Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
96 registered members (2006dodge2500, alarmguy, ARCOgraphite, 97prizm, aquariuscsm, 12 invisible), 1,760 guests, and 58 spiders.
Topics286,387
Posts4,907,359
Members67,614
Most Online2,967
Mar 10th, 2019
Porsche Carbon Fiber Wheels #4495038
08/22/17 09:20 AM
08/22/17 09:20 AM
Idaho
SubLGT Offline OP
SubLGT  Offline OP
Idaho
http://www.tyrepress.com/2017/08/world-premiere-braided-carbon-wheels/
Quote:
...Porsche has become the world’s first vehicle manufacturer to produce lightweight wheels with braided carbon fibre. They will be available as an option for the Porsche 911 Turbo S Exclusive Series…
... the innovative wheels are not only lighter than standard alloys – Porsche reports that a set of four weighs around 8.5 kilogrammes or 20 per cent less than standard alloy wheels – they are also 20 per cent stronger…
...Manufactured entirely from carbon fibre reinforced polymer (CFRP), the wheel is essentially comprised of two components. The wheel centre is made from carbon-fibre fabric, its construction requiring the cutting and assembling over 200 individual components. The second component is the rim base, which is made from braided carbon fibre using what is, with a diameter of approximately nine metres, currently the world’s largest carbon fibre braiding machine….
...The new carbon wheels will be available as an option for the 911 Turbo S Exclusive Series from the beginning of 2018 in size 9 J x 20 for the front axle and 11.5 J x 20 for the rear...
I wonder what it would cost to replace a damaged or stolen wheel.
Re: Porsche Carbon Fiber Wheels [Re: SubLGT] #4495040
08/22/17 09:28 AM
08/22/17 09:28 AM
Northern Ontario, Canada
Danno Offline
Danno  Offline
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: Porsche Carbon Fiber Wheels [Re: SubLGT] #4495042
08/22/17 09:29 AM
08/22/17 09:29 AM
Nevada, USA
gaijinnv Offline
gaijinnv  Offline
Nevada, USA
I wonder what a set of those wheels would look like after having new tires installed at your local tire store ... duh
USN NAVSECGRU 1970-1974
Re: Porsche Carbon Fiber Wheels [Re: Danno] #4495067
08/22/17 10:05 AM
08/22/17 10:05 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Originally Posted By: Danno
Well, it is different. Porsche uses a special loom to make the barrel of the wheel, so it is one continuous piece, whereas Ford and even Koenigsegg use a conventional lay mold to make the barrel. Should absolutely make the Porsche wheel lighter and stronger. And hey, a first is a first.
"Zed's dead baby, Zed's dead."
Re: Porsche Carbon Fiber Wheels [Re: SubLGT] #4495068
08/22/17 10:07 AM
08/22/17 10:07 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Re: Porsche Carbon Fiber Wheels [Re: SubLGT] #4495074
08/22/17 10:16 AM
08/22/17 10:16 AM
Austin, Texas
Brons2 Offline
Brons2  Offline
Austin, Texas
Plastic wheels! Oh the humanity!
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 10w30, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Factory fill still.
Re: Porsche Carbon Fiber Wheels [Re: SubLGT] #4495079
08/22/17 10:27 AM
08/22/17 10:27 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Re: Porsche Carbon Fiber Wheels [Re: SubLGT] #4495107
08/22/17 11:16 AM
08/22/17 11:16 AM
Great Lakes
Quattro Pete Offline
Great Lakes
Pretty sure each one weighs 8.5 kg, and not a set of 4.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Porsche Carbon Fiber Wheels [Re: gaijinnv] #4495110
08/22/17 11:17 AM
08/22/17 11:17 AM
MN
oil_film_movies Online content
oil_film_movies  Online Content
MN
Since those wheels are about $5,000 each to replace when damaged, your local tire store should simply refuse to work on them!
I don't see how a standard steel pry bar would work on that wheel's resin surface. (Then again, steel pry bars are used used on soft aluminum alloy wheels.)
One of the newer Hunter Auto34 machines does spread the pry loads out and uses softer touch materials, it should be fine.
https://www.youtube.com/watch?v=fX43c-gBamk
Re: Porsche Carbon Fiber Wheels [Re: Quattro Pete] #4495121
08/22/17 11:29 AM
08/22/17 11:29 AM
NC
kjbock Offline
kjbock  Offline
NC
I guess I read it as the set of four weigh 8.5 kg less than a set of four standard alloy wheels.
Therefore, each wheel weighs ~2.1 kg less than its alloy counterpart.
2013 BMW 128i - Castrol 0W-40, Mann HU 816X oil filter
2015 Acura MDX - M-1 0W-20 AFE, M-1 M-110
2009 Honda Fit - PUP 5W-20, Fram Ultra XG7317
Re: Porsche Carbon Fiber Wheels [Re: kjbock] #4495142
08/22/17 11:57 AM
08/22/17 11:57 AM
Great Lakes
Great Lakes
Thanks. Yes, that makes more sense now. smile
Re: Porsche Carbon Fiber Wheels [Re: SubLGT] #4495148
08/22/17 12:06 PM
08/22/17 12:06 PM
MN
MN
Less mass means the wheel has less inertia, and can follow imperfections in the road surface better for better adhesion. Wins races, but also smoother ride over bumps.
Didn't some car maker come out with plastic wheels a few years back? Different than this, since they were cheaper of course. Still they would have had to meet the same durability standards, yet probably would not have saved weight. Anybody remember that?
Re: Porsche Carbon Fiber Wheels [Re: SubLGT] #4495149
08/22/17 12:07 PM
08/22/17 12:07 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Thought Ford or Koneig had done this already?
Doubt a Porsche will see weather for years and years outdoors, but wonder what the longevity of the epoxy and fibers are once getting some curb rash, etc.
Neat idea, but seems like a pretty niche item for most cars. The unsprung mass is impressive for a high end performance car.
Re: Porsche Carbon Fiber Wheels [Re: oil_film_movies] #4495175
08/22/17 12:34 PM
08/22/17 12:34 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
We have sold a couple GT350Rs that have the carbon fibre wheels. We will not even attempt to do any work on those wheels, especially at $4053.33 a piece.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Porsche Carbon Fiber Wheels [Re: bdcardinal] #4495180
08/22/17 12:38 PM
08/22/17 12:38 PM
MN
MN
Your Ford dealer you work at won't change a tire on those wheels? Wow. So Ford has no special tools or instructions or training to change those tires off that wheel? Wow.
