Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
102 registered members (aquariuscsm, 928, Ag76, Alfred_B, Aero540T, Altima2, 12 invisible), 2,095 guests, and 58 spiders.
Topics286,236
Posts4,904,891
Members67,582
Most Online2,967
Mar 10th, 2019
F250 Brake Issue #4494967
08/22/17 07:23 AM
08/22/17 07:23 AM
Illinois
carguy996 Offline OP
Illinois
Im posting this for my neighbor. He bought a 2005 F250 6.0 Power Stroke yesterday, when he drove it the 35 miles back home, when he pulled in the driveway there was smoke coming from the left front wheel with an almost electrical burning smell. The hubs on the front and right rear were extremely hot and brake fluid was boiling out the cap and leaking from the bottom of the master cylinder. After letting it cool, we started up the truck and then the brake pedal sunk and there is no pressure but the fluid is still at an acceptable level in the Master Cylinder. The ABS light stayed on for a minute or 2 and then it turned off. He hasn't had it towed anywhere yet, but would the presumption be that the truck likely needs a new master cylinder, calipers, pads and likely rotors? The truck has 95,000 miles and 2950 engine hours, its a really nice truck.
2018 Nissan Rogue Platinum AWD w/ ProPilot
2014 Honda Odyssey Touring Elite 3.5
2013 Chrysler 200 Convertible 3.6
Re: F250 Brake Issue [Re: carguy996] #4494981
08/22/17 07:50 AM
08/22/17 07:50 AM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Yes yes yes and yes at least. He should also have the brake system flushed - after boiling the fluid he can't be sure it is still serviceable.
Definitely want to take advantage of any warranty if there is one.
Thick vs Thin test: 15k / 43k miles complete
Re: F250 Brake Issue [Re: carguy996] #4494982
08/22/17 07:50 AM
08/22/17 07:50 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Who did he buy it from? Was it a person and it sat for awhile?
If it was a dealer I'd be going after some brake work from them.
Also IIRC that era of powerstroke was slightly below AWFUL.
He needs to check all the issues and confirm it has none of them or that they were fixed.
Re: F250 Brake Issue [Re: carguy996] #4495003
08/22/17 08:31 AM
08/22/17 08:31 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
Sounds like the caliper(s) hung up.
Extremely common on these trucks, especially if they don't tow often or aren't used often. It's not the sliders that seize up but the piston in the bore of the caliper. I have a 2001 with 62K miles and pretty sure it's on it's 7th set of calipers.
What happened was the calipers hung and he kept driving to the point that it boiled the fluid (which you saw) and that caused the pedal to go to the floor.
If you're lucky, you can get by with replacing the right side calipers - I would do all 4 since the other side isn't far behind - and a brake fluid flush.
You *may* have lost an axle seal on the right rear side. Maybe caused damage to the wheel bearing in the right front. Calipers themselves may be bad now too from being heated up.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: F250 Brake Issue [Re: carguy996] #4495005
08/22/17 08:31 AM
08/22/17 08:31 AM
Illinois
Illinois
The vehicle was purchased from a dealer. This isn't your typical dealer though, its a real small town with hundreds of older used fords (including 4 Aerostars), some of which are literally sunk into the gravel up the rim. This particular truck had been there since April of this year....some of the vehicles had been there for years according to carfax. The vehicle was purchased as is/no warranty, in IL there is no return period when a vehicle is purchased used. His plan is to call the dealer this morning but likely will be told there is nothing that can be done.
Re: F250 Brake Issue [Re: carguy996] #4495011
08/22/17 08:37 AM
08/22/17 08:37 AM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
Lesson learned
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: F250 Brake Issue [Re: carguy996] #4495017
08/22/17 08:45 AM
08/22/17 08:45 AM
USA
mk378 Offline
mk378  Offline
USA
Calipers will rust and get sticky on almost any vehicle if parked outside and not used for months.
Did he test drive before buying?
Re: F250 Brake Issue [Re: carguy996] #4495019
08/22/17 08:49 AM
08/22/17 08:49 AM
USA
SOHCman Offline
SOHCman  Offline
USA
Definitely time to replace master cylinder, and likely all 4 corners as well. Or at least a full inspection and fluid flush.
Also see if the parking brake has seized. Sitting vehicles eat brakes unfortunately...
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: F250 Brake Issue [Re: SOHCman] #4495034
08/22/17 09:14 AM
08/22/17 09:14 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Yes and possible wheel bearing or seal issues from the extreme brake heat..
also I found a list of possible engine issues
http://www.powerstrokehub.com/6.0-power-stroke-problems.html
This engine started the era of "Powerchoke" engines
More power and extreme lessening of reliability vs the previous 7.3L powerstroke.
Sounds like your neighbor just got a $1000-2000 wake up call for buying used truck without inspection.
Re: F250 Brake Issue [Re: carguy996] #4495082
08/22/17 10:32 AM
08/22/17 10:32 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Figure out the brake issues. I would start with the caliper in question and go on from there.
Then go to Powerstrokehelp.com. Look for 6.0 issues. Most people end up having a bunch of expensive upgrades done to make it a usable truck.
2015 Ford F250 w/Powerstroke
Re: F250 Brake Issue [Re: carguy996] #4495117
08/22/17 11:26 AM
08/22/17 11:26 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Aside from the brakes issue , if he is interested , check out http://powerstrokehelp.com/ .
Wyr
God bless
Re: F250 Brake Issue [Re: carguy996] #4495169
08/22/17 12:30 PM
08/22/17 12:30 PM
stl
MarkM66 Offline
MarkM66  Offline
stl
Interesting. What dealer is this?
Re: F250 Brake Issue [Re: Donald] #4495266
08/22/17 02:12 PM
08/22/17 02:12 PM
Illinois
Illinois
Its the Ford Dealership in Delavan, IL. There were literally hundreds of Ford products from the 80's and early 90's just sitting there. It was actually quite a sight to see. Many of the vehicles had incredibly low miles. There were Aerostar's, 1st gen Explorer's, Mercury Villagers, Rangers, a Bronco II, it was quite a time capsule walking through the lot looking at all the vehicles. So many of them had flat tires or just are sunk into the ground.
Re: F250 Brake Issue [Re: carguy996] #4495544
08/22/17 07:29 PM
08/22/17 07:29 PM
USA
mk378 Offline
mk378  Offline
USA
They should have sold those cars years ago while they were still worth something. Now they're basically junk.
