01, Orion62, Revd, blinky1041, mostdecent
65262 Registered Users
82 registered (4WD, 379KITTY, 2015_PSD, 2strokeNorthstar, 7 invisible), 1775 Guests and 34 Spiders online.
65262 Members
67 Forums
285527 Topics
#4495080 - 08/22/17 10:29 AM Alternate size, will this work?
otis24 Offline
Loc: South Dakota
1996 Mercury Villager. Current size 205/75/15. Can I run a 215/65/15 tire on this rim/vehicle?
1991 Chevrolet K1500 (4.3, 4x4, 86k miles)
2016 Dodge Grand Caravan
(3.6 V6) 46500 miles
#4495083 - 08/22/17 10:32 AM Re: Alternate size, will this work? [Re: otis24]
eljefino Offline
Loc: ME
Check your door sticker for the load rating and see if your proposed tire's rating is equal or better. You lose load rating when you lose sidewall.
#4495095 - 08/22/17 10:50 AM Re: Alternate size, will this work? [Re: otis24]
Linctex Offline
Loc: Waco, TX
Not related (yours is a Nissan) but I switched out the 15" rims on a 2001 Windstar and went with 16" rims from a Ford Taurus... and 215/65-16 tires, and it handled FAR, FAR better.
#4495102 - 08/22/17 11:10 AM Re: Alternate size, will this work? [Re: eljefino]
ARCOgraphite Offline
Loc: N.H, U.S.A.
that's right. Speedo will read fater than your going, car will accelerate faster smile without knowing any more - should work FINE, section width is only 5mm wider each side of the tire which is under a 1/4 " - unnoticable. You will notice the lower profile though. Tire will look tiny in the wheel wells - but who care s its a minivan.
Are these used or boneyard takeoffs?
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
#4495106 - 08/22/17 11:15 AM Re: Alternate size, will this work? [Re: otis24]
FZ1 Offline
Loc: Texas
The tire acts as a shock absorber. Going from 75 to 65 is less shock absorption. Keep your wheels and buy a better 75 tire.
#4495111 - 08/22/17 11:19 AM Re: Alternate size, will this work? [Re: otis24]
Kuato Offline
Loc: Colorado
Your speedo will be off by about 5mph at 60:
http://www.1010tires.com/Tools/Tire-Size-Calculator3/205-75R15/215-65R15?ismetric=False
You may want to use a size more closely matched:
215/70R15
235/65R15
255/60R15
195/80R15
Thick vs Thin test: 15k / 43k miles complete
#4495112 - 08/22/17 11:20 AM Re: Alternate size, will this work? [Re: otis24]
BrocLuno Offline
Loc: Kalifornia Kollective
Depends on what you want. Better handling is relative.
Better braking and cornering is fine, until you start driving where that tire will become shredded (pot holes, curbs, rocks, off-road, etc.).
I'll take better ride any day (more sidewall, less air) and tire conformity to the surface (more flex) because I go off-highway.
If you only live in the city on well paved streets and never hit a curb, go down to 40 series if you wish grin
Edited by BrocLuno (08/22/17 11:21 AM)
#4495176 - 08/22/17 12:35 PM Re: Alternate size, will this work? [Re: otis24]
JohnnyJohnson Offline
Loc: Wet side WA
Tell us about the incredible things you're gaining by switching to this other tire.
2004 Toyota Corolla 121525
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74016
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4495185 - 08/22/17 12:47 PM Re: Alternate size, will this work? [Re: JohnnyJohnson]
otis24 Offline
Loc: South Dakota
Cost. The vehicle has 238k miles. The tires I am looking at are used. It is used to go to and from school. Highway miles However, if the seller only has two and not a set of four, its a moot point. I will replace with two new tires of the same factory size. The two rear tires are pretty decent. I will probably put two new snow tires on the rear as it gets closer to winter and move the two good tires to the front. In the spring, purchase two new all-season tires.
#4495315 - 08/22/17 03:11 PM Re: Alternate size, will this work? [Re: otis24]
CELICA_XX Offline
Loc: Oklahoma
If it's a matter of cost, and you have no other options... those tires will work fine.
I would assume you are not pushing this van to the limits.
Even if you were forced to run a slightly different tire front to back, it would be preferable to four old, worn, cracked tires all matching in size.
15 Toyota Prius - M1 EP 0w20
02 Toyota ECHO - Valv MaxLife Full Syn 5w30
97 Lexus LX450 - M1 0w40
93 Lexus LS400 - Valv MaxLife Full Syn 5w30
#4495377 - 08/22/17 04:33 PM Re: Alternate size, will this work? [Re: otis24]
michaelluscher Online   content
Loc: Staten Island, NY
https://xa.yimg.com/df/villagerquest/Whe...p;type=download
Here's a chart of all stock wheel/tire combos for a V/Q
If you want to upgrade, I'd go for anything H rated in the handling package size of P215/70R15 97H
I've had a blowout at highway speed in my '01 with the factory Goodyear Eagle LS's with a T speed rating
Those pants we're never the same...
It weights nearly two tons unladen, you want to keep it on point
If you want 16's, there are many wheels off other cars that'll fit, or keep an eye out for a set off MY99-MY02
For all it's quirk's, stop by the V/Q Yahoo group
https://groups.yahoo.com/neo/groups/villagerquest/conversations/topics
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
#4495393 - 08/22/17 04:55 PM Re: Alternate size, will this work? [Re: otis24]
slacktide_bitog Online   content
Loc: USA
Why do you want to do this? smile
If you can wait a week or two, DTD will be having their labor day sale, which will give you a good price for tires of the correct size.
